Question about Voyetra Turtle Beach Turtle Beach Ear Force X1 Headphones
Xbox360 hi my x box 360 has benn in storage for a while now, recently went to set it up and for some reason the disc tray will not open. there is a chance that a disc may have been left inside. please help. thanks
When you press the eject button, lightly smack the top above the tray, the tray should open and the loading belt will be visible
you should change it or try cleaning it with alcohol for a short term solution
Posted on Jun 14, 2008
I've tryed putting xbox360 games in a xbox360 but it sais open tray
The XBox 360 is a wonderful video game console, however, with heavy usage, the laser (and/or other components in the drive) will eventually burn out. The first signs of the laser starting to burn out is that your game will start freezing during game play. Eventually the games will stop reading altogether and you will get an "OPEN TRAY" message when you put a disc in and close the tray. What this means is that the XBox 360 thinks that there is no disc in the system.
You can find more information about this issue, find parts to repair it, or send your system to repair all at the following website:
http://store.richspsxparts.com/howtofixxb36.html
Jun 21, 2011 | Video Game Consoles & Games
My xbox360 won't read disc's it just says open tray
I learned this from a Youtube video and this did the trick for me. Hopefully, it will solve it for your X-Box 360 too! 1. Put disc into X-Box 360. 2. Turn X-Box 360 off. 3. Open tray. 4. Take disc out. 5. Slam Tray 6. Turn off X-Box 360 (Immediately after slamming the tray shut) 7. Turn on X-Box 360 _______________________________________________________ Your dvd drive probably has a bad motor. There are three motors inthere. One moves the tray. One moves the laser and another spins theDVD. If the tray ejects than that motor is fine. If you hear the discspinning then that motor is fine. Take the top off the dvd drive andsee it the laser moves when you close the tray it should move slightlythe laser should bob up and down and light up if none of that happensyou have a bad laser drive motor or bad laser. The solution is to buy agood DVD drive the same as your make and change the pcb boards (thecircuit board in the DVD drive) make sure yor pcb stays with yourconsole as the motherboard and pcb are keyed together.
Apr 10, 2010 | Microsoft Xbox 360 Console
I put a game in and it kicks it right back out
Hi
The problem you are facing is possibly due to a white lever near the dvd tray that is out of alignment, how do you align your console while playing Horizontal or vertical ?
try changing console position and check if it makes any difference, do not try experimenting much if your console is under MS support warranty, send it straight away for repairs they would replace the dvd drive for you
Nov 24, 2009 | Microsoft Xbox 360 Console
Xbox360 disc drive
Hi, it sounds like you have the" open tray" error that is very common with the 360s. How you fix this is you take your DVD drive apart and look at the laser assembly, there are 2 screws on the side of it, look at the one on the left. Turn this screw to the left a VERY little bit at a time and keep checking it every time you turn it until it stops the open tray error.
Aug 17, 2009 | Microsoft Xbox 360 Console
Old xbox360 disc tray wont close at all
open it up ( very carefully) and check to see if the disk tray end is still attached or alligned to the plastic gears that eject the tray. if so check the rubber band to make sure it has not broke or streched.
Jun 25, 2009 | Microsoft Xbox 360 Console
Xbox360/must open & close tray 5 to 10 times before game opens.
This is an indication that your disc tray / the lens on the tray is not working properly.
What i suggest is to call xbox customer support to have your xbox serviced. Good Luck! hope your console still has warranty
Apr 04, 2009 | Microsoft Xbox 360 Console
Help
Try putting the game in straight. By straight i mean putting the disc in where the xbox 360 logo at the top of the disc goes in the tray towards the xbox360. if that does not work contact microsoft
Mar 16, 2009 | Microsoft Xbox 360 Console
XBox360 won't play games
Well I just recently purchased an XBOX 360 about a month ago form gamestation(used). It was giving me disc read errors every time iplayed it, but i opened it up and cleaned my TOSHIBA drive and wiped everything down with a cotton bud, and then lubed up all of the parts which needed to be.
and that fixed my problem
please rate
Dec 17, 2008 | Microsoft Xbox 360 Console
Disc Tray Problem
That is how the X-Box works. It doesn't stay open, because if it stood open and it accidently dropped or anything, the drawer would break, and that would cause alot of problems with Microsoft. Thanks for using Fixya!
Jul 11, 2008 | Microsoft Xbox 360 Console
Xbox360
no the eye is either dirty or broken did you get it wet or did it fall off something
Mar 15, 2008 | Microsoft Xbox 360 Console
Open Questions:
Voyetra Turtle Beach Turtle Beach Ear Force X1 Headphones Logo
37 people viewed this question
Top Voyetra Turtle Beach Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Voyetra Turtle Beach Audio Player and Recorder Expert? Answer questions, earn points and help others
