Question about Dell Inspiron 6400 Notebook
Primary hard disk drive 0 not found
Hi I have a dell inspiron 5100 which i used as a music player it had thousands of songs on it, i never used internet on it. So it cant possibly be a virus.
When I start up it tells me
primary hard disk drive 0 not found
no bootable devices--strike F1 to retry boot, F2 for setup utility
What should i do i cant lose my data please! help
Thanks in advance
  • sixftgod Mar 21, 2009
    Hi I have a dell inspiron 5100 that someone gave me. When I start up it tells me
    I thought is was the drive so I bought new one but I get the same message. I was told that it may be the HDD controller but I have no idea how to get another one or install.
    Any ideas?
    Thanks in advance
  • 3,940 Answers
The first thing to try is removing and reseating the hard drive. Sometimes the drive just looses it's connection with the motherboard, reseating can resolve that.
If that doesn't work, you can get a 2.5 in USB hard drive enclosure, and see if you can read the drive in another system, and recover you files that way.
Most likely though is the hard drive has failed. If this has occurred, then your options are limited. You can contact a data recovery service, but that is expensive. Http://www.ontrack.com or http://www.drivesavers.com are a couple options. You can contact them and get an estimate of the cost if the other options do not work.
Posted on Jun 08, 2008
Dell laptop crashed
reset bios setting & select 1st boot hard disc.
May 30, 2012 | Dell Inspiron 5100 Notebook
Primary disk drive not found
Check the connection of your hard drive and make sure it's plugged properly On The Motherboard.
Is this a SATA drive? Has it ever operated properly? If worse comes to worse, you'll have to reload windows from scratch.
Nov 11, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
Dell inspiron 5150 primary hard drive disk 0 not found
You may find that either the cable is not connected properly or is faulty, or the worse case the mother board has problems (driver, chips, breakages)
May even be a power supply problem, as the power supply has many output points and different voltages that the HDD power out may have blown. If it has then the rest of the system will appear to be ok.
So first off, check the cables connections on the motherboard, and look for any breaks in the cables, and if you have a power meter of some sort check the power connection, or plug in another power connector, the ones with the same end are generally the same power outputs. The ribbon cable for the HDD should have 2 sockets for HDDs and you must connect your HDD to the end one.
May 14, 2009 | Dell (U0614) for Inspiron 5150 60 GB Hard...
I but a dell d600 latitud 60 hdd and 512mb,using it up to a month pluse it was tell me 0 primary hard drive not.
I assume you meant "primary hard disk drive 0 not found"? Have you pressed F12 during bootup and run the HD diagnostics? If you can't run the diags and it does not show up in the BIOS, then you have a bad hard drive.
I've seen this error many, many times on D600s.
Dec 20, 2008 | Dell Latitude D600 Notebook
Hi Kenneth,
If you just bought the laptop, then it is still covered by a warranty. Then all you have to do is contact the seller or directly to dell. This is the fastest and most appropriate way, and usually you will get one-to-one replacement (they will replace your laptop with new one). But, please make sure by contacting Dell.
Regards,
dC
Dec 12, 2008 | Dell Latitude D600 Notebook
Laptop won't boot..
try new hard drive 1st ok
Jan 30, 2008 | Dell Inspiron 8500 Notebook
Dell Inspiron 6400 Notebook Logo
1,049 people viewed this question
Alun Cox
