Question about Goodman CLQ36AR49 Air Conditioner
AC breaker trips after 10 minutes
Turned on unit; runs fine for 10-15 minutes, cooling begin immediately - then trips breaker? Fan runs, thermostat works, condensation pump works.
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Whats the amp breaker? Is this for the inside unit or the outside condenser? If the inside and gas heat you have a bad fan motor, If its an electric furnace , the same, but if its the outside unit, the fan could be going bad, locking up and the compressor still runs and pulls high ampsand tripps breaker or the compressor is just pulling too many amps due to plugged coils with dirt , grass or weeds blocking airflow.(koolbreezes74401@yahoo.com)
Posted on Jun 09, 2008
My duo therm 13.5 btu rv air conditioner started making a popping sound and dimming the lights like it's trying to cycle to shut off. Well then it started triping the circuit breaker so I changed out the 2...
The best guess is that you have a bad thermostat. When the compressor shuts off it has to stay off for a long enough period of time for the low pressure high pressure to equalize. If it turns the compressor off and back on immediately it can't start against the heavy load created by these unequal pressures. If it will start every time after sitting for 10 minutes the thermostat is making it short cycle.
May 26, 2014 | Dometic Rooftop RV Air Conditioner
Ac won't blow any air
Good Morning David - Here are some simple troubleshooting tips to help resolve this issue:
If the outside temperature or inside temperature is below 60 degrees, the unit may not run.
Confirm that the unit has power to it.
Check the power cord connection to the wall outlet is secure.
Make sure that the house circuit breaker has not tripped.
Make sure the unit is turned off, Press the TEST button, you will notice a click as the BUTTON pops out. Then press the RESET button. Again, you will notice a click as the button engages, now turn unit on. If the LCDI plug does not reset the cord may be damaged.
The "Cool" circuit has an automatic 3-minute compressor time delayed start if the unit is turned off and on quickly. This prevents overheating of the compressor and possible circuit breaker tripping and the fan will continue to run during this time.
If the unit has been turned off and on rapidly or if the thermostat was changed to a lower number and then immediately turned back to a higher number the compressor may not start. You must turn the unit off and wait a minimum of 3 minutes for the unit to equalize before restarting.
I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. Parts are often costly and if the problem is precisely diagnosed, it can save you a lot of time and funds. I hope these troubleshooting tips help you in some small way.
Jul 09, 2013 | Frigidaire Heating & Cooling
AC runs for 5 minutes and then circuit breaker
What else do you have running on hydro while AC is running? Such as coffee maker, microwave, water heater, fridge. That 30 amp breaker is your main breaker I assume, or breaker on pole your plugged in to. Keep in mind your AC will normally draw approx. 15-17+ amps momentarily when compressor kicks in to cool, then drop back to 12-15 amps when running normal. If your AC is drawing too much current, then you would only normally trip 20 amp breaker for AC in your panel. Try switching other appliances to gas operation while running AC, such as water heater, and fridge. Make sure incoming voltage is up to specs as well . (115-120 volts)
If water heater takes 5-8 amps, and fridge takes same when they are calling for power, you'll be close or over the 20amp mark when you consider your on board converter etc. as well. That only leaves approx 10 amps for AC that requires approx 15 amps to run, and up to 20amps when compressor kicks in. If you switch all those other items over to propane, and it still happens, then a current draw test should be done on AC unit to see if perhaps a capacitor is faulty, or possible compressor faulty.
Jul 22, 2010 | Dometic Rooftop RV Air Conditioner
RVP 8000 A/C just experienced slight power surge. Compressor on.
I'm leaning toward sticky relay as well, but if you want to confirm it's not thermostat, remove thermostat from wall, and temporarily disconnect the yellow wire from thermostat (compressor) when/if, it happens again. If compressor stays running, I'd say relay for sure.
Just for future reference , Gray wire from thermostat is low fan, green wire is high fan, yellow is compressor, blue is ground. ( For cooling side) The red is 12 v + to furnace and white is negative to furnace.(heat side)
Jun 10, 2010 | Coleman Mach 15 Air Conditioner
Unit shuts off on hot days
It may be low on refrigerant. On hotter days, the compressor has to run longer to reach the temperature you have on your thermostat. Have it checked for the proper refrigerant charge and have them test how many amps that the compressor is pulluig as well. With the proper breaker installed, the unit should not be tripping out. Make sure that the breaker that is in there now is actually the proper one for your unit.
Best regrds, --W/D--
Aug 01, 2009 | Dometic Rooftop RV Air Conditioner
AC Kicking OFF Breaker
Sounds like you have a problem with your compressor. If the beaker trips the second the compressor tries to come on hen it is shorted. If it takes a couple of seconds, then your compressor is locked up.
seth
Jul 03, 2009 | Dometic Rooftop RV Air Conditioner
579 series, 13.5K BTU Rooftop trips AC circuit breaker in hot weather...
Is your condensing unit located in a well ventilated area and have an ample space, atleast a foot, from the rooftop flooring? Just make a check that free flowing outside air properly ventilates the condensing unit specially on high ambient temperatures. Hope this would solve your problem
Sep 16, 2008 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
744 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
