Question about Epson Stylus RX500 All-In-One InkJet Printer
Just Bought Can't Get To Print
Trying to print with a USB on Mac and doesnt print image in DiscLabel program just a bunch weird  lines of letters
  • jewels mom Jun 16, 2008
    try reinstalling driver sand software, still no luck
    President:
  • 2,692 Answers
Download and install updated driver.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=26321&prodoid=37472317&infoType=Downloads&platform=All
Intel-based Macs with OS X (v10.4.4 - v10.5.x)PowerPC Macs with OS X (v10.2.8 - v10.5.x)
epson11899.dmg - 29.8MB - posted on 01/21/08
Posted on Jan 16, 2009
I just bought this printer and I have a newer HP Photosmart Plus all in one printer. Unfortunately, I cannot get either printer to print in mirror image. Can you tell me what I need to do to get at least...
Usually you use your software to flip the image before you send the file to the printer. Thus, what program are you using to create the fabric transfers?
This is easiest if you are dealing with an image. Find the command section for layouts and then choose flip or rotate horizontally. For example in Paint, the Rotate drop-down is part of the main ribbon below Crop and Resize. If you are trying to do a line of text, use a drawing program and write the line of text. Select it and then flip it. Write all of the lines of text and repeat the rotation for each one. Similarly do this for any images or lines of images.
When finished, print a test page on regular paper before using the fabric transfer paper.
(Publisher in Office or similar programs will also do this well.)
If you are using images from a file, import it into an appropriate software program to do the rotation then save it to a new file name before printing.
I hope this helps.
(some printers have the mirror image option in the Advanced Settings. Not many of the ones that I have used have the feature.)
Sep 15, 2011 | HP DeskJet 1000cxi InkJet Printer
Alignment is not the issue with my printer... i keep getting a shadow behind my letters and images I print, but not on typed documents... only scanned ones or copied and pasted images into word... so...
The shadows are common from scanned images. You might want to hold the book you are trying to scan in a better angle so that the scanner can read it more clearly. Then your scans won't have that many shadows.
Mar 06, 2011 | Office Equipment & Supplies
Photosmart C7280 only prints half the letter/line the part that prints is perfect but I would like the rest of the letter. Is the printhead out of position?
The print head is dirty, of defective.
Try a few cleaning cycles (the hp tool kit is in your HP program menu)
If this does not improve you image, replace the print head
Jan 07, 2011 | Office Equipment & Supplies
I have a hp 3310 wireless. It prints in colour well but if you print in black most will be not clear although a line every so often is printed clearly. If you print the same document the same lines...
What you are trying to print is created in RGB. This means it is a photo that has been created in a color format that will ONLY print if you print it in full color. If you try to print your photo item in only black, it will only print what it sees in TV Colors, a combination of RED GREEN BLUE. This is why you will only get part of the image printed when only in black.
The only way to change it to print the whole image in all black, is to open the image you are trying to print in Photoshop or another professional grade photo program, and to change the settings of the image to CMYK, effectively, Cyan, Magenta, Yellow, Black. Then, change the image once again - to GREYSCALE. This will effectively change all the colors to a SHADE OF GREY, in different HUES.
Save the picture as a JPEG, and then print from the desktop, from your picture viewing software that came with your computer, and you will see everything print out from the black ink, in greyscale.
Nov 16, 2010 | HP Photosmart 3310 Printer
I'm trying to enlarge a scanned photo, then print it on my Epson
Hi, scan at around 350dpi, save the image file as a jped and then import it into word or other program that will accept jpegs and you can make the image as big as you want up to A4 or letter size (depending on the paper size you use
Jan 27, 2009 | Epson Stylus Multifunction Inkjet Printer/...
GIMP Printing Problems
I'd suggest the print driver is off by several generations. Have you tried moving over to a KDE deaktop and trying it from there? If you have KDE installed that is.
Worldvet
Oct 19, 2008 | GIMP GNU Image Manipulation Program
Doesn't print correctly
Current printers do not have a 'built-in' font or character set. The printers only print what they are told to print by the application from which they are printing. What program are you printing from? Does it do this with all programs? Check printing from very basic programs like Notepad or Wordpad (print documents that are at least a couple of pages long). If the printer prints correctly from there, you may need to contact the publisher of the program that is giving you the weird printing.
Apr 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
HP LaserJet P2015dn
sounds like you're dealing with Postscript issues here. Does your HP have postscript drivers installed.
you might want to check on the current Mac drivers through this link
Mar 08, 2008 | HP LaserJet P2015dn Printer
Epson Stylus RX500 All-In-One InkJet Printer Logo
392 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
