Western Digital WD2500JS 250GB SATA2 7200rpm 8MB 250 GB SATA II Hard Drive Logo
Posted on Oct 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello sir, i recovered some imported data from my corrupted hard disk (WD2500js) but after that i could not install the windows on it. I have partitioned it three times but didn't affect. i think i need a disk manager for this hard disk so that disk manager adjust the internal settings on default of the hard disk!!! What do you suggest??
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Oct 26, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557375
Points
31058
I think that your disk-drive is about to "die", and the symptom of not being able to install Windows (which tries to write many files onto the disk) is a strong indicator.
Is the drive still under warranty? If so, W.D. will give you a free replacement. If not, W.D. has a 'Customer Loyalty' program -- buy a new disk-drive from their web-site, and get a discount.
2answers
A notification stating HDD is to fail. where do I have this repaired or replaced? thanks,
maybe you HDD system is corrupted, try to recover it if your can....
otherwise,back up your important files and format,re-install new system software..
Won't boot in safe mode or reinstall windows vista. Failed a hard drive test by seagate.
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will automatically fix any corrupt files on your hard drive or
go to control panel administrive tools computer management you can right click on the drive select properties tools check now?tick in both boxes to scan for and repair/recover any bad sectors and automaticall fix any corrupt files
in xp
hope this helps
1helpful
3answers
Corrupted data and folder showing empty.
i just used the scanning process from its property and then got the backup by windows from the properties of hard disk.After doing this all the folders were working.
15helpful
7answers
Data recovery from corrupt external hard drive
Well, in your case you should format the external drive and then try some so-called data recovery software.
First of ALL - Connect your hard drive to your personal computer. And install this software Wondershare Data Recovery on the computer in order to perform data recovery. Get the program from its site.
data recovery (for Windows OS)
Mac data recovery (for Mac OS X)
Good luck. I hope that my reply has shed some light on the problem!
Top Western Digital Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Paul Bade
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
