Question about Biostar P4M80-M4 Motherboard
Dvd-rom not installed but not working
Problem with cd rom and dvd drive installed but won't work, shows up in device manager with a yellow dot
  • 10 Answers
Right click on cd rom device with yellow mark and click on uninstall. after that cd rom device is deleted from device list.now right click on Home and click scan for hardware changes.now you got driver installation for your cd rom.if not restart yopur system you will get driver installation.
Posted on Jun 09, 2008
My dvd rom is not working becouse an error in driver HPDVDRAM GS30
Optical drives are more forgiving.
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install.
Dec 12, 2012 | HEWLETT-PACKARD HP ENVY 15 Series Notebook...
My dvd rom is not showing in My Computer
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Aug 18, 2012 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
DVD FUNCTION WON'T WORK, what should i do?
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
Nov 11, 2011 | LG CRN 8245B (CRN-8245B) Internal 24x...
Cd/dvd is not working saying no drivers installed
click start control panel administrive tools,computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver
hope this helps
Apr 17, 2011 | Acer (99.B0311.002) Internal 50x CD-ROM...
Dvd does not work. Light blinks but not seeing it . is there a driver i need or what do i do to fix this
You must determine if the problem is the media you are using (CD, DVD) or the drive itself. (CD/DVD Rom)
First see if the driver is installed for the CD/DVD ROM by Right clicking My Computer and choosing Properties, Hardware, Device Manager. Clikc the plus sign next to DVD/CD Rom Drives to see if there is a yellow exclamation point, or question mark. This means you need to install the correct driver. If there are no yellow exclamation marks or question marks your driver is installed properly.
Next try playing difffernt CD's to see if any of them work. Confirm they are good CD's by playing them on another device, then try them on your Compaq. If the Cd's play on another device you may possibly be experiencing read errors on the CD/DVD Rom drive. Try using a CD Laser Cleaner that will clean the laser head of the CD /DVD Rom. it looks like a CD with small brushes on the music side. This may solve a read error problem. if that does not solve your problem you may need to replace the CD/DVD Rom drive.
Jun 14, 2009 | Compaq Presario Notebook
DVD/CD-ROM PROBLEM
The yellow exclamation mark means that the driver for the DVD/CD-ROM is corrupted. You will need to find the drivers for your drive and re-install it. This should be easy enough to do: find the brand name of your drive and go to the website of the manufacturer, then locate their drivers page and find the specific driver for your product, then download and install the driver and restart your computer and the drive should work.
Please rate if this works for you, Thanks!
Mar 10, 2009 | Microsoft Windows Vista Home Basic for PC
CD Rom and DVD Rom won't work
you need to delete lower and upper filters from registry to fix the problem instructions CLICK HERE
Dec 28, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
DVD DRIVE/CD-WRITER
GO TO CONTROL PANNEL
SYSTEMS
HARDWARE
DEVICE MANAGER
CLICK DEVICE MANAGER(WINDOW)
EXPAND CD /DVD ROM DRIVES
RIGHT CLICK ON SELECTED DVD/CD DRIVE
SELECT PROPERTIES
1.SELCT DRIVER ( CLICK UPDATE DRIVER)
2.CHECK DVD REGION CODE.
3.UN-INSTALL DRIVER
4. REINSTALL DRIVER AGAIN(AFTER STEP 3)
OR
IN DEVICE MANAGER RIGHT CLIVK DVDCD ROM DRIVE
UN-INSTALL DRIVER
OK
REBOOT COMPUTER
ADD HARDWARE(CONTROL PANNEL)
IT WILL PROPMPT FOR INSTALLATION OF DRIVER
SAY OK.
PROCEED WITH WINDOW INSTRUCTIONS
DVD/CD ROM DRIVER WILL GET INSTALLED AFRESH.
HOPE IT WORKS.
Jul 01, 2008 | Computers & Internet
DVD works but not regular CD ROM
try frimware update for it from site ok pioneer.com ok
Feb 07, 2008 | Pioneer DVR-110D DVD RW Dual Layer Burner
Biostar P4M80-M4 Motherboard Logo
64 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
