Speedtouch 585V6, mapping ports doesn't seem to work properly. I need port 343 mapped for my work vpn, done it on other brands of router but this one is getting the better of me, as it disconnects from the vpn after 30 seconds.
  • andy58 Jun 08, 2008
    Thanks for the promt response. I'm sorry to say I tried that previously and did not work. I spoke to thomson helpdesk and they said it should. I tried resetting to default config and re-created the gaming application but it's still not playing. They even gave me a set of telnet instructions that I tried and still no joy. Even set it to a DMZ, disabled the firewall. I connected the laptop to my Netgear router and can set it up to work in about 15 seconds, so not the lappy thats a problem.
Iik
Posted on Aug 28, 2008
    President:
  • 169 Answers
connect to webmanagement via internet explorer http://192.168.1.254
Click on Toolbox
then Game & Application Sharing
Click on Configure at the top
Use UPnP or Create custome port.
I have a THOMSON TG585 v7 or may not be the same.
Hope this helps.
Posted on Jun 08, 2008
  • Abdul Qayyum
    Abdul Qayyum Jun 08, 2008
    I use cisco VPN Client and it uses
    UDP port 4500, If your using a Cisco VNP Client then try opening UDP 4500 and 5000.
    Regards,
    Abdul Qayyum
Where is the WPS Button on my Thomson Speedtouch Router
Does the speedtouch 585v6 router have WPS and if so where is the ...
www.askmefast.com > Computers & Internet > Computer Networking > Router
  1. Cached
  2. Similar
Jump to The WPS button is located either at the back or top of your router.If ... - source: Trying to connect my wireless printer with the router at my new ... Router thomson speedtouch tasto wps ... Wps button speedtouch 585.
IS THERE A WPS BUTTON ON A SPEEDTOUCH ROUTER - Fixya
www.fixya.com/support/t20444391-wps_button_speedtouch_router
  1. Cached
Oct 1, 2013 - Question about Thomson Speedtouch St585 V6 Sl Wireless Modem ... do i find my password for my wireless speedtouch 585v6 router? my ...
Page 17 of the manual
https://www.cosmote.gr/fixed/documents/10280/652016/TG585_SetupUserGuide_en_v8.pdf/0878a24f-0922-408c-bd51-fff55a07f53a
Feb 02, 2017 | Thomson Computers & Internet
How do i find my password for my wireless speedtouch 585v6 router? my broadband provider is Aol.I need this to set up a tablet please help. Thank you
There is no password unless you have changed it, the user is Administrator note the capital A and leave the password blank. When you have done change it and save the result
Mar 07, 2015 | Thomson Speedtouch St585 V6 Sl Wireless...
Belkin N300 - CISCO Clean Access Agent
All configuration can be done with the router GUI.
Firewalls: Server Side Having a server side firewall is the typical configuration on many systems. There is only one method for doing this, whether you use telnet or ssh: map a port to be forwarded to the server in the firewall router. It is not advised that you use telnet from the Internet for security reasons; that is usually why you have a firewall.Decide which method of connectivity will be allowed, and determine what port you will use to forward to this service. If there is only one server involved, you can use port 22 for ssh or 23 for telnet and forward them straight through to the server. But if there are several servers involved and they do not have public IP addresses, you will need to pick different ports on the firewall router and let the router forward those ports to the different internal servers.
Mar 01, 2013 | Belkin Surf N300 Wireless N Router
I need to access a web server externally via port forwarding. i have a smcd3gnv
Do you mean that you need to access an server on your LAN from the outside world ?
The manual is on the second result of a google search for smcd3gn and the table of contents has clickable links.
The machine you run any inside server on needs a static IP address (192.168.0.11 for example) and you configure the gateway so that your outside request to address and port (http://10.10.10.1:8080) gets mapped to your inside machine's IP address and the port you are running the server on (192.168.0.11:8000) for example.
