Question about Dell PowerEdge 1750 Server
NO POWER TO FLOPPY OR CD ROM NOTHING FROM THE GRAPHIC CARD
IS A PROBLEM WITH POWER SUPPLY, ALL FANS COME ON.
  • 2 more comments
  • Anonymous Jun 11, 2008
    HI THERE, PROBLEM WITH MY 1750 SERVER, no power to cd or floppy or hard drive(scsi) all these item are connected to the scsi backplane board connector.The fans are ok, when i switch the server on the fans comes on they seem loud but after about 22sec the speed cut down,and the blue light switch to amber(flashing) the power supply has three(3) indicator- 2 green 1 red, the red one does not come on, i took the memory out same problem
    cpu same problem, took one power supply out switch them arround try one
    at a time same thing i even took the scsi backplane board out same thing, they are nine(9) indicator, three for each drive on the, scsi backplane board
    connector none comes on,no post nothing on the monitor, no signal to key
    board but on the mother board all the indictor lights come on,nothing gets
    hot on the mother board no smell power supply not overheating.(CONFUSED)
  • Graham Waddilove
    Graham Waddilove Aug 09, 2008
    I am having trouble/issues getting any sort of boot (to BIOS) or picture on the monitor.
    When I switch it on it starts but without any error indications or beeps but does not startup the monitor from sleep mode, I have tried several monitors, leads, etc to no avail.
    I have tried re-seating the memory and putting in only 2 sets at a time to see if it was/is a memory issue but to no avail.
    Thinking I was a bit silly for not plugging 2 power leads in (seeing as there was only 1 PSU) I tried doing so; I have also tried swapping the PSU from one place to the other; slot PSU1 to slot PSU2, still same. The indicators on the PSU shows 2 greens NO red.
    On switching the Server on the fans start (I'll say FULL speed) then after about +/-10/15 secs slowed down to (I'll say half speed) and the amber light starts flashing. (great but what is the error?)
    The HDD(s), FDD, CDD and the Keyboard indicator lights do not flash on as they normally would during a boot, I do not get to a BIOS setup screen, as the monitor does not start. (see above)
    It does this every start. To get it to start "Full Speed" again I have to remove power then re-apply.
    I am new to this and any help would be great as this issue is driving me crazy.
  • Graham Waddilove
  • ODoyal May 11, 2010
    Could you be more specific about the problem?
You need to list the problem in detail.
e.g. when you turn on , what do you see.
when does it stop.
do the lights come on
does the floppy or cd rom run
etc.,
without all these it is difficult to conclude on the possible malady.
it is same as going to the doctors and just sayint "I am unwell" and not providing what the problem is .
Good luck
David
Posted on Jun 11, 2008
Everything was disconnected from my motherboard and power supply. It is an Asus K8V-MX/s
You will get all the required stuff as i have viewed and confirmed, from this source.
http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8V-MX/E2335_K8V-MX_h.pdf
best of luck!
Mar 11, 2012 | ASUS K8V-MX Motherboard
Howe to connect the power cabel to my new graphic card
Firstly, you need to have a power supply that meets the power (Watts) and current (Amps) of your card. Check your video card's documentation to verify this, and look for a sticker on your power supply to give you more information about your power supply's Wattage and Amperage ratings.
Next, if your video card needs additional power (it will have a molex 4 pin (like a floppy drive uses), or a 4 or 6 pin PCI Express Power plug. In case your power supply does not provide you with this type of power connector, many video cards include a 4 pin Molex to PCIE adapter. Again, make sure you meet the power requirements for your card, or it will likely die prematurely due to under-current conditions.
If you are using an adapter, plug a hard drive or CD-ROM drive power connector in on one side and to the video card on the other.
IF your power supply provides the correct power connector, use that one side goes to the power supply, and the other to the video card.
(It's less hinky that way, and I think it gets it off the same circuit with the other devices.
Good Luck!
Jan 27, 2012 | Computers & Internet
I have an ATI radeon X1300 Low Profile 256mg PCIe graphic card for my Dell Optplex 620 (SFF) computer. I'm wondering about the power draw. The computer has only a 240 watt power supply. Will this tax...
Your computer should be able to handle the graphics card with no problem.
The only issue that comes up is how many hard drives or CD Rom drives are attached to the system.
If everything is stock out-of-the-box, you are OK.
I hope that this helps.
asnowman
Mar 05, 2011 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
Why does my computer swith on but not boot up
try getting a new graphics card or when it turns on try resetting it a few times.
Aug 20, 2009 | Compaq D51S 1.6GHz Desktop XP Computer
Asus p5s800-vm MB has complete power lets monitor know
Disconnect the hard drives, cd/dvd drives and any expansion boards you have plugged into the mainboard. We want to remove as much as possible to see if we can eliminate the problem.Using the onboard video, start it up again, and see if it comes up. If it does, then its one of the items you disconnected. Power down and reattach one of the disconnected items and power up again. Did it come up? Keep in mind that we want to see the bios start up screen. Once you have attached all the items you will have found the bad component. Replace it. But lets say you didn't get a good system when you disconnected everything. Well, that narrows down the suspected bad items to: the mainboard, the power supply, the memory, or the cpu. The power supply has many voltages coming out of it, keep in mind that the drives, cd/dvd rom drives and fans use 12 volts for spin up. There are 3 other voltages used by the mainboard. I would replace the power supply next with a known good one. Then it gets a little costlier, the memory, then the cpu and then the mainboard. Stick with it. You'll find out which it is. Good Luck.
May 21, 2009 | ASUS P5S800-VM Motherboard
No video
Go to the Asus website and download the drivers for this board. It's most likely that it did not come with drivers installed. Hopefully this will fix the problem. Good luck.
Dec 23, 2008 | ASUS P4V8X-MX Motherboard
Wont send power to screen or keypad/mouse
Try Reseating the RAM/ try with another working RAM. Before this remove all peripherals like HDD, CD-ROMs, Floppy Drives. Check with another Power Supply,
Jun 21, 2008 | Intel Motherboard
Hey anyone can help me with some info
Well it will not hurt you're board if that's what you want to know. Depends what devices you have plugged into the board. If you're running 4 serial ATA SATA's. Two CD/DVD drives. A floppy drive & an AGP 8x graphics card. The 400w should do just fine. (You can never run too high a PSU source).
I'm running 4 serial ATA 7200rpm SATA's, 2 DVD-ROM's, a floppy drive. 1 PCI-E graphics card. Four, 4" case fans. Skt 939 Dual core 4200+ CPU & my 550w has been stable for over 2 years.
Have a great weekend!
Mike
May 30, 2008 | Abit A17 Guru Motherboard
Replacement Video Card - Dell 8200 w/ NV25
I have a couple of graphics cards that will do the trick. Email me back and I will help you out.
May 14, 2008 | Computers & Internet
Is the 350 watt power supply ok for EVGA 6800 128 mb agp card ?
I would suggest at least a 400 watt power supply as the amount of peripherals you are running will soon take up the 350 watt supply, but go for a 500w as the price difference is negligable.
Mar 20, 2007 | Evga e-GeForce 6800 (128 MB) Graphic Card
Dell PowerEdge 1750 Server Logo
243 people viewed this question
Alun Cox
