Question about Marantz Audio Players & Recorders
Marantz sr4320; digital sound knob has become completely unresponsive;set itself to 80 (inaudible) and cannot be adjusted in either direction; the display says "d8" whatever that means...
3 Suggested Answers
  • 45 Answers
SOURCE: marantz sr4320 will not come out of standby
Sounds like it's in protection mode. Take it to a hifi shop, they should be able to reset it.
Posted on Jan 08, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have a marantz sr4320
Do you mean "db"?
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING. The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Turn the volume down.
While you're squinting at the front panel, find the manual and evaluate every indicator on the face to make sure you understand what they mean and how they might affect operations. Look for Speakers NOT enabled, Muting ON, a Tape or other input inadvertantly selected. If you fail to find the errant setting, treat it like a new install and set it up all over again according to the manual.
Posted on Mar 09, 2011
garconne99
I have d8 showing up too next to volume, and volume does not seems to be working properly despite rechecking all my connections (only very dim sound at highest volume, from both CD input and tuner). Did you ever find out what d8 meant, or a solution?
Posted on Oct 14, 2013
Mum returned from overseas has s520 Nikon Coolpix.Last 8 days holiday pictures completely blurred.Now&again one clear out of over 100. Photos prior to particular date perfect.
Possibly the front element of the lens has become contaminated with some foreign substance and requires cleaning. Otherwise, sounds like a trip to repair facility. If it is still under warranty, contact Nikon direct.
Jul 16, 2016 | Nikon COOLPIX S520 Digital Camera
Hi, I need the schematic diagram for marantz pdm679, Someone can help me? I am jorge, audiohertzio@gmail.com
Jorge,
The schematic will be part of the service manual, which gives a complete explanation of dis-assembly, circuit function, parts, & adjustment. You can purchase a service manual for the Marantz PMD 670 at http://www.servicemanuals.net/ServiceManual/MARANTZ/pmd+670/pos1/results.aspx
Anthony Beeler
Oct 10, 2012 | Marantz PMD670 Desktop Digital Voice...
Hi,i have connected phono cables from mixer to anolog in on marantz dr4050 and from anolog out on marantz dr4050 to input on amp,there is no sound unless you turn levels to max and then it is very quiet...
So you're saying an unnamed mixer is feeding a potential analog signal to a CDR. You're monitoring the CDR output at an unnamed amp.
You haven't established that there is any signal to BE heard.
WHAT is the actual source sound device (BEFORE the mixer)? Is the source input visible on the CDR when it's in Record Mode?
Have you perused the manuals?
NEVER USE EXCEPTIONALLY HIGH VOLUME SETTINGS FOR TROUBLESHOOTING. If a signal is inaudible at half volume it's effectively not there. YOU WILL BLOW SOMETHING UP WHEN YOU FIND THE MISPLACED CONTROL AND FLIP IT.
Jun 07, 2011 | Audio Players & Recorders
I have a marantz sr4320 receiver. The volume control knob is not working---I can't get any sound no matter the volume number. "d8" is now showing, too, following the number. I have followed...
Do you mean "db"?
Mar 09, 2011 | Marantz SR-4320 Receiver
The volume will only turn up to "0" and barely hear a sound from the speakers. How can i trouble shoot this
I had a similar problem with an SR4320 that I bought used at Goodwill. First of all, turn the volume knob down; 0 db is actually the highest volume. Not sure why Marantz did that; it's counterintuitive. Set it to a more normal volume like -30 db. If it suddenly starts working, you'll blow out your speakers (and possibly your eardrums).
Second, check the back of the unit. There are two RCA connections that say "Pre Out" and "Main In". This is where you could connect another amplifier or a graphic equalizer. But if you don't have either of those hooked up, you need to have them connected to each other. Apparently the unit shipped with jumpers connecting these plugs, but a prior owner must have taken them off.
All you need is a short (1 foot or less) red and white RCA stereo cable. Connect the top Pre Out to the top Main In plug with the white cable and the bottom Pre Out to the bottom Main In plug with the red cable.
Hope this helps! It's a terrific receiver!
May 21, 2010 | Marantz SR-4320 Receiver
Marantz sr4320 will not come out of standby
Jan 08, 2010 | Marantz SR-4320 Receiver
Marantz pm 7200 integ.amplifier
Dear Sushant,    I do not think your use of an equalizer has caused any problems.  I will explain the proper use of the source/direct button.  This button's function is to monitor the output of a recorder connected to the record outputs of your amp.  When this button is pressed on the sound going to the speakers comes direct from the "source" (cd, radio tuner, phonograph etc.) when in the off position you can monitor the recording of whatever source is being recorded via the tape deck.  This switch must be off to record through the amps record outputs.    To test this, put a blank tape in the tape deck, choose the source as phono and place the dec in record/pause.  With the source direct button pressed on you should hear a change in volume when moving the amp's volume knob only.  When source direct is off you will be able to hear the output of the tape deck, so adjusting the tape deck's record level will also affect the volume coming out of the speakers.  more record level in/ more level out.!    Below is copied from page 9 of your user operation manual for Marantz's explanation of the source/direct button.  image.tiff
best of wishes, Michael Mittelsdorf
Jan 05, 2009 | Marantz PM7200 2-Channel Amplifier
Marantz Pianocorder P100
i Have a Marantz Pianocorder model P-100 the cassette player when adjusting the tuning knob,the LED lamp never goes out like it should the lamp stays on all the time when you try and make AZ. adjustments?
Apr 14, 2008 | Marantz Audio Players & Recorders
Playstation 3
I assume that the Marantz has an Optical lead input. If so you should connect an digital optical lead directly between the PS3 and the Marantz receiver for the sound while keeping the HDMI lead to the projector for the picture. You will need to configure the PS3 to be outputting the sound to the optical output (done through the settings menu).
Jan 08, 2008 | Marantz SR-5200 Receiver
29 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
