Question about Western Digital Caviar SE WD1600AAJS 160 GB SATA Hard Drive
Although BIOS/CMOS and Device Manager can see the drive, but the status is 'unreadable'. However, File Manager cannot see the drive. Can someone please help?
  • 2 more comments
  • alfixya Jun 09, 2008
    Hi worldvet,
    Yes, I've been using it since March 2007 (over 1 year) and I have not used even half of the 160GB.
    FYI: I have two IDE hard disks (one being the master and the other being the slave). This SATA disk is the third HD where I put all my data. Do you think it has anything to do with the driver?
    What happened: I switched on my PC last night and for some reason it says DISK BOOT ERROR, I pressed ENTER. No luck but with the same error. I then pressed the reset button to reboot, it came back with the same error. I pressed enter again, same error returned. So this time I switched off the PC, waited for a few seconds and then switched on. It booted up fine, BUT I could no longer see the SATA drive on Windows Explorer. The funny thing is the it shows up in the Device Manager. The Device Status says 'This device is working properly.', but the Volume Status says 'unreadable', and Capacity being 0 MB. On the other hand, it shows up and is detected OK in the CMOS/BIOS.
    I just tried connecting it to the other SATA connector on my motherboard and it's still the same.
    alfixya
    I have not tried another SATA cable. My power supply only comes with 1 SATA power plug. Can you please send me the link? I can't see the link to the Registry Fixer you mentioned. Thanks.
  • alfixya Jun 12, 2008
    Hi, I tried the SS Registry Fixer...still no luck. I might go get a copy of the Hiren's Boot CD and see how it goes...
    Yesterday, my friend gave me a copy of Active Partition Recovery for Windows. When I tried to recover the good partition, it said "The disk has not been initialised by Operation system. After partition is recovered, device might not be accessible by operating system...etc'. If I go ahead to initialise the disk using Computer Management (Fix MBR), will I lose all the data in the disk? Does initialise mean formatting?
    Regards,
    alfixya.
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    Have you formatted your drive yet?
    Regards,
    Worldvet
Hi, I could not find the Initialise option under disk management for this disk. So I used Active File Reovery and managed to recover all my data, and then reformatted the SATA disk as a basic disk (instead of dynamic disk). So all is good now. Thanks for all your help and advice.
Regards,
Alfixya
Posted on Jun 25, 2008
Hi, are you talking about the Console Recovery in Windows Setup disc? I did press F6 to install all drivers but I did not press 'R' subsequently for the Console Recovery. Should I ? It did not ask for SATA driver.
There are two SATA sockets on board. I tried booting up with the SATA disk and cables disconnected. It booted up just fine. I think it might have caught a virus that corrupted the partition table.
In the Computer Management, the right bottom window says this dynamic disk is unreadable (with a red cross). The disk does not show up in the right upper window (so cannot right click to Explore). I can see the other two good IDE disks though.
Also I can't find the option under Computer Management to fix MBR . It has <Refresh>, and <Rescan Disks> actions. Please advise.
Regards,
alfixya.
Posted on Jun 13, 2008
    Guru:
  • 859 Answers
Have you tried another SATA cable and power plug?
Yes, it could be the driver and I'd do a registry sweep with a good registry fixer, not just a cleaner. A good free utility is Registry Fixer and can be found at this location just scroll down the page until you see the entry.
When you do get a good boot into Windows download and run the Registry Fixer and give that a go.
If that doesn't work and you have the SATA driver for your board on a floppy or CD, restart the PC with the Windows installer CD/DVD and press F6 when prompted and reload the SATA driver for your board when you let the installer run it will eventually tell you that Windows is already installed, just select the Repair radio button option and let her install. Windows will heal itself and this should solve your problem. If the cable, power plug swap, Registry Fixer and reinstall of Windows as a Repair option does not solve your problem it is your hard drive and you can use this sequence you went through to seek an RMA.
As to your data should all this fail you can get a hold of a copy of Hiren's BootCD and use one of the partition recovery programs to see if they can heal what could be a partition table entry error and bad partition alignment.
Keep me posted.
