QS8 keyboard. Why is volume in organ mode much louder than piano mode when I switch between modes without touching volume slide?
On organ mode, in general, almost all brands of the modern keyboard, velocity setting is not enabled. Setting velocity is used to determine how much the level of the sound that follows how strongly you press the keys. It is really just to imitate the sound of vintage organs, which in the past, electronic organ technologi not use the velocity on the keys. So, how strong / slow we press the keys, the sound level will remain the same.
At the Piano mode,modern keyboard using setting velocity. This also to imitate an acoustic piano, which, if we press the keys slowly, the sound level will be slow as well, and vice versa.
So, in your case,at the same volume slider, try to play on the organ modes, note level. Moving to the piano mode and press the keys securely powered (full power). Then the sound level should be equal to the organ mode.
On modern keyboards, also included organ sound that added velocity setting. Usually found on the user bank.
