Question about Cameras
Hi again its Alex
Yer tried the battery removal but it still doesnt work, have you got any more ideas, many thanks Alex( 770swback screen not working)
  • 2,985 Answers
Take a look at the screen from the side .
1. Can you see any image there at all[like a shadow]?
2. Is totally black with a hind of luminosity along the top?
If the answer is [1] then the back light has failed.
If the answer is [2] Then there is either a connector problem or main board failure.
With 2 try gently squeezing beleow the screen and/or gently on the base of the camera to try to reconnect
Repairs/replacement are virtuosely a no no particularly in the budget/ popular brands - there items are considered 'consumable
You have not named the make so I cant go further - Contact the makers support site- If it is a recent purchase replacement may be possible.
Posted on Jun 08, 2008
Hi. I'm using nokia c3 mobile phone since my battery was very low i tried charging my mobile by using ten rupees currency note by placing it at the center pin of the battery and tried switching on it...
Dude, It's not because of what you did by the currency note. There might be some other problem.
Try removing the battery and then place it again.
May 20, 2011 | Nokia C3 Cell Phone
Hi i have bought netbook Acer Aspire One. i want to boot it from usb cdrom. after i changed bios boot order and exit from the bios. i have only a black screen. the computer do not shows anything in...
You are on the right track, but just removing the battery wont help because the BIOS is powered by a CMOS battery that also must be removed...
For it to just be giving you a blank screen, however, you had to change more than the boot order because the system doesnt initilize the boot order until well after the bios should be availiable.
I did find this moethod, however that may work since it's a big pain to disassemble it just to remove the CMOS battery:
Feb 15, 2011 | Acer Aspire One PC Notebook
Hello, my powershot screen doesn't work when I try and compose a picture but works fine when I review the picture. Is this a result of a setting I can change?
Thank you for using FixYa for your problem
yer in the settings you can have it turned off or on while picture taking
Please rate our solutions and if you still have problems please call back for more ideas to help you
Richard Scott
Technical Support
New Zealand
Feb 21, 2010 | Canon PowerShot A560 Digital Camera
Will not power up, no lights or sound
tried to remove battery and ac for a little while?
if that doesnt work, remove battery and ac-power.
remove the ram
put ac-power back and try to boot without ram
(do you get a beep/error?)
remove the ac again
insert the ram
insert battery
insert ac
try to boot up again.
if that doesnt work its probably a mainboard error and you need to take the computer to repair.
May 29, 2009 | Intel Everex LM7WE Notebook
Two things can be happening, either your charging system isnt doin the job, or you have a short thats draining yer system... so
to answer your question... start by fully charging your battery, then put a volt meter on it and turn your bike on.... the volt reading should increase.... if it doesnt - you got a stator or regulator problem - if it does..... you need to trace your wires for a possible ground to yer frame
Mar 18, 2009 | 1996 Honda CBR 600 F(3)T
When I turn it on, I can hear the fan working, but the screen is
Hi, is possible that on having hibernated your equipment has blocked himself, tries removing the external battery and it connecting only to the AC Adapter, try turn on, as soon as the equipment completes the load of the operating system, turn off and place again the external battery, must work
Jan 08, 2009 | Toshiba Satellite M35X-S349 Notebook
How to reset Asus PC-DL Deluxe BIOS
Remove the Lithium Flat Battery from the motherboard, then start the machine. Let it run for about 5-10 seconds and then turn it off and put the battery back in.
Some motherboards when you try to power it up without the battery, will not turn on. Press the power button 2-3 times and then place the battery back in and it should achieve the same results.
Dec 11, 2008 | ASUS PC-DL Deluxe Motherboard
ASpire 5580 series, no power
Hi Dhadha,
Try this: - remove AC adapter plug - remove the battery - insert the battery again. - try power up the laptop.
I have same problem, but this trick always work, and I always do this every power up. :)
However, I am using a usb optical mouse for an indicator. When inserting the battery, I check the light on the mouse. If it is flashing the second I insert the battery, then the power up will be successful. IF it is not, then remove and insert the battery again.
Try it.
Dapid Candra
Nov 17, 2008 | Acer Aspire 5580 Notebook
Acer aspire 5580 laptop unable to power up fully
remove battery and use the ac try it then, if that doesn't work remove everything possible cdrom,memory,battery,pc1.gif cards and try it again, if still fails try wiggling the ac cord at the input
Jan 24, 2008 | Acer Aspire 5580 Notebook
Toshiba satellite a135-s23876
if I'm not mistaken there is no reset button ot this Satellite. Try unplugging the charger and removing the battery to reset it. Let me know what happens
Nov 09, 2007 | Toshiba Satellite A135-S2386 Notebook
Cameras Logo
60 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
