Question about Car Audio & Video
In Dash DVD instalation - handbrake cable connection
How do i connect the monitor cable to the handbreak so the monitor works?
also is their anyway of connecting the cable so i have a switch somewhere so i can have the satnav on while the car moves?
help needed asap
  • david tattersall Jun 08, 2008
    i've cut the main ground cable from unit to car and re-attached with brake cable.
    works perfect.
  • pinkspots Jan 23, 2009
    Does anyone know what colours im looking for i cant see any words in the ford focus
Connect the cable that says "brake" to ground it will then work on the move
Posted on Jun 08, 2008
1.9vauxhall vectra C fitted new pads and hand brake cable now handbrake has too much travel same as before items were fitted
it looks like a common flaw in design
it can fail an mot if handbrake wont hold
with both wheel of the ground and hand brake fully applied do the wheels spin
handbrake cable system on a
1.9vauxhall vectra C says self adjusting
but this picture implys there is an adjustment point
Thread Handbrake adjust
you tube vectra handbrake system in action
Opel vectra handbreak
Jun 15, 2016 | Cars & Trucks
How much would it cost to fix handbreak light it on even when handbreak is on
The handbrake light is also the 'low fluid' warning light. It is connected to the handbrake as that ensures that it is checked every time you use the handbrake. If it remains on all the time, then check the brake fluid and top up if required. If the fluid is ok then it is probably the switch on the lever and is adjustable
May 08, 2014 | 2000 Ford Focus
Abs light traction on handbreak light flashing
Did the handbreak get pulled by chance? There should be an adjustable switch at the end of the saddle- it may just be coincidence,
Is the handbrake cable loose at the wheels? Moving it around should free it up if they had been set and are hanging up.
Feb 15, 2012 | 2003 Volkswagen Golf
Handbreak light on dash board remains on even while driving. Also at present fixing break pads had them bleed. Why is the light for the hand break on. Handbreak working just light remains on while driving
it is either the switch under the handbrake is jammed or the fluid level is low or has air in the system, park the car on a hill both up and down to see if the light goes off. get back to me if you need more info.
Jan 01, 2011 | 1995 Mitsubishi Diamante
No picture on my xtrons d708
Its an installation issue to prevent you watching while driving.The default install requires a wire to be connected to the switch on the handbrake which activates the warning light, this works by supplying an earth when the handbrake is applied if you earth this wire the display will be activated.
Mar 25, 2010 | Recoton Advent XTRON TTL 12" XTRON MONITOR
I HAVE A MAZDA 323 1999 MODEL CAN ANYONE TELL ME HOW TO ADJUST THE HANDBRAKE PLEASE please note it is a 1999 model but it wont let me put that year in
your handbreak connects to the rear breaks follow the cable from your break drum where the 2 meet is the ajustment give it a squart of penertrating oil before ajusting as it has been open to the weather also there is further ajustment where the cable enters the hand break lever good luck ps if this dosent do the trick i suggest you cable is fully streched you will need to fit a new one
Nov 15, 2009 | 1986 Mazda 323
Cdv 710 silver crest dvd is not working
Silvercrest has a policy about traffic security! they deliver car audio and dvd players with no possibility to watch video while driving !I went to a car audio specialist and they connected a brown cable which was the handbrake cable to the ground (a black cable and then the pro was solved!I didnt see the warning (enjoy music only while driving) i could watch dvd while driving and my pro was solved ..
Mar 25, 2009 | Car Audio & Video
Replaced handbrake lever on focus,and steel cable has disconected
either it will hook wright on to the brake assembely or you will have to remove your dash and see if there is any spot it connects to a differsnt cable
Feb 12, 2009 | 2001 Ford Focus
Handbreak lights
Take out the console around the handbrake check the connector and wiring to the handbrake. Make sure it is not grounded or touching something metal
Nov 25, 2008 | 1986 Honda Accord
I have a Ripspeed DVD-730B head unit for my car. its all installed but when trying to play a dvd it displays a message sayin: do not watch while driving and then only plays sound, no picture. how do i...
if the unit was installed with a handbrake lead properly it will only get picture with handbrake on,try taking that wire off and connect it to a permenant positive like the permanent live to the head unit,so the unit thinks the handbrake is on, or if it wasnt installed properly and that wire is somewhere else like a permenant negative then the unit thinks the handbrake is always off hence no picture while driving,hope this helps :-)
Mar 13, 2008 | Televison & Video
Car Audio & Video Logo
14,521 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
