Question about Dishwashers
Dishlex wont run
The dishwasher was started earlier but paused, now when we try to start it there is a humming noise. I have turned it off and tried to reset it to no avail please help me??
  • houseslave Jun 09, 2008
    Its more of a rumbling sound when it is turned on.
  • 790 Answers
Hello ,
You may need to call in a plumber the b/f said there might be a blockage in the outlet pipe, it maybe that it isn't displacing water via the outlet, try a dose of Drano check first that it is safe to do so its pretty corrosive before calling in the plumber.
Posted on Jun 09, 2008
    Genius:
  • 2,035 Answers
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Turning over but not starting
sounds like a faulty starter possibly the selinoide on the starter
Mar 03, 2014 | Kia Sephia Cars & Trucks
Dishlex dx 203 buzzer
solenoids that control water flow (taps) buzz when failing Check out the water in solenoid.
May 26, 2013 | Dishwashers
Dishwasher starts then pauses and drains.
Fixed! I had the issue where the cycle would start, the KUDS30IXBL8 would hum 4-5 times and then drain. Plastic folk pieces jammed in the disposer. These instructions took a few minutes (only 5 screws and a couple clips) to figure out how to take it apart, and it only took 60 seconds to put back together. How To Repair Dishwashers KitchenAid Repair Chopper Replacement
Apr 25, 2012 | KitchenAid Dishwashers
Dishwasher wont work
hi
Try to access the pump hose and remove blockage.If that does not fix the problem you will have to replace the drain pump.
Mar 28, 2010 | Dishwashers
My 06 Ford Fusion has trouble starting on these colder mornings. After 4 or 5 tries, it will fire and starts normally each time after.
When you put the key in, turn it to run and pause before turning it to start. Pause it until you hear a humming noise at the run position that stops. Then turn the key to start. What that does is allows the fuel pump to fill up your lines and make it a little easier to ignite. Also consider a new battery.
Dec 21, 2009 | 2006 Ford Fusion
Dishlex global 300. ECO light flashing.
if that fails then try emptying the over flow try found behind the kick panel below the door. 2 phillips screws will be found either side under plastic screw covers, behind kick panel you will find the cover for all internals remove a total of 6 screws from these covers, then with a torch you will see the internal workings of the machine. located at the bottom of it all is a small kidney shaped tray that may have some/alot of water. this is the over flow tray. empty by soaking up the liquid with a sponge. reassemble then try starting it.
Jan 16, 2009 | Dishwashers
Dishlex Global 2000 starts makes a constant noise tries to start up then stops. Bit of water in the bottom of the dishwasher. Lights flash but does nothing
have you checked that your outlet pipe is not blocked. if it is blocked machines are designed to stop to prevent flooding. this may explain why there is water in bottom
Sep 03, 2008 | Dishwashers
Dishlex global 300
try holding the start and program buttons simultaneously for a few seconds, it seemed to reset itself for me-i have done this a few times now.
Feb 04, 2008 | Dishwashers
Dishwashers Logo
44 people viewed this question
Top Dishwashers Experts
