Question about Olympus FE-210 Digital Camera
Problem with fe-210
When you turn the camera on, it beeps and then makes a ticking- type sound - almost like a cogs on a wheel mising each other.
Imi apare cand dau drumul cu niste liniute
Posted on Jun 19, 2008
  • 20 Answers
Lens gears are probably broken off, or other problem with lens. Will need to replace lens, or may possibly be repaired. I've repaired a few lenses with gears broken off, by replacing broken off posts with similar size plastic pieces(drilled holes and super glued in place, being very careful). Still working months after repaired. Olympus repair shops can replace anything needed, but at a HIGH price; sometimes cheaper to replace camera than to have them work on it.
Posted on Jun 15, 2008
On my Olympus FE-210 camera....It won't record sound. Is there a way I could do to get sound on it?
Unfortunately this camera model is not capable to record sound when in movie mode. The camera was not designed to support that type of functionality. There is no way to incorporate sound as the model was not designed with any audio output features.
Jan 18, 2009 | Olympus FE-210 Digital Camera
Digital camera won't take pic
HELLO NEWFIE,
YOUR CAMERA HAS A VERY COMMON PROBLEM THAT THE FE-210 HAS. YOU MUST PAINSTAKINGLY TAKE APART YOUR CAMERA PIECE BY PIECE. MAKE SURE TO CAREFULLY REMOVE THE SMALL SCREWS THAT ARE UNDER THE COVER PLATES FOR THE USB, VIDEO OUT AND DC INPUT SLOTS. ON THE RIBBON FOR THE FACE AND THE LCD, YOU MUST "LIFT UP" ON THE RIBBON LOCKS. SOME ARE BLACK AND LOOK LIKE A TAB AND SOME ARE WHITE AND LOOK LIKE A "PUSH IN" TYPE OF LOCK. THEY BOTH SWIVEL "UP", NOT PULL OUT!!! RETAIN THE WHITE LOCK AS IT WILL NEED TO BE PUT BACK IN THE SAME WAY. ONCE THE FRONT COVER IS OFF, REMOVE THE LCD THE SAME WAY. IT WILL HAVE 2 SCREWS IN OPP. CORNERS AND A RIBBON WITH A BLACK LOCK. ONCE THE LCD IS REMOVED, REMOVE THE MAIN BOARD BY REMOVING ALL OF THE SCREWS IN THE CORNERS AND THE ONES THAT HAVE "GOLD" AROUND THEM. THERE IS A SMALL SCREW UNDER THE DOOR FOR YOUR BATTERIES, DO NOT FORGET TO REMOVE THIS ONE ALSO. NOW, LIFT THE MAIN BOARD UP SO THAT YOU CAN SEE THE SMALL GOLD GEAR NEAR THE SHUTTER OPENING. TAKE A SMALL SCREW DRIVER, SUCH AS THE ONE YOU HAVE BEEN USING AND ROTATE THE GEAR. THIS WILL FIX YOUR PROB. NOW REVERSE THIS PROCESS AND YOU WILL BE UP AND SNAPPING.
Jan 15, 2009 | Olympus FE-210 Digital Camera
Olympus FE-210 White LCD screen
Sounds as if this is a repair issue with the image processing chip inside the camera. You may want to call Olympus Customer Service and discuss the repair process with them. Their telephone number is 800-622-6372 option 2 and then option 3
Dec 11, 2008 | Olympus FE-210 Digital Camera
No sound on video
with the fe 210 it dosent have sound in the video
Jul 09, 2008 | Olympus FE-210 Digital Camera
I dont know how to turn the sound on so that my videos have sound.
The problem lies in that the FE-210 is not equipt with a microphone for video with sound. FE-190, FE-230, many Stylus brands, and newer FE- models have microphone for sound.
Mar 22, 2008 | Olympus FE-210 Digital Camera
FE 170 OLYMPUS digital camera
its fucked up olympus sux i bought a sony cybershot 4000000 times better than that trash fe-210.
i trashed it destroyed it mutilated it till it begged for mercy
Dec 02, 2007 | Olympus FE-210 Digital Camera
My olympus Fe-210 wont record sound
This isn't a problem, the Fe-210 doesn't record audio and it was built this way.
Nov 05, 2007 | Olympus FE-210 Digital Camera
check the battery door and make sure it is making good connection with the batteries.
it is also suggested that you use lithium batteries with these type of devices
Oct 18, 2007 | Olympus FE-210 Digital Camera
Olympus FE-210 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
