My tv screen is frozen. I can change channels but the screen stays frozen
  • 5,138 Answers
Unplug the TV wait 1 hour plug back in and see what happens set should return to normal.
Posted on Jun 10, 2008
While using closed captioning, when the program goes to a commercial, a phrase of text stays frozen on the screen. I tried changing channels and turning the tv off.
What you are seeing may be a quirk of the CC system because program content is "paused" for insertion of commercials. Think of it as a memory aid to help you remember where you were before the distracting commercials started. :-)
Nov 18, 2016 | Samsung Televison & Video
One caption frozen on screen
I believe this is associated with closed caption settings. This can be found in your setting menu, most likely under video. In there turn off CC.
Apr 02, 2014 | Samsung Televison & Video
Frozen display
hi on the remote control press the i button this should remove the caption, go into the menu on the tv select display setting check the time out hope it helps
regards
shaun
TV turns on, but a picture from previous channel I was watching is frozen to the screen. I've unplugged cable cable card and connection to cable service and picture is still frozen on screen. Will not...
sounds like a burn-in but are you saying that you can view another picture but no clear because the previous picture is still there. A burn-in is a tv being left on a fixed object like a picture and left there so long this is what you see when you change channels the image burned on the screen, is this what you have?
Jan 06, 2011 | Hitachi 42HDS69 42 in. Plasma Television
Samsung tv power cycles when I get to higher channels pass 40. I attempt to change channel. Doesn't change and then front led blinks, tv screens goes blank, led flashes again and then screen is normal. I'm...
We have a similar problem when changing channels/surfing, the TV will begin to power cycle, until you unplug THE CABLE TV input, then it will turn on again and stay on as you rehook the cable and change channels....till it decides to do it again, DTV channels seem to trip it up, but not sure....if I leave it on the same channel it will run for days. Yep and the cable TV is grounded outside
Dec 19, 2009 | Samsung LN40A630 40 in. LCD TV
Screen is frozen and displaying," this is an encrypted channel." I unplugged it for a few hours, turned off and on....what do I do next
hook up your sat/cable box and reset the tuner; place the set into "setup" then: "add channels" the tuner will look for and install active channels
Apr 25, 2009 | iLO 3200 32 in. LCD Television
Multiple issues with tv
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Feb 21, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Cannot change channels in digital mode
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Jan 29, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Tivo tv screen frozen
It could be your tuner, can you/have you tried changing to another channel?
Dec 12, 2007 | Tivo Series 2 80-Hours Video Recorder
Picture frozen
Source box problem, not TV. Have you tried playing a DVD....
Nov 03, 2007 | Sony KV-32S45 32" TV
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
