Camara just "froze" last time using it. After charging the battery, push power button, camara won't turn on. Makes a little sound when you push the power button, then just does nothing. My lens won't retract back in either. Had camara for almost 2 yrs.
If the battery power is low, it won't power ON. Charge it for at least 4 hours, and check. http://electronicshelponline.blogspot.com/
If it do not help, replace the battery. It does not hold charge.
Remove the battery. Wait a minute. Put the battery in and plug in the charger and connect it to the camera. If the power button glows and a green LED flashes it is taking a charge. Do not try to turn the camera on UNTIL you can get it to charge.
this occurs in any device that uses battery/s in some cases a small short forms that drains the batts there is only two fixs have the fault found by a service tech and repaired ( expensive and very hard to find) or store the batts out of the camera untill its being used now if the batts are not lasting in the camera then its the batterys simple. always remember with units such as camers always always use rechargable batts they give a heck of a lot more power drive than shelff pre charged batts
Sounds like the battery is down so low that it won't turn on even with the power supply hooked up to it. When was the last time you changed the laptop battery? Also, check voltage of charger to make sure it can charge the battery to specs.
Turn off your LCD display screen. I know this is hard—who likes shoving their face against the camera to compose a shot through the little viewfinder? But the LCD screen single-handed-ly drains a lot of power.
Minimize the picture preview to the least amount of time possible—usually one second. This uses less LCD screen time, thus less power.
Dim the brightness on your LCD screen. A dimmer display extends battery life by consuming less power to light the screen. This might make the display harder to see, but usually only in direct sunlight.
Set the power saver to the least amount of time. Power saver lets your digital camera “sleep” when not in use, but doesn’t shut it down entirely. To “wake up” your digital camera, simply click the shutter button.
Use your zoom as little as possible. The motor that moves the lens uses power. This also goes for repeatedly turning your digital camera on and off if it has an extend able lens.
Turn off the continuous focus. Again, constantly using motors and electronics to ready your shot drastically minimizes battery life.
Don’t push the shutter button half-way down until you’re ready to shoot. Pushing the shutter button (constantly resetting and refocusing) will drain battery life.
Use the flash only when necessary. Your digital camera’s “auto flash” option should take care of this, but make sure your flash isn’t going off in broad daylight.
Don’t delete pictures from your digital camera unless necessary. This consumes power. Wait until you download the pictures to your computer before deleting.
This one’s basic, but charge your battery often. Lithium ion batteries, which most digital cameras use, don’t have “battery memory” like older alkaline. In fact, lithium ions work better and last longer if charged completely and regularly.
there is a little push button on the back. use a niddle and push that down at the same time hold the power button. you will hear the unit turning on itself and then it should work fine
I'm not sure what model camera you have, but it's possible that you may be using the wrong type. If your camera uses AA batteries, make sure that you are using lithium batteries instead of regular alkaline ones. The lithium batteries are a lot better for digital devices and they will last a lot longer too. However, they are a little more expensive. You can find them anywhere they sell batteries. They're the energizer e2 ones in the blue package.
