Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Icemaker I have a kenmore coldspot 106.55394400 and the ice maker is not working. Water dispenser is fine. It's almost 3 years old. Is it worth emptying the fridge and turning it off for the night to melt any frozen parts or tubes? Does the solenoid ever go bad or should I just assume the controller board and thermostat is the problem? BTW I don't leave bad reviews here
  • 4 more comments
  • Ben Jordan Jun 10, 2008
    I found details on how to test the ice maker unit itself on-line and it passed all the tests including the thermostat at 0 ohms when cold, infinite ohms when warm and 4.5k ohms when warm and the ice bin full lever is up.
    A little more detail.
    When I took out the ice maker there was no ice in it. Water is not being added.
    I put a themometer in the freezer last week. Can't remember the exact reading but I remeber it being cold enough for whatever forum post I had read at the time.
    There was a lot of dust and hair on the cooling tubes behind the bottom pannel that I cleaned out, that did not solve the problem.
    Yes, I had the full bucket arm in the correct position (down = on) My fridge does not have an on/off switch for the ice maker unless it is very well hidden.
    would the thermistor stop the water from entering the ice maker? I found testing procedures for the thermostat inside the ice maker and it passed. Is this a different part you are talking about?
    Defrosting a fridge is a pain unless you have another fridge to put your food in... the fridge at work has been pumping out 2x the ice for 5 years without problem. I can see into the fill tube and it doesn't look blocked.
    Basically, I don't want to defrost my fridge if there is an easy way to check for ice blockage... should I be able to see the ice blockage in the tube? Can I disconnect the tube and blow through it for a test?
    From what I've read on forums most suggest replacing the controller board. This would cost me around $160. I'm able to replace components if anyone knows A) if this sounds like a controller board issue and B) if by some miracle they know what exactly breaks on teh contoller board.
  • Ben Jordan Jun 11, 2008
    Last night I tested the solenoids. The water solenoid was 190 ohm and the ice solenoid was 260 ohm. I even pulled out the master controller board to look for anything obvious. There were no fuses (even surface mount) and only a few diodes I could test because the board was coated. Everything looked fine...
    I also ran a string through the water inlet for the ice tray so there is no ice blockage.
    The fridge has a built in water filter before the ice maker solenoid so I don't see how mineral blockage could be a problem. Plus our water is really nice here. The water dispensor works fine.
    Scholar:
  • 46 Answers
Have you looked at the pressure of the source supply of water for the icemaker.. ? Sound's like you've checked everything else up to there !
Posted on Jun 11, 2008
    President:
  • 2,712 Answers
Here is a solution I found on a different site:
Try this..using some hot water and a squirt bottle with a tube about a foot to a foot and half long (about 1/8 to 1/4 inch diameter) to melt the ice (if present) and return it to working order most of the time. There is a black tube to the right of the ice maker on the roof of the freezer, if you squirt the hot water there, it should fix it, if there was an ice blockage..This way you donot have to defrost the fridge :) Here is a pic:
It would be better if you take off the ice maker and the ice maker cover. The ice maker cover comes off by lifting it up and pushing it to the right, the pegs come out of the holes then. The ice maker is removed by one bolt at the bottom of the ice maker. Here's a pic to help you locate it:
Once the ice maker is moved out of the way, you can easily feed the tube into the black hose and turn the bottle upside down to push the warm water into the hose. It should then melt any ice and it should all come draining out. Keep a dish underneath the hose to catch the water and (hopefully) the ice that was blocking the hose.
Re-assemble and wait a few hours to see if your making ice again.
Also note if you see a flashing red light just inside the freezer door where the button is to turn on and off the ice maker. A flashing light means problems with the sensing PCB. Look behind the kick panel under the refrigerator door for the service info sheet. It will give diagnostic info for these boards.
