Question about DeLonghi 6507L Oil Filled Radiator Heater
Efficency with Oil Column heating
I have oil column heater on to warm a bedroom on level 3 in the evening but have conflicting reports of it taking more power to heat up again every night... am I better to turn off oil column heater during day time or is it more efficient to leave it on level 1 during that time and turn it up during the evening if necessary?
  • 105 Answers
Because it operates on room air temperature, if this is the only means of heat to this room, leaving it on would be more economical thus keeping the rise in air temp time less=less time it works hard to match what you desire. but if not only source of heat no. time to heat room would be almost the same thus you would save what you used during the day due to fluctuations in room temps between time your furnace would kick on and off.
Posted on Sep 21, 2008
The engine light just came on ....what could it be?
run the fault codes first to determine the failure
engine lights report on engine and transmission
check coolant levels , sump oil levels, over heating, transmission oil levels for obvious problems and the codes will report on sensors and the like
Feb 10, 2016 | 2008 Toyota Matrix
My heater warms up then it trips out my electrics
Either you have to much on the circuit, like lamps, TV, and running,
or there is a problem with the heater and you should return it.
Try a bedroom outlet, make sure noting is on in all the bedrooms, or the kitchen if you have outlets above the counter, outlets above a kitchen counter are suppose to be on their own circuit.
If you try this and it trips the breaker, return the heater.
Apr 10, 2013 | DeLonghi TRN1015T Solaris Oil-Filled...
Do electric fireplaces supposed to click on and off like central heat
do not want the three dollars would rather do this for free, it would depend on if it has a thermostat or not if it does yes it would if its a simple on/off switch and not one that controls a temperature no it shouldn't go on and off heaters generally do turn off and on if controlling a set temp like central heat also oil column heaters turn on and off to warm oil to a set thermostat temperature, so if its not controlling a temperature you set its faulty
Dec 03, 2010 | Heating & Cooling
How do I add oil to help heater warm better??
they are a sealed heater you can't add oil to get more heat, if you can must be a new type i haven't seen, but if not hot enough throw away and buy a heater that works they work on the principal that an element heats the oil and runds on an internal thermostat to control temperature of oil, your element may be starting to deteriate the same as hot water you only notice with hot water as it starts to not heat the water as much and you feel this in a shower or bath but you won't notice the same in oil heater it won't heat as it has and it may also be the thermostat, inside heater i wouldn't even bother trying to repair waste of time and money i would buy a proper working heater prefrably one that could be fixed to go better after its starts to deteriate a lttle
Nov 29, 2010 | Lakewood 2727 Heater
Hi, I have a Goldair oil column heater which is a
im sure it has a fuse-able link that will melt when the temp gets to high. it is a safety option
Jun 05, 2010 | Heating & Cooling
Left Heater switched on over night, oil radiator de longhi dragon
1st, check the electrical cord plug; because of the hielectric demand, thesaes plugs overheat and form a burn coating on the prongs that stops the hilevel of electric but allows a small level ofalaectric that still lights the lights but no power for heat.
2nd, the thermostat is not making contact: it is a bi-metal contactor that sometimes burns or loses its strength and no matter where you turn it it wont work. You can simply cross the terminals of the thermostat to see if you get electric flowing (you have to open the oen housing to do this.
3rd, the element could be burned-out or (as often happens) the connection to the heat element burns-off. Again, you need to open the end housing and look, or take it to a small appliance repair place.
Oct 11, 2009 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
I have an oil column heater about two years old, this year it is emitting an adour, is this normal , does the oil get old?
You need to give this heater a good clean with a mild detergent and cloth with it unplugged let it dry for a few hours then try it again. The oil is sealed inside inturn you can't smell this unless it's leaking.
Cheers
May 30, 2009 | DeLonghi 6507L Oil Filled Radiator Heater
Delonghi TRD715T
Does it sound like oil bubbles? Sometimes when an oil heater is heating up you can hear the pop sound of the oil heating.
Feb 15, 2008 | DeLonghi TRD0715T Oil Filled Radiator...
DeLonghi 6507L Oil Filled Radiator Heater Logo
313 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
