Question about Akai Televison & Video
My akai ct-t349e3a tv the picture is very bright,and i cant lower the brightness at all
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 92 Answers
There are internal adjustments that may help or you could have component failure. Either way you should consult a qualified servicer. You should not pay more than 50.00 for service call and if just alignment, maybe 100.00 total. If there is parts failure, you could see a bill in excess of 2-300.00
Craig Cleveland Classic TV www.classtorations.com
Posted on Jun 08, 2008
AKAI Colour Television CT-1419A/AT plus AKAI remote RC-V9A. Television was fine, then went to just a narrow, bright horizontal band across the screen but sound is fine. Suspect my son played with the...
hi,
Its not problem with any setting. Its an internal fault. Vertical scanning output stage has failed in your tv. You have to check the soldering of the vrtical output ic if there is any dry soldering this can happen. try to resoder all the points in the vrtical output stage. IF doesn't help then you have to change the vertical output ic. Have added the picture of the dry soldering point how it looks like. If you need further assistance feel free to contact throug FixYa.
Aug 20, 2011 | Akai Televison & Video
AKAI PT50DL14X\SMS - LAMP INDICATOR (GREEN)
AKAI PT50DL14XSMS - LAMP INDICATOR (GREEN) FLASHES ABOUT 20 TIMES - CAN HEAR FAN RUNNING AND LOOKING THRU LAMP GRILLES CAN SEE BRIGHT BULB LITE - NO PICTURE COMES ON - AFTER ABOUT 30 SECONDS EVRYTHING SHUTS DOWN
Nov 02, 2009 | Akai PT50DL24 Television
Picture too dark
Hi kseguin
Your TV has internal problem @ video stage on the circuit
But you may try to apply resoldering on the circuit board near flyback and CRT circuit board.
Apr 14, 2009 | Panasonic CT-34WX52 34" TV
Xbox360 picture is too bright
I just had this same issue when i bought an Xbox 360 a week ago or so. Everything was WAY too bright but only on the Xbox. After some checking and rearranging of cords i found that the RF Modulator (adapter) i was using was set to the wrong resistance (Ohms) as i plugged in the Wii and had the same issue. I would say check the resistance setting and channel on the adapter, also making sure to NOT use "Y" rca cables to have more than one thing plugged into the same input.
Hope this helps ^_^.
Apr 10, 2009 | Microsoft Xbox 360 Elite Console
Brightness on my tv quit workin
open your tv.At the back you see a plyback,it is big parts of tv with a wire attached to the picture tube,that is plyback At the buttom you wiil see a two knob, the lower knob is for the screen and the upper knob is for the focus.Adjust the lower knob or screen .
Nov 16, 2008 | Toshiba 36A42 36" TV
Picture washed out, can't get it right
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Sep 21, 2008 | Akai LCT2715 27 in. LCD Television
AKAI CT 2112
This is a typical power supply problem. Please check the B+ Power Supply that goes to the LOT (FBT). It should be 110V. If that is ok, check the voltage while increasing and decreasing brightness, sound. If there is variation, the problem is in the SMPS. Look for dry capacitors, open/high value resistors, zener diodes, transistors etc. If nothing works, please download a data-sheet of the IC and check voltages at the pins and locate the adjacent components. Even a dry capacitor in the power supply can decrease the votage at load
Mar 30, 2008 | Akai LCT2662 Television
Panasonic ctp2780sf Picture very dark
check the ABL at the flyback and solder any bad connections there. U can increase the brightness at the flybacks buttom control .
Dec 29, 2006 | Panasonic CT-27SF25 27" TV
Televison & Video Logo
186 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
