Question about Sony BRAVIA KDL-40V3000 Television
Connection hi i have a monitor out on my tv. i want to send this(whatever is playing on the tv to my onkyo receiver which then sends it to my projector how can i do this? ive tried av cables but it doesnt seem to work.
    President:
  • 1,284 Answers
The monitor outputs on most Sony TV's are regulated by the volume level. In other words if the volume is set low then the output will be low. Go into the menu of the TV and turn the internal speakers off and then see if there is an option to set the audio output to FIXED or VARIABLE. Set it to fixed and all should be good to go.
Posted on Jun 09, 2008
Onkyo tx sr502vreceiver wont send sound out when trying to play a cd. Hooking up to samsung smart tv that has no s video or optical output connections. HELP ! ! !
Hi Denni, the TV should not be a factor. Is the CD player connected to the receiver. It should be playing out the receiver speakers. Thank you, Onkyo USA
Nov 30, 2016 | Onkyo Audio Players & Recorders
When I turn on my TV connected from the hdmi port of the Onkyo tnxr609 The says ONKYO with the 609 o. Or off any input selected
Hi Mark, if this has not been resolved please send me an email with a clearer description of the problem, you can email me at askOnkyo@us.onkyo.com, Thanks, JT
Apr 03, 2015 | Onkyo Audio Players & Recorders
My Onkyo TX-SR506 plays cable and CD inputs to zone 2, but DVD won't play. Everything is connected according to the manual and I assigned zone 2 output correctly. What gives?
How are your cable and cd inputs hooked up? Analog connections? Alot of receivers cannot send an audio signal from hdmi inputs to zone 2.
Feb 06, 2013 | Onkyo TX-SR506 Receiver
Playing a blu ray disk on PS3 connected with optical cable to the Onkyo, I only get a PCM signal, no DTS or 5.1 (although this is available on the BD)
In theory, your receiver's decoder should be able to automatically "detect" the incoming audio format. But, this only occurs if the device playing the disc is sending the correct audio format.
So, with this said, there should be a fun tion on your PS3 where you can manually select either Dolby 5.1 or DTS 5.1. Both of these are opposing formats (i.e. can only output one format at a time).
If you were to play a movie disc from a standard DVD player into your Onkyo receiver, you would normally have to manually select DTS 5.1 audio from the disc menu.
Does the PS3 menu allow you to manually select the audio output?
Sep 05, 2011 | Onkyo TX-DS696 Receiver
I want to know how to connect an equalier to an 7.1 onkyo surround system
It might not be worth the effort because it would only be useful for analog 2-channel audio. But it IS possible.
Video 1 and Tape have Ins and Outs for the use of any typical analog stereo processor, such as the EQ.
The following is some boilerplate I made up that should explain some usage limitations.
Be advised that the engagement of any device in a Tape Monitor loop on a late-model Audio/Video Receiver will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
The connections themselves are fairly simple but it pays to understand what happens in the loop.
In general, any Line-Level external processor (EQ, dynamic range expander, etc) will go into a Tape Monitor loop on a receiver. A Tape Monitor, when engaged, sends the stereo analog signal Out to the Processor, massages it and returns it to the receiver via the Tape Monitor IN connectors to be passed on to the receiver's internal processes (volume, tone, whatever).
Old school analog stereo-only receivers consistently work this way. Newer digital and audio/video receivers introduce a couple of problems: 1) digital sound processing to simulate a variety of soundfields; 2) multiple output channels, either discrete or digitally-generated.
The latter requires that whatever signal is being processed experiences a maximum of one analog-digital-analog conversion.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose a STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Monitor as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? They would NOT be processed. That logical problem also plays into the decision to defeat digital sources if the Tape Monitor is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Okay, back to the hook-up:
Receiver Tape Out (Rec) - to the External Processor (EQ, whatever) Preamp-, Rec, Line-In;
Receiver Tape In (Play) - from the External Processor (EQ, whatever) Preamp-, Play , Line-Out.
So, to sum up, you can only use the EQ or any outboard processor for analog stereo sources. If you actually want to use an analog recording deck you could place it within the typical Equalizer
Feb 07, 2011 | Onkyo HTS3100 Theater System
I have an onkyo tx sr608 7.1 receiver and I want to hook up my yahama eq. I dont have a tape/monitor loop, how do I do it?
