Question about Cell Phones
Phone wont turn on
I used the wrong charger on my samsung phone, i think i may have shorted the battery. is it worth putting a new battery in or will the memory board be ruined ?
    Brigadier General:
  • 7,752 Answers
Try a new battery if that does not work then take the phone and have th phone fully service and check.
Posted on Jun 08, 2008
I have had my samsung propel for 3 years now and every time i put it on the charger i have to position the phone just right or my phone wont charge. at first i thought it was the charger but i plugged in...
Sounds like you have a cracked PC board at the charging port. Most likely caused by attempting to remove the adapter without depressing the tabs. This is an easy fix if you can find a shop to do it; keep in mind that repairing maybe as much or more then the phone is worth.
My suggestion is to position the charger so that the battery continue to charge, then replace the handset when it no longer accepts a charge. This could take a week or a year or two before the charging circuit is no longer working.
Jan 11, 2011 | Samsung Propel A767 Cell Phone
Samsung Intensity Wont turn on.
More often then not its the battery even tho the battery is fully charged as it may seem. The rel test is get a new battery not your friends battery tho but a new one put it in there and let it charge. If that doe not work then the phone's logic board has been effected and it may or might not be worth reviving. But check the battery first.
Please do be considerate and leave ratings and feedback for all experts involved in helping you out today, thanks
May 26, 2010 | Motorola Mobility Boost i415 Cellular...
I have a samsung f480i.. and lately it just died, when i plug it into the battery charger, all it does is keep flashing the samsung logo and gets extremly hot, it doesnt even turn on anymore, just flashes...
If the cell phone senses that the charging is too strong (that is, if the charger is giving too much voltage that could make damage) the cell phone will react with a message tha tcharging is wrong or by blinking until you remove the overcharging item. Also, it could be that the battery is shorting (internally) and causing the charger to react toa short and the cell phone sense this as incorrect voltage, and thereforeis warning that something is wrong. Try the charger problem by attaching the cell phone to someone' elses phone charger and see if it continues, or if you have or can cheaply buy a car charger adapter for the cigarette lighter outlet; this will tell you if the wall electric charger is at fault or it is the battery.. if you still get the same results with the car charger, hopefully you can go to a cell store or a friend and try another battery before buying one. If a different battery does not stop the blinking, the problem is the phone.. if it is ithe phone, try turning off the phone and wait one minute before turning on.
Apr 28, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
Samsung omnia problem trying to charge battery
It looks like battery is damaged... When plugged in to charger phone shouldn't power on. Try put it on charger when on and see if charging icon appear. (top right corner-battery status icon should change -insted of battery to charging.) Battery is fully charged after cca 4 hours, 80% after 2 hours.
Jul 16, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
My samsung juke wont turn on. ive charged it several times and still nothing. ive sent it to electronic experts and nada. ive taken th battery in and out and nothing. Ive held the END button on the phone...
Does the Verizon logo flash when you plug it in? I had this same problem. Take the battery off. Plug the phone in. Observe the flashing logo. Put the battery back in. Observe "Charging..." screen. Power on. Unplug. Good to go.
Jun 05, 2009 | Verizon Communications Samsung Juke Cell...
Phone won't turn on
dear there is clear problem in your charging place that can not transfer the charge to the cell part till it remins to the bettry not move forward into the moblie..
so let the check of charging place below mobile
May 26, 2009 | Nokia 5300 Grey Cellular Phone
I got a short or something wrong the phone wont
change your charger 7 if that doesnt work . your board mey be bad , unfortunately , you may have to buy a new phone . if you would like to know how you can get a better phone . go to www.ytb.com/gizelle and click on "view company presentation".
May 06, 2009 | Samsung Blackjack SGH-I607 Smartphone
Samsung SGH-A701 Wont charge when on the charger
Similar problem, battery ran out but cant get recharge it, sometimes the screen flashes if it take the battery out and put it back in, but then black?
Should I try an new battery or a new phone?
Jul 15, 2008 | Samsung SYNC SGH-A707 Cellular Phone
My problem is with the sidekick III, it wont charge, What should I Do?
dnt drain the batteries of your phones...if that happens pls buy multicharger or battery shock,remove the battery..... charge it for about 5min or shock the battery if ur using battery shock...be sure u positioned it ryt....den put it back on ur phone then charge it or continue the charging on the multicharger until its full !!!!im pretty sure of it....im encountering the same prob as urs before and thats what i did and it work!!!!
Jun 09, 2007 | T-Mobile Sidekick II
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
