Question about Hotpoint Washing Machines
We have a washer dryer WD420 and the dryer has stopped working is that anything we can try and fix?
    Novelist:
    Champion:
  • 244 Answers
Does your washer still work if so then it will most likely be the thermostats under the lid u cant miss them tere will be 2 wires going to each stat there are 2 fitted to the silver dryer unit repkace both will cost u no more then £15 to buy and will only take 10minutes to do m8 let me know how u go or if u need anymore help peter
Posted on Jun 10, 2008
    Genius:
  • 1,122 Answers
MOST TIMES WHEN A DRYER JUST STOPS AND DOES NOTHING IT IS EITHER THE DRYER DOOR SWITCH LOCATED BEHIND DRYER DOOR OR THE MAIN FUSE FOR THE DRYER IS BLOWN,MOST DRYER YOU CAN REMOVE BACK OF DRYER TO GET TO FUSE,ALSO SOME DRYER'S HAVE A SAFETY SHUTOFF IF BELT BREAKS IT IS UNDER THE DRUM,LET ME KNOW IF YOU NEED MORE HELP-MIKE
Posted on Jun 09, 2008
Hotpoint wd420 shows error code f13 after replacing heater element for dryer.
Change electronic board it is what will cause this problem if you checked all ducts an fan and still heats board is bad
Oct 28, 2014 | Hotpoint Ariston Aquarius WD420 Front Load...
Whay my Hotpoint -Ariston Aquarius WD420 Front Load All-in-One Washer / Dryer stpos have way the circle
You say it stops half way through cycle (if I have read it right), especially when fast spin starts. Does it stop anywhere else (in wash cycle or rinse cycle)?
I would check the main filter in the sump (pipe from drum to drain pump) and ensure pump itself is not blocked which could cause the pump out time to be exceeded and thus stop the program. A faulty pressure switch could also be responsible.
I would also check the tacho on the motor and connections to main board at bottom of machine near to motor.
Disconnect machine by pulling out plug and wait 10 minutes for capacitors to discharge before doing anything, to protect yourself against residual voltages.
From a retired engineer who owns one of these machines.
Jul 28, 2012 | Hotpoint Ariston Aquarius WD420 Front Load...
Sometimes when using the tumble dryer of my Hotpoint WD420 I get a puddle of water on the floor. Doesn't happen with every use. Do you know what the problem might be?
I suspect your dryer vent is blocked or partially clogged.. Also if your washer is not opperating properly putting wet close in the dryer could also cause this.....hope this helps!
Feb 19, 2011 | Hotpoint Ariston Aquarius WD420 Front Load...
Where is the filter on a Hotpoint Aquarius wd420 washer dryer?
it is located at the back of the machine...are you encountering problems with this machine? check this link i will give you, this a forum/comments which the owners encountered different problems with this machine..
http://www.unbeatable.co.uk/p_rupr/Hotpoint-Aquarius-WD420-Front-Load-All-in-One-Washer--Dryer-Reviews/22394331.html
Nov 13, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Door will not open door light just flashing on and off
washer not spining mini load button flashing on/of buton flashing
Apr 27, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wd420 washer dryer dryer is not heating up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Mar 07, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Turn washer dryer on ok, then close door then curcuit trips
check the wiring and make sure nothing metal is on the motor because your dryer has a short in it somewhere
Dec 23, 2008 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint WD420 Washer/Dryer - Not completing cycle
I WOULD FIRST CHECK THE COLD WATER VALVES ONE COULD BE INTERMITTEN
Jun 25, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
88 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