Actually the VCR/DVR is a Tape Loop that would support the EQ or any other audio processor..
http://www.retrevo.com/support/Onkyo-TX-SR608-Receivers-manual/id/23653ag916/t/2/
Be advised that the engagement of any device in a Tape Monitor loop will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose a STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Mon as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? That logical problem also plays into the decision to defeat digital sources if the Tape Mon is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Okay, back to the hook-up: Receiver Tape- or VCR Out to the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-In; Receiver Tape- or VCR In from the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-Out.
If you actually want to use an analog recording deck you could place it within the typical Equalizer's own Tape Monitor loop(s). Many have two to facilitate equalized dubbing between decks.
Dec 31, 2010 | Yamaha EQ-70 Home Equalizer
How to connect a turntable to Onkyo txsr 500
Just like most contemporary AV Receivers, there is no built-in Phono preamp in this unit so if your TT doesn't have one internally, you'll need to get an aftermarket Phono Preamp somewhere to PREamplify and frequency-balance the minute Phono Cartridge output to a useable Line Level you can send to any available Line Level input on the Receiver (CD, Aux, whatever) .
Feb 06, 2010 | Onkyo TX-SR500 Receiver
No HDMI Output
My configuration:
ZONE 1 (living room)
DishNetwork Dual Tuner DVR Tuner 1 [S-Video out] -> [S-Video in] ONKYO TX-SR875 [HDMI out] -> [HDMI in] Sony KDS-60A3000 rear projection TV
ZONE 2 (living room)
DishNetwork Dual Tuner DVR Tuner 2 [Composite Video out] -> [Composite Video in] ONKYO TX-SR875 [Composite Video out] -> [Composite Video in] Samsung AQUOS LCD TV
Problem:
ONKYO receiver stops sending video signal to my ZONE 1 Sony TV through the HDMI connection. ZONE 2 may still receive video. (NOTE: the issue might be related to the upconverter circuitry?)
Symptom:
I couldn't see any video, but I could hear the Tuner 1 audio through my ONKYO. An important clue is that I couldn't see ONKYO's on-screen display menu on my TV when hitting the [Setup] button on my remote. But, I could see my TV's Sony-based menus and display options.
Solution:
1. Put all ZONES in Standby mode using the remote. Hit these buttons on remote: [Receiver], then [Standby]. [Receiver], [ZONE2], then [Standby], [Receiver], [ZONE3], then [Standby]. You should NOT see any lights on the ONKYO except maybe one red led near the power button.
2. Pull the power plug out of the back of the ONKYO, and leave unplugged for 20-30 seconds. Turning off any power center it is connected to isn't enough. You MUST unplug the power from the back of the ONKYO for 20-30 seconds.
3. Reconnect the power cord to the ONKYO.
4. Using the remote, set ZONE1 to a video source known to be working. If you don't see video, try leaving the power cord off for a longer period.
I know it sounds too simple to work, but that's what brought the video back for me the few times the video stopped displaying. Hope it works for you.
Jan 06, 2008 | Onkyo TX-SR875 Receiver
Mitsubishi HDMI connection trouble
I have the same issue with my 73". Rather then going over all of my connections and equipment I'll just say htat I feel your frustration. I have been on the phone with Mitsubishi directly and it appears as though they have a free software upgrade that should address this problem. If you call 1-800-332-2119 and press 4 in the menu you will get someone to help you. Be patient. They will make you go through all of the fixes that you have already tried. They will mail you a flash drive that goes right into the front USB port of your TV. I hope this is of help. Good luck.
ret4good
Jan 04, 2008 | Mitsubishi WD-73833 73" HDTV
No picture with vhs
Don't pass the video sample through the Onkio.. Use a second single RCA patch cord to go from vcr to TV... Use the same yellow out on the vcr that you're using now and send it directly to the yellow video input you're using on the TV..
Hope that's clear - I'm getting tired...
Bill
Dec 02, 2007 | RCA TruFlat 27F520T 27" TV
Sony BRAVIA KDL-40V3000 Television Logo
135 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
