Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
Error ,unmountable_boot_volume Hi , when i start up my pc it says , unmountable_boot_volume , ive tried safe mode and last known good configuration but it keeps going back to this screen . its windows xp home , i got no boot disc with it , the pc is a good few years old , hope u can help me , thanks , raymond
  • 49 Answers
Your out of luck with that one. You need a disk.
Posted on Jun 08, 2008
Pc powers up then shuts down
The processsor needs to be changed
Aug 25, 2014 | HP Pavilion a6110n PC Desktop
My acer aspire one wont come off the 'Setup is starting services' screen. After a while a message will come up saying it cant complete because windows isnt installed. Then it restarts the laptop and does...
The error is in your Operating System or your last Installed Application.
you should do this first.
1.Try boot the computer in Last known good configuration to go back to the earlier configuration when it worked fine.
Keep tapping f8 key when you restart the computer, from the advanced options, select Last known good configuration .
2. Reformat your PC this was the best Solution
Aug 21, 2013 | Acer Aspire Computers & Internet
Starts up until welcome screen, then goes black
Try Last Known Good Configuration. From shutdown turn the computer on and as soon as you see the DELL logo start tapping F8. Advance Boot Options will appear and then use the up or down arrow keys to go to Last Known Good Configuration and press Enter.
If that does not work:
Try booting to safe mode. After powering the computer up when you see the DELL logo start tapping F8 from your keyboard and then choose "Safe Mode" or "Safe Mode with Networking" if you're able to boot up successfully go to Start-> All Programs-> Accessories-> System Tools and then System Restore.
Restore your computer to a date when it was working.
Hope you found this helpful!
Apr 19, 2011 | Dell Latitude D505 Notebook
Received 512 - chassis fan error on HP Compaq dc5100 ff - I replaced the front chassis fan after detecting fan was not working now when I attempt to log into windows - windows screen appears than...
By enforcing the option to return BACK TO THE LAST KNOWN GOOD CONFIGURATION you have nothing to lose. Respond if you have already selected that option with no success?
Bruce
Jan 12, 2011 | HP Computers & Internet
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Please select an option:
Safe Mode
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
WHAT TO DO IF MY SONY VAIO WON'T START?
Hi there.
Choose "LAST KNOWN GOOD CONFIGURATION" if it still won't boot up try "SAFE MODE" and perform a system restore and take the computer back a week or so.
Good luck and thanks for using FixYa!!
May 13, 2009 | Sony VAIO VGN-FJ270/B Notebook
Laptop Will Not Boot
chose start windows normaly
Apr 14, 2009 | Acer Aspire One PC Notebook
PC notebook will only start in safe mode.
Try doing a System Restore, once you have booted up in Safe Mode, to a time before you had the problem.
Hope this helps
Chris (ziraffa)
Jan 02, 2009 | Computers & Internet
Unmountable boot volume
Hi
It looks you have a bad hard drive. Have you tried changing it? If not, try it. Regards.
Nov 28, 2008 | Sony VAIO VGN-FJ270/B Notebook
Computer shut down ..wont restart
what has happened is your hard drive as failed and that is why it shut down and then gave the unmountable boot volume. You could try repairing windows using your XP cd but it's a new hard drive i recon.
Oct 05, 2007 | Compaq Presario M2000 Notebook
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
26 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
