Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron This morning out of the blue, my Sony Trinitron will not turn on. I noticed that the standby light is flashing 5 or 6 times in sequence. I tried to turn it off but it will not turn off now. I unplugged it from the wall for about 10 minutes to see if it would re-set like a computer, but that has no effect. The moment i plug it in the standby light is on, and the on off button - although it clicks and makes a "tube"' noise - the button has no effect. This set is about 5/6 years old. My email is emrldeyes8@yahoo.com Your help is appreciated. I simply cannot afford to replace this TV at this time.
I am having the same problem my tv will not turn on all of the sudden, standby light flashing, cnnot get it to do anything
Posted on Jun 09, 2008
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My tv won't turn on!
My tv did the same,this means your tv needs serviced.Mora than likely it is the bulb gone out in it.These are expensive but east to replace yourself.Just make sure to dispose of the old one properly.You can look in your manual how to change the bulb,that way you can pull it out and check it,see if theres any discolorations or broken pieces in it.You might only need a Phillips head and a small flat screw driver. head to get it out.
Apr 08, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Standby light stays on and the tv will not go on
Please check batteries in remote that seems not working. Sony TV would either turns On or standby light will blinks if TV gets any internal problem.
You question shows standby light stays On that means TV does not receive power on command from remote.
If standby light is blinking in sequence, let me know how many times it is blinking and also intimate exact model number of TV to find out possible solution.
Thanks.
Sep 21, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I have a Sony FD Trinitron WEGA KV-27FS120 the Standby light flashes four consecutive times with a pause in between sequences. When I turn the TV on with the remote, it powers up, you have volume but no...
It is vertical deflection failure problem.
Let me know if you want to repair TV by yourself, that requires soldering parts in PCB experience.
Aug 08, 2009 | Televison & Video
Sony Vega TV , On off switch
prolly u need the "D" board replaced--common to give error code of 5 to 6 flashes--unplug and wait to reset and try again
Jul 18, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony kv-32hs500
Most probably the IC504 (Sharp PQ05RD21) on A-Board went bad. This model TV, including mine, is notorious for having this problem. The IC is rather easy to find and inexpensive (around $2.50). Your main problem will be desoldering the old one and soldering the new one.
Good Luck.
Jul 25, 2008 | Sony FD Trinitron WEGA KV-32HS500 32" TV
On picture
Hiii...
Try to check the M board,IC001,G2 ( Screen ) Voltage....
Thank's
[vrya]
Mar 13, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
215 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
