Question about Compaq Presario 5000 PC Desktop
Question about installing Windows 98 onto a Compaq Presario 5102 US
I am trying to install Windows 98 with a floppy disk and I click on option 1 (with CD-ROM support) I click on that and then it prompts me with a black screen and a:/ and now I dont know what to type in. This machine already has ME installed on it but I want to put on Windows 98 on it.
    Producer:
    Uploaded 30 video answers.
  • 95 Answers
Hi fej67 ,
http://www.windowsreinstall.com/win98/install98floppy/indexfullpage.htm
(click on the link above)
GoodLuck :-)
Posted on Jun 08, 2008
Compaq presario 5190 is asking on startup for a floppy startup disk
hi,
enter bios and disable boot from floppy disk.save and restart.if this works fine if not you will have to re-install windows.
Feb 09, 2014 | Compaq Presario 5190 (320770-003) PC...
How can i install windows xp when screen showing blue screen
Check whether you have installed the SATA Hard Drive driver using a Floppy disk. Some Computers needs SATA Hard Drive Driver before installing the Windows XP. Try using Windows XP SP2 disk.
Jul 01, 2010 | Compaq Presario 700 470024-192 Notebook
Ican't get a self installed floppy disk drive to work with Vista.
Reverse the data ribbon direction in floppy side (data cables pink color side should be plugged opposite to power cables color side)
Sep 25, 2009 | Teac Floppy Drive 235HF Internal Floppy...
Can not setup windows xp sp3 sata on hp compaq presario v6700
Ok, the problem here is that the Windows XP CD that you have does not have the proper SATA drivers on it already. There are two ways to get around this:
1. Locate the drivers for your SATA controller from HP's website. Copy them to a floppy disk (old 3.5" style) and install the drivers during the installation. When booting up the XP CD, one of the first things it says is "Press F6 to install 3rd party RAID or device drivers". This is where you would press F6. During the install, it would ask you to provide the hard drive controller drivers. Windows XP only allows for these drivers to be installed from a floppy disk, so if your computer doesn't already have a floppy drive, you'll need to get an external USB drive. Once you give XP setup the correct drivers, it can find the hard drive and continue with the installation.
2. Create a custom XP installation CD with the new drivers on it. On another computer with internet, CD-burning capability, and a lot of time and effort, you can slipstream the SATA drivers into the XP CD that you have now. This is not a process for novice users, and can be very time consuming. For a single installation, you're better off with the floppy drive option.
In order to find the correct SATA drivers for your computer, we'll need to know the exact make and model of your computer. The Presario v6700 is a series, there are many models inside of that series. They most likely use the same driver for SATA, but it'd be nice to know exactly which model you have. THis should be printed on the bottom of the laptop.
May 14, 2009 | HP Compaq Presario V6700TX Notebook
Invalid systme disk. Replace the disk and press any key
its domnickr,
its so we can not install xp in model 1255 it will spoils your hard disk all you can install win98 ED 2 only..... so its wise not to try it and reinstall using win 98 install disk. if format is not possible do format using Fdisk command.
step 1 :enter dos floppy
restart ur lap enter from insulation option.
chance boot perority to floppy disk ie Shift +.
restart lap
enter fdisk in commant
format using instruction for any help mail at domnickr@yahoo.com
Mar 21, 2009 | Compaq Presario 1255 Notebook
Supposed to have 20 GB of memory, only have 1.99GB
Use windows 98 to make a rescue disk (3 1/2 floppy)
use that emergency disk to repartition and format the hard drive. You can probley use fat16.
Mar 11, 2009 | Compaq Presario 5000 PC Desktop
Compaq Presario 5102US downloading Windows 98
If U already have 98 on the pc, R U trying to have dual boot, recover, or reload 98 instead of 98ME?
The disk U R using is a recovery disk and U will still need the 98 cd to reload. The disk is for repairing or reloading the 98 system and I would suggest that U learn how to use the command structure first before attempting a system repair.
Please explain what the problem is and what U want the system to do. We R very happy to help U get to where U want to go.
Jun 08, 2008 | Compaq Presario 5000 PC Desktop
Installing widows XP
first, have a WIN XP startup disk...created by (in windows)  inserting floppy and right clicking choosing format and select option "create MSDOS startup disk"
first backup all personal files...then restart and bypass to DOS screen at startup...try using F8 key just after BIOS screen...then select startup to DOS prompt only...then run (from the floppy disc) format c:
now you should have a nearly bare hard drive. repeat above steps and this time choose "startup using CDROM drivers"...then insert CDROM and redirect to that drive letter (d drive?) and run setup.exe.
Oct 30, 2007 | Compaq Presario C552US Notebook PC
Cant perform a quick restore.
what size is yous hard drive and is the windows installing it'self properly and the other problem is have you got all the motherboard drivers if not then the system will become unstable and the hard drive will need to be format back to manufactures default as the files thet were on drive are burrired deep and the only way to get rid of problems is using a program called kill disk then using your win 98 start-up floppy and fdisk the hard drive then partition then format the hard drive then install windows on then all other files for motherboard and graphics and other devices. it should take you about 1 day to get back on line with pc up and running. hope this helps
Aug 14, 2007 | Compaq Presario 5070 (117815-004) PC...
Compaq Presario 5000 PC Desktop Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