Also, a solid red light means that the door is open and the ice maker will not make ice. If you hit the big white switch to the left of the door (hinges area), the light switches to solid red. This tells the ice maker to start making ice. The little holes under the red light are sensors that tell the ice maker when it's full. Make sure that these are not blocked in any way, and are clear, or it will give wrong info to the control panel saying that the ice maker is full..
Hope that helps!
    President:
  • 4,402 Answers
Ice maker solenoid is bad i had the same problem with my fridge.
    Master:
  • 788 Answers
If everything checks out and you aren't getting any water then it's most likely the water valve that isn't opening on the ice maker side. A new valve is available here: http://www.partselect.com/xq/aspx/Inventory.733408/qx/PartDetail.htm?SourceCode=7&ModelNum=106.55394400
Look at this article for a great description on locating, removing, and testing the solenoid on the valve: http://www.popularmechanics.com/home_journal/home_improvement/1276061.html?page=1
It can happen that it freezes, use a hair dryer to heat the valve and the surrounding tubes. That way you won't need to defrost the entire fridge.
Posted on Jun 10, 2008
  • Dean Joly
    Dean Joly Jun 12, 2008
    Try to find a way that you could test for the voltage at the ice solenoid, if there is no signal then the solenoid will keep the valve closed. If this is the case then you either have a problem with your wiring or with the control board even if it looks healthy.
    Here's a link the purchase the control board: http://www.partselect.com/xq/aspx/Invent...
    Genius:
  • 1,665 Answers
WHAT IS WRONG WITH YOUR ICE MAKER
http://www.repairclinic.com/0047_1.asp
Type " kenmore coldspot " at search tab to find parts needed
    Master:
  • 638 Answers
Normally the thermostat cycles the freezer on and off. The cooling system runs as long as the temperature inside the freezer is higher than the set temperature. If the temperature inside the freezer is cold enough, but the thermostat doesn't cycle off, the thermostat may be defective. If so, you need to replace it.
but i feel unpluging n keeping ur refrigerator off for least 24 hours n defrosting it is a best thing to do in such cases.try doing that ,if u hve already tried out doing it n still if it doesnot help.do not try to open it manually if u dont hve any experience as it can lead to further problems.its better to call a technician n the servicing is more than enough to resolve this problem.thanks rate this solution as "fixya" if it helps u anyway.thanks feel free for further assistance.
  • 13,433 Answers
Yeah its a good idea to melt it ones or twice in a year.
    Guru:
  • 1,894 Answers
The thermistor wold be faulty
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
Icemaker not working
The ice maker valve is a dual one. with 2 solenoids. One solenoid operates the water and the other the ice maker. So if the water works that don't mean the ice maker supply is ok. The ice maker itself controls the flow of water. So if the water valve is ok then the ice maker is faulty. I have repair photos HERE
Feb 14, 2010 | Refrigerators
Kenmore 52552100 refrigerator not working
Hello.... do you still have the parts??
I can use Part 921526 PC Board kit, emitter & reciever icemaker - $30.
You can email me at durangoboy@xemaps.com
Thanks,
Paul
Oct 09, 2009 | Refrigerators
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore Coldspot Side by Side Model #57562791
hi debie normaly the life of these ice maker range from 3 to 4 years then the wtr hardness eats them up and the mold start leaking wtr but if is a fairly new model the you have a faulty wtr vale that is not closing sending wtr all the time to the ice maker repl the ice maker is you see is peeling of the texture inside if it is ok repl the valve
Oct 04, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
I have a kenmore coldspot side by side model # 106.53662300.
The ice maker red light is blinking and it has made very little ice in the last 24 hours. What do you think the problem is?
Jan 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
No ice
if you remove the icemaker there is a white cover over the head of the icemaker, pull the cover off. youll see a gear in the center. in the middle of that gear there are two plastic tabs that hold it in place one or both of the tabs may be broken cause a bad conection behind the wheel. if tabs are broken you need a icemaker modual (part the gear is attatched to) if not broken you need a watervalve located on the bottom right side behind the freezer
Nov 19, 2007 | Kenmore 53542 / 53544 Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
289 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
