Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Refrig When it is hot in the house it does not operate properly I was wondering what temp. would have to be maintained while im out?
  • 828 Answers
You may want to check the condenser for cleanliness of dust and dirt. The condenser is normally located in back behind a removable panel. Be sure to reinstall the panel after cleaning the condenser. It is necessary for proper cooling of the refrigerator system.
If you are living in a hot climate turning your A/C system off while you are out just gives a higher heat load to recover when you come home.
Posted on Jun 08, 2008
I have a Whirlpool mod. ED5LHEXD00 refrig. I left home for 3 weeks in Dec. with the house temp. set to 50 deg. F. I got home and discovered that the refrig./freezer was at room temp and all the food had...
If Fridge working fine now, the problem may be is Hydro Grid.
When the fridge just start, the compressor is running with high pressure of Freon. If Hydro power has voltage surge or power Off/On ( suddenly ), the compressor should be stuck, the overheat protection switch will actived, than fridge will stop working.
The noice of "click" - properly is overheat switch auto-reset.
May 28, 2017 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
55 plate Ford Ka, heater only blows hot
Check the temp dial, the potentiometer may be faulty
Nov 09, 2017 | Ford Cars & Trucks
I have a profile refrigerator PDS20SCPARSS, SN TF047061. If youopen the door alot ( 4 kids) te refrigerator temp goes all the way to 60deg and the freezer goes to -30. If you don't open the door at all the...
If this is struggling to maintain temperature like this, either the system is low on gas (motor running all the time) or the fan has stopped which you should be able to hear. Make sure that the fan is not just jammed.also check the return air vent in the fridge as if this gets stuck with a spillage ie O.J. etc, the fridge cannot get air from the freezer and the freezer runs continually (-30) but the thermostat never cuts out in the fridge. Last idea most likely.
Dec 10, 2009 | GE Profile PSW26P Stainless Steel Side by...
Freezer and refridgerator are not maintaining cold temp. Compressor is Hot?? what can i do.unit is less than 3yrs old
Try cleaning condenser. Also check if there is a condenser fan and if so is it operating properly.
Good Luck,
Gilsh
Nov 26, 2009 | Kenmore 64802 Top Freezer Refrigerator
Light and temperature indicator on refregirator do no operate. Wife heard a pop when she opened refrig. door.
If the refrig light AND the temp adjustment knob lights , went out , you need to replace the electronic board . Pt # W10135090 . This part is located behind the refrig , at the bottom left , with 2 screws , inside a white box . The board runs about $ 80.00 , and is easily replaceable .
Nov 22, 2009 | Whirlpool GS6SHEXNS Side by Side...
I would like to use the frig Model# FRU17B2JW for wine storage
ok im at a loss as to why you would want a refer at this temp. but i will tell you no, this unit cannot maintain that high a temp. it can be tricked into it
but that involves odd wiring and changes in the baffel; system
at the risk of a bad rating i am sorry to be the bearer of bad news
Oct 25, 2009 | Frigidaire FRU17B2JW Refrigerator
Runs constantly to maintain 40 degrees, requires highest setting
Not sure how old it may be, but you can check a few things to see if it's defrosting properly. Also clean the condenser coils under the refrigerator to insure good circulation of air over coils. In the picture below you will need to check out three things until we find the problem. Defrost timer, defrost heater, and defrost thermostat. Let me know when your ready, Sea Breeze
seabreezehvac@yahoo.com
Apr 20, 2009 | Refrigerators
My refrigerator is hot
IM NOT UNDERSTANDING YOU PROPERLY IS THE FOOD IN THE REFRIG STAYING COLD.PLEASE GIVE MORE DETAILS ON YOUR PROBLEM AND NO THE LIGHT BULB WILL NOT CAUSE THAT.MOHAMED
Sep 16, 2008 | Whirlpool ED2FHEXN Side by Side...
GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Mar 30, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Gsh25vgpccc ge side by siderefrigerator
well if you keep that damper open im sure everything in your refrig- will freeze is the temp- in the freezer o.k. if you have an ice maker is it working properly because if your freezer does not maintain the right temp your ice maker wont work. if so you might have a bad temp control (thermostat)
Dec 23, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
42 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
