Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Refrigerator not staying cold
The refrigerator is suddenly reading 48 - 52 degrees. The light switch toggle is somewhat shaky - but has been working. Sometimes it has needed a jiggle to make the lights go on, but not lately. Within the past few days, I have noticed high temp. readings on digital read out for refrigerator. I have turned the unit off and turned it back on and waited a few hrs. to see if it cools back down to desired set temp of 39 - and it is not. what is wrong. This is only 8 years old cost a fortune.
Thank you for any advice you can offer.
    Problem Solver:
  • 12 Answers
Put you own thermometer inside and see if the temperature is the same as the digital thermometer. the light switch shouldn't have anything to do with the temp. another thing to check is see if the condenser fan (condenser is the metal coil on the outside) is running, and that the coil is clean. if the coil is dirty or the fan is not running then either clean the coil or check for voltage at the fan. if you have voltage to the fan and it doesn't run then you need to replace the fan. if you don't have voltage to the fan then you may have a deeper problem. hope this helps
Posted on Jun 08, 2008
Have a Kenmore side by side refrigerator freezer gets cold but refrigerator side stays at 40 degrees
The refrigerator of fresh food side is supposed to be around 40 so its working correctly.
Feb 27, 2015 | Kenmore Refrigerators
What does 34F ER mean
Put a freezer thermometer in the freezer and see if it reads +34 degrees, then put it in the refrigerator. If the freezer reading is above 0 degrees, say +34, then the freezer is too warm. If the refrigerator is reading 34 and the freezer is way cold, then the refrigerator is getting too cold. This could be either a thermostat setting too cold or the sensing isn't reading properly or a much more serious issue. Generally a refrigerator should be no warmer than +40 but not freezing either +32 degrees and a freezer should be about 0 degrees. Make sure nothing is blocking the air flow duct work or where the sensors are located.
Aug 14, 2014 | U-Line Echelon Combo® CO2175DWR Compact...
Our KitchenAid KBRS22KWWH02 works great with the exeption that the freezer is cold but it's not actually freezing ANYTHING!!! For example a carton of ice cream will just stay melted, it will be cold but...
Sorry to read about your problem, I hope this helps you out.
Sounds like your unit maybe low on freon, and that is something you cannot do yourself, your unit should be around zero degrees.
I suggest you contact a service company.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 30, 2010 | Refrigerators
Freezer works but fridge doesn't stay cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2010 | Maytag MSD2756G Side by Side Refrigerator
Lights stay on in fridge
HI. The door switch will be the culprit here.
The interior light in most refrigerators, and the fan in some, are controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Dec 10, 2009 | LG LFX25960ST Stainless Steel French Door...
94 civic a/c
Look at the LOW pressure gauge reading when the engine is OFF.
On an 80 degree day, the LOW gauge should read about 56 psi or higher if the A/C system contains an adequate charge of refrigerant.
On a 90 degree day, the LOW side reading should be about 70 psi or higher.
If the LOW gauge reading is less than this, the A/C system probably needs some additional refrigerant.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 22, 2009 | 2003 Honda Civic
Heater will not stay working
Either the switch you are toggle or the hi tempture reset is going out on it.
Mar 16, 2009 | Water Heaters
The refrigerator is not staying cold
Check it's cealing of the door. Depends if it's cooling and then not staying cold, means door is not cealed or frequency of opening too much. More possibility is gas leakage.
Mar 04, 2009 | Frigidaire FRS26ZSG
Refrigerator side want stay cold
sonnds like your control board is going out .and possibly your cold control.
Feb 27, 2008 | Refrigerators
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
261 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
