Question about Biostar P4M80-M4 Motherboard
Ram problem I upgraded the ram from 256 to 512 and when I turned it on,I smell some burning fumes so I shut it down.After turning it on again hear 3 beeps continuously and nothing else.What is wrong and how can I fix this?
  • gagglefinish Jun 08, 2008
    I tried using the other ram slot and even the original ram module but I still here the 3 beeps.So what is the problem now.
One of my RAM slots arent work can someone help me please.
Posted on Jun 11, 2008
    President:
  • 2,712 Answers
You may have inserted the RAM wrongly, or the two modules are incompatible. The 3 beeps you hear indicates that RAM is not functioning properly.
Remove the RAM module that was recently inserted. Most likely the RAM slot is unusable now, as there was a short circuit at the slot.
Try using the RAM module on a different slot. Also make sure that that you have purchased the recommended type of RAM, ie DDR/DDR2, etc. for the slot.
It is always better to use a single RAM module, rather than 2 different modules from different companies..
Posted on Jun 08, 2008
  • Swilin Sampson
    Swilin Sampson Jun 08, 2008
    It looks like the circuitry from the RAM DIMM slots is defective. Unfortunately, if both slots are defective, your only solution is to replace the entire motherboard.
My gas stove seems to have what i would call a after burn
If it is just short final flare, it is probably just the gas still in the supply pipe to the burner. That last bit of gas will burn off rapidly right after the valve is turned off.
Jan 03, 2015 | Kenmore Kitchen Ranges
Upgrade BIOS to see if it will resolve hardware issue with new stick of RAM
Hi Szusza,
The new RAM module you purchased may be faulty, it is definitely possible that either due to a fault of the new RAM or on the slot you are trying to install it to cause the computer to not fully boot.
Have you tried to boot the computer with the new module only?
If not please try this:
Replace the original RAM module with the new one (make sure you insert the new RAM in the same slot you took the old one out)
If the PC boots you know the new RAM is fine.
If this does not work I would suggest getting your new RAM tested.
If it does work, put the original RAM back in the computer (in a new slot) if it does not boot after that then, there is possibly a problem with the RAM slot on the motherboard.
Dec 16, 2013 | HEWLETT-PACKARD Compaq Presario CQ5302F...
I need to unlock a iMac running OS 10.6.1
Step 1:
Turn off your iMac G5
Step 2:
Power it back on. Right when you hear the startup sound, hold down Command and S together. This will bring up a black and white terminal prompt.
Step 3:
If at this point, it asks for a password (firmware password), power back down the iMac, change the amount of RAM (remove one stick of RAM and leave the other in), turn the computer back on and when you hear the start up sound hold down Command + Option + P + R. Keep holding until it restarts again. Once it restarts again, let it boot up, then shut it down again and put the stick of RAM back in. This will reset the firmware password and should allow you to continue onto the next step.
Step 4:
Once you are successfully at the command prompt, type the following commands, pressing enter after each line.
mount -uw /
rm /var/db/.AppleSetupDone
shutdown -h now
Step 5:
That's it! Once you boot back up, you should have a brand new administrator account that you can use to access all files and remove other accounts.
Dec 25, 2012 | Apple iMac G5 Desktop
Add more ram
hi-
To add ram - look on the back of the lap top. You will see some screws that are holding down a little door. There may be two of these. Remove the screws on the ram cover and remove ram cover
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ram slots are stacked. you have to remove the top one first.
1- press the buttons on the sides of the ram chip, and then it will pop up and towards you.
2- 2- pull this ram upwards and out
3- from there, you can take out the other chip, if there is one, or you can start installing.
4- installing the new ram chips is just as easy
5- line up the slots in the chip, then push it in as far as you can without breaking it.
6- then push it down so that you hear it click on both sides, and doesn't budge.
7- Repeat using the top chip.
This should do it –
I hope it helps- please rate me – thanks
G
Mar 18, 2010 | Acer Aspire 9500 Notebook
No output at all
okay close laptop remove battery, open ram / memory compartment, remove memory. try holding down power button for 3 minutes. THEN INSTALL BATTERY , NOT RAM/ MEMORY AND PRESS POWER BUTTON AND IF YOU HEAR A SOUND THAT GOOD NEWS THE SCREEN MIGHT COME ON, OR IT MAY NOT, BUT YOU SHOULD HEAR A BEEP, IF POWER BUTTON REMAINS LIT HOLD DOWN TILL COMPUTER TURNS OFF, THEN INSERT MEMORY/ RAM AND FIRE IT UP. WORK THESE STEPS
Jun 02, 2009 | Dell Vostro 1500 Notebook
Compact presario v5000
remove your RAM from their slot then insert it again, hopefully this may solve your problem
Oct 16, 2008 | Compaq Presario 700 470024-192 Notebook
Prolem with DDR RAM 400
Hello, you might want to check hear http://www.crucial.com/ there is a good chance that you put the wrong type of ram in this computer.And it might need a new motherboard.
Oct 01, 2008 | Compaq Presario 5000 PC Desktop
Burning smell , Microwave not turning off
the control circuit shorted out from the cleaning session and kept the microwave on so long with nothing to cook that it has cooked itself I'm sorry to tell you. Probably not worth repairing
Dec 27, 2007 | Kenmore 62702 Microwave Oven
Burning smell from Microwave
If you clean any appliances always plug out the unit power supply do spray any liquid in the unit that can enter inside the control, instead just wipe it with rug not spray. In this situation you have to call for a qualified technician. Maybe there are some wires that burned or rust in the control that cause the short circuit inside the unit..
Dec 27, 2007 | Whirlpool MH7135XE Microwave Oven
Biostar P4M80-M4 Motherboard Logo
70 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