If you are only using one internal web server just map port 80 to port 80 along with the inside IP and you can omit the port number in the external URL. (If you are running more than one server you should be able to figure it out.) Remember to disable external access to the router's configuration if you do this because that also runs on port 80.
My example mapped outside port 8080 to inside port 8000 just so they would be different. Remember that one outside port can be mapped to a single inside address and port. You can run two inside machines with a service on their own port 80 but they need different ports on the WAN interface.
Sep 29, 2012 | Smcd3gn-res Wireless Router Cable Modem...
I have a speedtouch 585v6 router.the wlan light use to be on green constantly but now there is no light on at all
try resetting it should be a button in the back. if this dosnt work try uninstalling the reinstalling the program if this dosnt work either then your router has been shocked and will not work anymore :)
Mar 24, 2010 | Computers & Internet
WRT120N doesn;t permit VPN accesses
Most times when VPN is not working is because one of the ports is not forwarding right. Easy fix is to go to router settings and enable DMZ for your computers IP address. Also you can actually find out what are the ports this VPN uses and go to Port Forwarding part of router and open the ports manually. My favorite is DMZ. All this does is open up ports for your computer IP address so there is no blocked pockets. Good luck.
Jan 12, 2010 | Linksys WRT120N Router
Trying to get VPN to work but not sure what fields to fill out to open ports on router. There is a previous post about opening some ports but I'm not sure what to fill out in all the fields or what it is...
you should at least provide with the router name and modem number , than i can provide you with the port number and how to open the port or more specifically "PORT FORWARDING" FOR YOUR vpn connections ... thank u
May 16, 2007 | SMC Barricade 7004 Router
VPN
the following is from a nice guide i found on the net, see if it works for you: First thing to check is whether your router has any settings for PPTP or IPsec "pass through". These are commonly found in Linksys routers but you may have to hunt around for them on other makes. All you need to do is enable the setting for the VPN protocol that you're using, reboot your router and, if you're lucky, the VPN connection will come right up. Note: Not all routers have these enables and the lack of them doesn't necessarily mean that you can't get VPN working. Open up that Firewall Still no connection? The next step is to try opening some ports in your router's firewall to get your VPN connection made. In each case, you'll need to open the specific ports (and protocol) to the IP address of the computer that you're running the VPN client on. NOTE that port mappings work with only one computer at a time. If you have multiple VPN clients that you need to connect, your router will have to support the VPN protocol that you're using without requiring ports opened. If you're using Microsoft's PPTP protocol, TCP port 1723 is the port you'll need to forward to allow PPTP control traffic to pass. Figure 2 shows the Forwarding screen on a Linksys BEFSR41 set to forward this port to a client with IP address 192.168.5.100. PPTP also needs IP protocol 47 (Generic Routing Encapsulation) for the VPN data traffic itself, but note that this is a required protocol, not a port. The ability to handle this protocol must be built into the router's NAT "engine"?which is true of most present-generation routers. IPsec-based VPN's need UDP port 500 opened for ISAKMP key negotiations, IP protocol 51 for Authentication Header traffic (not always used), and IP protocol 50 for the "encapsulated data itself. Again, the only "forwardable" item here is UDP port 500, which is also shown programmed in Figure 2 to the same LAN client machine?protocols 50 and 51 must be built into your router. Tip: Not all routers are created equal! Some allow only one VPN tunnel to be opened and used by a single client. Others support multiple tunnels, but with one client per tunnel. Unfortunately, most vendors don't make the VPN pass through capabilities of their products clear in their documentation, nor do they have support staff properly trained to provide this information either. In most cases, your only option is to try a router in your specific application, and make sure you can return it and get your money back if you can't get it working. Still not Working? Getting many IPsec-based VPN setups working can be a black art due to the wide variation in techniques used by various vendors. Although IPsec products have become more uniform as the technology matures, your company may use older, more proprietary products that may not be configured with NAT in mind, or require additional ports to be opened in your firewall.
Feb 19, 2006 | Microsoft MN-700 Wireless Router
Computers & Internet Logo
683 people viewed this question
David Payne
David Payne