Thanks,
Worldvet
Posted on Jun 09, 2008
  • Glenn Rogers
    Glenn Rogers Jun 09, 2008
    Sorry about not putting the link in there. I guess it was too late at night to be answering posts.
    This is it.
    Regards,
    Worldvet
  • Glenn Rogers
    Glenn Rogers Jun 12, 2008
    Initializing does not format the drive. The software your friend suggested is good software. If the MBR is damaged fixing it will help and the software your friend suggested would help you to recover any lost partitions.
    Question: Are you using an add in device card to access the SATA or remind me again, is this an onboard connection.
    Have you tried the repair option in the Windows installation disc and loaded the F6 SATA drivers when prompted? You must try this before you can ask your motherboard maker for a replacement. You are still under warranty, aren't you?
    Lastly, when you can get into Windows again, right click My Computer and select Manage, Disk Management then right click your sata drive and choose Explore. Can you get this far? And, if so, do you see your drive contents.
    And finally, disconnect your SATA drive from the system, comm cable and power cord. Does your computer bootup normally now?
    Worldvet
    Regards,
    Worldvet
My harddisk showng 0.0GB in bios and PATA mode , how i can resolve it plz help
I would try to reseat the disk. Also, try clearing CMOS by removing the battery or repositioning the CMOS jumper. If that fails, the hard drive has failed.
Jun 02, 2011 | Western Digital Caviar SE WD1600AAJS 160...
Helloo i have problem with WD 1600AAJS not boot i can see bios hellp my please i dont now wath wii do.
trying re-installing windows again. before that get into the bios of the pc and check the connected devices to see if the hard drive is being detected.let me know if u need more info.
Apr 03, 2011 | Western Digital Caviar SE WD1600AAJS 160...
I need driver for my WD1600AAJB
Hard disks don't require drivers.
Please explain the problem you are having and someone here may be able to help you.
Include what OS you are running, type of motherboard you are connecting it to , etc.
Feb 24, 2011 | Western Digital Caviar SE WD1600AAJS 160...
The drivers for this device are not installed. (Code 28) is there any way to get drivers to my hdd?
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)right click updare driver
hope this helps
Sep 18, 2010 | Western Digital Caviar SE WD1600AAJS 160...
Hdd is locked
http://stason.org/TULARC/pc/hard-drives-hdd/western-digital/AL-2200-CAVIAR-LITE-200MB-2-5-SL-IDE-AT.html
Password protection the same idea send it back to the manufacturer or use the correct password and then delete it from the device
Aug 23, 2010 | Western Digital Caviar SE WD1600AAJS 160...
Does Western Digital still offer a disk to write 0s & 1s to the entire drive?
hi , i dont think they do that anymore , but i use this software for it
http://eraser.heidi.ie/download.php
it works great and is free .
hope this helps
Jul 08, 2010 | Western Digital Caviar SE WD1600AAJS 160...
Was wondering if my wd1600aajs was still under warranty
There is usually 12 months warranty with hardware, you need proof of purchase and date of purchase.
Oct 18, 2009 | Western Digital Caviar SE WD1600AAJS 160...
Just buyed Western Digital Caviar SE WD1600AAJS 160 GB SATA
you have to enable the raid controller in the bios to see sata hdd nad have you pluged the power connector to hdd which is by the sata cable port then to your sata port in the motherboard, then install sata card drivers for your motherboard then reboot and after you have rebooted goto devise manager and see if it is reconised the driver if you have a yellow question mark then select it then right click then uninstall then click yes when removed driver goto the icon with spyglass and computer on and doubleclick on to search for new hardware once done reboot then your new hdd will be in the my computer icon.
hope this will help
Jul 08, 2008 | Western Digital Caviar SE WD1600AAJS 160...
Installing SATA WD 160 GB Hard Drive
You may not have a SATA system - Western Digital has the other type of hard disk drive available.
Apr 07, 2008 | Western Digital Caviar SE WD1600AAJS 160...
Western Digital Caviar  SE WD1600AAJS 160 GB SATA Hard Drive Logo
2,181 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
