Question about Sony FD Trinitron WEGA KD-34XBR2 34" TV
Sony Trinitron KV-32XBR15
The picture has collapsed on the left and right Horizontal plane.
This problem produces an "Horu-Glass" picture/raster display.
I have checked for cold solder joints in the Horizontal and Flyback
transformer areas. I resoldered every suspected solder joint in these
areas but, the problem still exists. This is about all I can do since I donot have a schematic.
If the flyback transformer is bad, I would suspect a blank screen with no
raster. (?)
Any sugestions what could cause this problem?
Thanks,
Krist
  • kandersen
    kandersen Jun 08, 2008
    THIS IS WHAT I SEE!!
  • 10,594 Answers
You should check Pin-Amp stage for subject problem. Pin Amp is located at Horizontal area. Pin Out Transistor is suspected.
Posted on Jun 08, 2008
SONY TRINITON KV-32XBR15 The picture has collapsed on the left and right horizontal plane. This problem causes an " Horu-Glass" picture/raster display. I have checked for cold solder joints in...
From your description it sounds like a yoke problem, you describe an hour glass picture which is a classic symptom of the horizontal sector of the yoke is at fault. The easiest way to test for this is a ringer tester, chances are it will show a short in the horizontal winding which causes the high voltage to load down and draw more current in the process.
Mar 08, 2011 | Sony FD Trinitron WEGA KD-34XBR2 34" TV
Power on, sound no picture for three seconds, power off, led blinks 6 times pause repeat
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
That means no horizontal output which could be caused by a faulty driver stage or even a faulty power supply.
Hope that helps.
Dec 09, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My sony trinitron 32" tv just went black and the
Hello
Six blinks of standby light in Sony TVs denotes the absence of horizontal oscillation.
In most cases the Ic is foud defective. anyway check its soldering points for any loose contact, or bad solerings. Check the line drive transformer, a very little transformer soldered directly to the main printed circuit board, very close to the horizontal output transistor. Check its primary winidngs for open. If it gets open no horizontal drive signal will be present at the base of the horizontal output transitor, that also may the cause of horizontal stop.
Nov 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony wega blinks the standby light red 6 times, pauses and repeats. Cant get a picture on it at all. Any ideas?
  • Sep 13, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Sony FD Trinitron WEGA KV-30XBR910 30" TV Led flashing
    6 blinks meens no horizontal and no raster check capasitor c515/c516/ jungle IC and IC206.
    regards,
    daniel.
    Dec 28, 2008 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
    My Siny Trinitron G21M1 is producing horizontal lines across the screen
    I hope your TV model is Sony KV-G21M1 and you see color bars as horizontal lines across the screen.
    Let me now are you tech guy or know how to repair TV to guide you further.
    Oct 26, 2008 | Sony Televison & Video
    Sony 32
    It more like the tuning capacitor(s) that is connected to the HOT that is defective or a cristalized/dry solder joint nearby the flyback transformer.
    May 30, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
    KV-32XBR15
    Yes, you should check other parts. The horizontal output transistor is more than likely shorted. Also the flyback could have gone bad. Some SONYs have problems with the horizontal driver transformer which is connected to the base circuit of the horizontal output transistor. If this little transformer has a loose solder connection, it will take out the horizontal output transistor. This may give you some insight as to where to look for your problem. Stargazer
    Jun 11, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
    Trinitron- hourglass?
    You very likely have loose conection in the horizontal drive transformer,dont use or it will blow up all the way.Good luck.
    Aug 31, 2006 | Sony FD Trinitron WEGA KV-32FS100 32" TV
    Sony FD Trinitron WEGA KD-34XBR2 34" TV Logo
    390 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
