Question about Maytag Neptune MDG5500AW Gas Dryer
Dryer keeps resetting
My dryer keeps resetting itself from sensor to wrinkle release and several beeps.i tried to unplug continues to do the same
  • 979 Answers
This may be a problem that only a repairman can fix. There may be an electronic board that has to be replaced.
Posted on Jan 14, 2009
MY DRYER DOES NOT STOP AT THE END OF THE CYCLE, THE BELL GOES OFF BUT DOES NOT STOP
if you have selected wrinkle release thats normal it will keep on going on just air not to let the clothing sit and get wrinkled
Jan 20, 2015 | Samsung DV431AE 7.4 cu. ft. Electric Steam...
Periodically, the display will change to the wrinkle release mode from sensor dry mode (all by itself), and the timer will show 18 minutes remaining. If I switch it back to sensor dry mode, the display...
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing, if that is fine the problem is either the door switch or the control board. Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | Maytag Neptune MCE8000AY Electric Dryer
My dryer panel is turning on by itself. when I shut it off, it turns back on after a while. A load of clothes is drying, and the dryer keeps making a beeping sound every now and again. It seems to be...
Many of your better dryers have an anti-wrinkle function. When a load is complete if you don't take care of it, every little while the dryer will turn on for a few minutes to fluff the clothes and beep to remind you.
May 31, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer will not stop running
Your machine may have a feature called wrinkle guard or wrinkle shield, which basically keeps tumbling the clothes without heat to prevent wrinkles from setting in. Turn that feature off and see if that does the trick.
May 15, 2010 | Frigidaire Electric Dryer
My LG dryer shuts itself off during the normal cycle and a dotted
OK, here's what it sounds like to me: The line going around the display should only be seen if you selected "Wrinkel Care" function for that cycle (and with the freshen up cycle, I beleive). With that option in use, after the dryer shuts off, if you do not open the door or turn off power to the dryer the dryer will display the moving rectangular segments and every 6 minutes the dryer will turn itself on and tumble for 10 seconds with no heat (to keep clothes fluffed up and prevent wrinkles from setting in) and will continue this cycle for up to three hours. The "Freshen Up" is the steam cycle used to remove wrinkles from 1 to 5 garments, like things that were all wrinkled up in your suitcase. Try drying with a normal or permanent press cycle, or a timed cycle. If you have additional questions or concerns, let me know.
Dec 06, 2008 | LG WM2077CW Laundry XL Front Load...
Maytag Neptune Dryer MDE5500AYW beeping and resetting itself
Ok , I replaced the control board. Still beeps continuously. Just sitting there, nothing else is on, just plugged in......beeep,beeeep,beeeeep,WTF man? I am about to turn this damn thing into an anchor and invest in more clothes lines! Maytag sucks. MAYTAG an acronym for...
Maybe
All
Your
Technicians
Agree;
Garbage...
May 16, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Switches to wrinkle release and changes to 18 on display.
Check the vent coming out the back. It may be plugged up not alowwing proper airflow. You might just unhook it for one load to see if that is the problem.
Apr 08, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Problem when drying gets to 1 minute mark
This is happening when you selected the wrinkle prevent option or you set it to wrinkle release cycle.what it does is it is tumbling with no heat to release the wrinkle in the clothing. This is normal.It could also be normal part of drying in "regular" cycle
May 29, 2007 | Maytag Neptune MDE6700A Electric Dryer
Timer problems
Yes it probably is but check the keypad also.It could have a short in it.
May 26, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
140 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
