I saw the AS2400 is compatible with Windows XP/2000/Vista.
You can install Windows XP in your computer (I presume you have a 4th Gen Intel processor installed in it) and run this software under Windows XP.
On the Windows 8.1 Help and Support, search: Windows XP
The AS2300 foot pedal RS23 or RS25 are not compatible with 64 bit operating systems. You will need an RS27 pedal, available at http://www.dictationmall.com/147-035.html
They will work with Windows 7 Professional or higher due to a built in "compatibility mode"
All you need to do is... upgrade to Windows 7 Professional. Right Click on the setup icon for the game. Go to properties. Look for compatibility mode. Run it in windows XP mode
First check it compatibility with windows7 before installing or downloading. Install windows7 upgrade utility that show how your hardware supported to windows7.
Unfortunately not all older printers and scanners are compatible with Windows 7 and manufacturers do not rush to produce new drivers for older equipment as they want you to buy a new one.
Hi, try this link at Del: http://support.euro.dell.com/support/downloads/driverslist.aspx?c=uk&cs=ukbsdt1&l=en&s=bsd&ServiceTag=&SystemID=LAT_PNT_P4_100L&os=WW1&osl=en&catid=&impid= But it seems there are only drivers upto XP; so have you upgraded your system to wndows 7 ?
HTML clipboard
Olympus AS-2000 is not Vista compatible, you need to upgrade your software,
I am not sure which version you have, but I think its version 6 ? You need
to upgrade your software from version 6 to 7 (free) and then from
version 7 to Standard (also free ) . check your foot pedal if it's RS-23 (
check the back of it ) then you need a new foot pedal ( RS-25 or RS-27 ) , if
you have the RS-25 or RS27 you are ok .
http://www.olympusamerica.com/cpg_section/software_results.asp?id=1219&os=w
Just hit the download button to download. Then to upload, select the file or files in the software, and drag to the dpm at the lower left. The 9750 will need to be in the download mode by pushing download first.
