Question about Sylvania SRPD442 42 in. EDTV-Ready Plasma Television
RED LINE I have a small skinny red line in the center of my screen only visible when video is present .It does it in componet composite and vga inputs.How can I eliminate it?
    President:
  • 1,284 Answers
If the line is vertical in nature then most likely then the plasma display panel is bad and won't be worth fixing because of cost. If the line is horizontal then the issue might be a lower or upper Y-buffer module.
Posted on Jun 09, 2008
My tv is a sanyo ds31590. I need to connect to an acer aspire 5253-bz692 in order to watch netflix. What cable do I need?
You'll need a VGA to Composite or Component Cable. Asuming you have RCA Composite/Component Connections on your TV.
I'll Look something like this:
funnyx_1.jpg VGA to Composite
or
VGA to Component
Make sure you TV has @least one of these 3 colored group inputs in front or in back of it. 1. Composite (Mono): Yellow, White or Red
2. Composite (Stereo): Yellow, White, Red 3. Component: Red, Green, Blue
If you don't have any of those then you'll need This Along with a Splitter.
Hope this helps, if it does then please remember to leave Feedback/Testimonial.
Mar 22, 2011 | Acer Computers & Internet
Tip
How to set convergence on Projection TV ' s
I have given an general explanation on most projection TV ' s
  1. Enter the menu on your TV. Use the remote control and bring up the menu.
  2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  4. Press "Enter." A crosshair pattern will appear on your screen.
  5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  8. Repeat these steps for all colors.
on Mar 18, 2010 | Televison & Video
I want to connect my computer to my Vizio TV to watch movies via netflix on my TV screen. If HDMI on TV end, what connection do I need to connect to the back of computer?
What "video-inputs" does your TV have:
* composite video (single cable for video, two cables for LEFT/RIGHT audio)
* component video (RED/GREEN/BLUE cables for video, plus RED/WHITE cables for stereo audio)
* DVI or VGA input
* HDMI input
* S-Video (similar to PS/2 keyboard/mouse, in size, and "round" shape)
What outputs does your computer's video-card have:
* composite (post-and-ring)
* S-Video
* DVI
* VGA
* HDMI
Just match them up.
Feb 24, 2011 | Computers & Internet
It has tripple vision and looks like a bow tie.
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    Red line on screen
    Are you able to view the same Red lines even in the BIOS window? If yes, this may be LCD issue too.. The LCD will show small red dots which are called Dead Pixels. If the Red lines and dots are more, then it is better to contact the Service Center
    Jul 03, 2010 | HP Pavilion dv7-1132nr Notebook PC
    I have thin red line in the center of screen fron
    If the line is present on all inputs, it is most likely a bad panel (screen). The screens are either not available or cost more than a new TV.
    Not good news I know but at least you can save the $100 estimate fee.
    Best of luck
    Roety
    Mar 29, 2010 | Sharp AQUOS LC-45D40U 45 in. LCD...
    How do you set convergence
    What is your Make and Model number?
    Can you hook up a PC to a Toshiba 32HFX71 TV
    yes if the computer has the proper outputs. you need either composite. those are the yellow, red, and white. componet those are red, green, blue. video, and red and white audio. s-video. most of the tvs. with the exception of lcd and plasmas wont sync to the standard vga input on the tv.
    May 31, 2009 | Toshiba 32HFX71 32" TV
    Dish satellite system with two tvs and 1 hdtv cable
    What are you splitting? Coax - just split the out to tv line. A\V cables or componet cables you'll need to split all wires (a\v- yellow and at least white, red to if you want stereo. componet- green, red, blue for video and red and white for audio.
    Mar 12, 2009 | Televison & Video
    Samsung HD Plasma - hooked up DVD to it but movies play in black & white??
    anytime you connect componet signal (green red and blue)to regular video inputs (yellow) end will have same effect. make sure that if you are using component signal from DVD player you have to connected to component input in the set.
    component signal will use green red and blue for video and red and white for sound.
    Composite signal will be yellow (video)
    red and white(audio)
    Jul 10, 2008 | Televison & Video
    Sylvania SRPD442 42 in. EDTV-Ready Plasma Television Logo
    99 people viewed this question
    Top Sylvania Televison & Video Experts
    matt martin
    matt martin
    Computer Repairing
    Computer Repairing
    Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
