Question about Nikon D50 Digital Camera
Changing lenses yesterday, i switched lenses, took two pictures. A few minutes later i tried to switch lenses and cannot take off the 28-70mm lenses. It seems to be installed correctly and i am suppressing the release button. I have been trying since yesterday.
    Scholar:
  • 154 Answers
Hmm the correct way is to turn the lens to te left by pressing the release button, and keeping it pressed untill the lens is of (either turn the camera on the back, facing the NIKON brand on top , te bottom of the camera away form you and the internal flash and front lcd towards you
Posted on Jun 08, 2008
I dropped my canon rebel xsi from about 7feet, but it still took pictures after i checked it. nothing cracked, not the lense, or the screen. but than about an hour later, when i tried taking pictures it...
It could be several problems. One is a bad contact between lens and camera body, clean the contacts , check for damage and try another lens if you have one. Try another memory card. Another problem could be with the shutter which would need the camera to be repaired by canon.
Jan 02, 2011 | Cameras
Fridge not working since i replaced door
Hi I would be checking the switch that starts the light when door opens. good luck
May 18, 2010 | Candy CPCA220K Bottom Freezer Refrigerator
From a cold start,power on,screen is all blue with "no signal" in the upper right corner. while still in blue screen mode approx 2 minutes after start a squealing sound starts. about 1 minute later the...
Sounds like a power supply fault due to leaky capacitors(electrolitics).
From cold take the back off and run a hair dryer over the power supply for a few minutes then switch on,if it comes up fully working then you have to isolate the faulty part/parts and replace.
Oct 01, 2009 | Polaroid FLM-3732 Television
Amana AFD2535DEW freezer/refrigerator with intermittent tempurature swings
I had the same issue. It was the relay overload which essentially provides the extra boost to get the compressor going. The switch tries for about 10 seconds before giving up and then retries 3 - 4 minutes later. In the early stages of failure, eventually it will work and the compressor will kick on. But eventually the switch will fail and will just cycle through the 10 second attempt every 3 to 4 minutes. The part is about $35 - part number 67005560.
Jun 26, 2008 | Amana AFD2535DES French Door Refrigerator
White streaks on all photos but not video
Sounds like the shutter isn't working properly.
It should be looked at by at technician.
Jun 16, 2008 | GE A730 Digital Camera
Casio Digital Camera ex-s770 will not open
Hi, this is a problem alot of people get having with this type of camera.
It could be one of a couple of things first check the battery is fully charges as a faulty battery would cause this problem, do you have a switch on the camera that lets you see the pictures stored on it without opening the lense, not all makes and models do this some have switch you can slide and some is just push button the push button you cant do this.
So if yours is the push button one then the only thing to try if the battery isnt the problem is looking and removing anything thats caught in the side of lense.
Ok try removing battery and any mem cards if you have any in it then bang the camera firmly into the palm of your hand sort of shocking the camera to dislodge any thing thats stuck in the side of lense do this few times then replace battery and switch on usually this solves the problem.
If not then when you switch camera on grab the lense and help it come out taking it past where it gets stuck be gentle try this few times and see if camera comes on.
Once the lense is passed certain point the camera should come on.
So give that a try it does sound like something is jamming the lense so try pulling it out gently only do it when its supposed to be coming out when it trys to go back in let go again try this few times.
Failing this then the problem could be that either the camera has been put down with the lense open and forced the lense motor damaging it or the other thing that people tend to do is switch camera on acidently whilst its in pocket or case so that it switches on but the lense is blocked from coming out this causing damage to lense motor.
If the problem is in fact the lense motor then their is no way of getting this repaired they just dont repair these and you cant get the parts like lense motor no camera shop will even look at them as you cant get parts and also price of repair would cost more than replacing the camera.
Also check to see if your lense turns round as its coming in or out if it does this then try turning the lense as its coming out.
Let me know how you get on ok and ill try assist you further
Feb 22, 2008 | Casio EXILIM Card EX-S770 Digital Camera
I can not take pictures
update, possible solution..
I pulled the batteries for 24 hours, attempting to force a reset of the camera. Today it worked, took pictures and zoomed just fine. I shut it off after about 10 pics and turned it back on and back to the start... Took the batteries out for a few minutes and put it back in and back in business. Hope this helps at least get SOME functionality out of it. This won't serve as a long term solution for me, but perhaps will lead towards a full answer.
Dec 17, 2007 | Olympus Camedia D-540 Zoom Digital Camera
Nikon D50 Digital Camera Logo
56 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
