Question about VIA P4MA Motherboard
Driver problem How can I be sure that I have selected the correct motherboard?? Where can I see the model or make number??
    President:
  • 2,351 Answers
Every motherboard will have the model number of the board marked on the board. Some manufactures place the model number on a white sticker located on the side of a PCI slot. Others mark the board near the memory slots, & others will mark a white sticker with the model number on the side of an IDE port or LPT port. (All found on the motherboard it's self).
Older boards lack such markings & people look for some markings on the north bridge & south bridge chipsets. The VIA P4MA you posted above I found from searching google. Looking for specs. Than the user can compair their board with a pic listed within the spec search. http://www.shopping.com/xPF-VIA-Socket-478-P4MA
Bottom line it is not easy finding older boards with little information marked on the board.
Mike
Posted on Jun 10, 2008
Need ethernet adapters drivers for the gateway motherboard 4000783
You can download the device drivers for your model Gateway motherboard from this WEB site. Make sure you select your model laptop and the correct Windows drivers. Click on this link to download the drivers: -
http://driver-pro.com/related/english/hardware-drivers/?a=12221&gclid=COmm19XHtpwCFSMSagodPRuwnQ&hit=1
Feb 12, 2013 | Gateway (4000783) Motherboard
Network driver
You can download the network and device drivers for your model Gatewaylaptop from this WEB site. Make sure you select your model laptop and thecorrect Windows drivers. Click on this link to download the drivers: -
Nov 14, 2011 | Gateway (4000810) Motherboard
Ned pci modem driver ned aoudio driver ned internet controler number.pls help me
You can download the device drivers from ASUS WEB site.Select your model motherboard/computer/laptop, and make sure you select driversthat matches your Windows operating system. Please click on this link to theirWEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Jun 27, 2011 | ASUS P5PE-VM Motherboard
CANT DETECT THE AUDIO DRIVER ON MY BUILT IN MOTHERBOARD P4S533-MX... PLS HELP ME TO FIX OR WHAT IS THE CORRECT DRIVER FOR IT...
May 06, 2011 | ASUS P4S533-MX MB, DDR+SDR/ VGA/ Audio/...
I lose my sound
Here is a guide to the sounds on a computer
the drivers might have been corrupted by something foreign or you might have got a virus run your antivrus program
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 09, 2011 | ASUS P5PE-VM Motherboard
Need sound driver info for asus motherboard k8m800
There should be a sticker on your notebook with the correct model number.
Make sure your audio is enabled within your bios.
Here is the like for Asus M70 series systems;
http://www.asus.com/Search.aspx?SearchKey=m70
Once you find your correct model, "example": M70SA-B1. Create a folder on your desktop & give it a name. Download the audio driver into that folder. Uncompress the audio file named simular to, Audio_VT_080130.zip
You may need the program winzip to preform the uncompression. If you do not have winzip you can download a 45 day trial version from the link below;
http://download.cnet.com/WinZip/3000-2250_4-10003164.html
Once uncompressed, run the setup.exe file.
If the above doesn't help you can call Asus tech @ 812-282-2787 EDT.
Asus will provide you with the correct model number & the link to download the audio driver software.
Cheers!
Mike
Oct 01, 2009 | Computers & Internet
How do i check to make sure what drivers are installed on my motherboard 680 sli from nividia? I'm having all types of problems installing my new video card also
Download the correct driver from nvidia, and then use device manager to update the driver. If you have the correct driver installed, device manager will report that the correct driver is installed
Aug 18, 2009 | Evga nForce 680i SLI (122CKNF68)...
No sound on my speakers
If I were you, the first thing I would check is to make sure that my new speakers were plugged into the correct jack (usually the green colour coded one).
Next in Control Panel /System/ Hardware and device manager, I would uninstall my sound driver from the "Sound, video and game controllers" list. Select the "Scan for Hardware changes" option from the Actions menu at the top of the page and follow the prompts from the installation Wizard.
If you still have no sound, you may need to update your sound driver. The Mercury download section can be found here. You'll need to know the model number of your motherboard in order to select the correct sound driver.
Good luck and I hope this helps.
Regards, ~ redqew~
Mar 12, 2009 | Generic Memory Computers & Internet
Solve my problem
http://www.acerpanam.com/flex/acer/bin/acer.html
click on the above link goto Notebooks
Select your model number and select the correct sound driver for your windows version there and it should work no problem
Sep 16, 2008 | Acer AOpen AX4BS-V (91.89J11.001)...
Need audio driver of compaq presario V6000
usually all drivers for Compaq and HP computer systems (portable and non-portable) can be found on the HP support website (Click here to go to it), simply go there, chose your region, than your country, enter your model number (not the series, the model number, you would usually find it on the service tag, or wherever you would find a serial number), but be sure to chose "Download drivers and software (and firmware)", and than chose your operating system. Hope this has helped.
Jul 06, 2008 | MSI KM2M Combo-L (MS-6738-010) Motherboard
VIA P4MA Motherboard Logo
739 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
Abhinandan  Patil
Abhinandan Patil
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
