Question about E-Machines eMachines Desktop PC
E-machine wont start comp
States warning!usb overcurrent computer shutting down. what happened?
  • 106 Answers
If this is a new motherboard, make sure the little tabs sticking from the back of the face plate are not inserted into the usb ports. I would also check the onboard USB ports (9 pin connectors with USB1, USB2 etc.. printed by them). Take the front panel cables off incase if you've connected them the incorrect way.
Posted on Jun 15, 2008
    Sergeant:
    Champion:
  • 326 Answers
Either the usb is shorted or a device is shorted. U can unplug the usb devices one at a time and reboot to find it or U can open the pc up and unplug the usb connections to the mb. If all the devices R unplugged and it still does it, then it's repair shop time or replacement time.
Posted on Jun 08, 2008
How do I reboot my Toshiba Satellite C55 without a
If your recovery partition has not been deleted you might be able to do it. See if you can access recovery mode
  1. Make sure the computer is turned off ("Shut-down" from the Windows Start menu)
  2. Remove any peripherals such an external mouse, keyboard, monitor, USB flash drive etc.
  3. Make sure the AC Adapter is plugged in and working.
  4. On machines with the F key numbers on the top edge of the keys and in White:
    • Press and hold the 0 (zero) key and power up the laptop.
    • Release the 0 (zero) key when the recovery warning screen appears.
    On machines with the F key numbers on the bottom edge of the keys and in Gray:
    • Power up the laptop.
    • When the initial TOSHIBA screen displays, press the F12 key to enter the boot menu.
    • Use the arrow keys to select the HDD Recovery option and press the enter key to begin.
  5. The TOSHIBA recovery wizard warning screen appears stating that when the recovery is executed all data will be deleted and the original factory software image will be rewritten. If the recovery process offers a choice of Operating Systems, select the appropriate one for you.
  6. After you are sure you have everything you want from the laptop saved, click Yes.
  7. When the Toshiba Recovery Wizard opens, the default and recommended option is "Recovery of Factory Default Software".
  8. After selecting your desired recovery method, select Next.
  9. On the next screen you may have recovery method options. The default and recommended method is to Recover to Out of Box state.
  10. Select next to continue.
Oct 18, 2014 | Computers & Internet
My powered USB port on my Dell Latitude D410 shorted out. Can this be repaired/replaced?
The USB plug will need to be removed from the computer, if luck is with you the computer will work, if no part is available, use a none powered USB hub on a spare port if available to run your applications.
Jun 23, 2012 | Dell Latitude D410 Notebook
Hello-i have 2 problems with my lexmark 2600 1-printer is only 4 months old. it is always telling me that there is no communication.,i plug and unplug, restart machine, it dosent always work. 2- after...
Hello. Unplug the usb cable from the computer. Reboot the computer. Remove the power supply off the printer. The power supply is the black box behind the printer where the power cord is plugged in to. Reinsert the power supply after 10-15 seconds. When the printer's ready, plug the usb cable back to the computer. Good luck!
Mar 24, 2010 | Lexmark X2600 InkJet Printer
My laptop will not go past the initial starting up screen that flashes HP Invent on the bottom it states: Press escape to go to the startup menu.. if you press escape, nothing happens.. I have left it on...
Power drain would be a better solution in this case. 1.first shut down the comp 2.unplug the charger 3. remove the battery and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Jan 11, 2010 | HP Pavilion dv7-2180us (NV022UA) PC...
Warning "not optimum settings"
Press F8 as the computer boots up and the Windows Advance Options Menu will be displayed. Then select Safe Mode to boot up the computer.
When Windows finishes booting up, then open Control Panel - select Display - Settings, then change the screen resolution to a lower setting.
Apply and shut down and reboot computer.
Dec 19, 2009 | Samsung SyncMaster 912N 19" Flat Panel LCD...
USB wont connect garmin to comp
usb doesn't need to be connected to both inputs just try one or the other
Jan 13, 2009 | Garmin nuvi 250 GPS Receiver
E-machine computer will not shut down
your files might have been corrupted i know the end close screen file sometimes and will get corrupted quicker than startup screen
now the question is was this the floor model or a straight out of the box unopened comp cause floor models always needs to be reformated those are the show comps. people play with those all day once you reform. comp. and put in new O.s. system everything should come back to working perfectly and dont forget spyware checkers and virus blockers name branded backed up these will help protect your comp
simple other solution might be you just need to upgrade your system files threw windows update
May 07, 2008 | Nexus Prolong:Extra Cooling after PC shut...
Wont power down after shutdown
your operating system is screwed up,backup your files and reinstall with the restore disk/repair ,good luck
Nov 26, 2007 | E-Machines EMA IMPERIAL GV (845GV) TG3...
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
