Question about Samsung Televison & Video
Samsung le32n had it for 16 months came down this morning blue light flashing on bottom of tv but no picture or sound. Tried swapping cables, sockets, leaving it off for a while nothing helps
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 92 Answers
Those Samsungs and most other HD units can fail within 6-18 months of purchase.. I would contact Samsung and go up the corporate ladder for help. Otherwise you may be looking at a repair bill that is as high as the cost of new unit.
Craig www.classtorations.com
Posted on Jun 08, 2008
Why would tv sound work fine but while using roku 2 the sound suddenly stopped working?
If the picture is OK then check your sound cables, red and white if analog, or swap out the HDMI cable with one that you know works.
Also, on the SETTINGS screen make sure your audio is set to stereo not surround sound.
Dec 27, 2014 | Roku 2 XS
My Samsung LE32N7 does not come on. The blue light under the screen constantly flashes without the tv coming on.
Hi, maybe the TV controller board is blocked, you can reset it, by disconnecting power cable from outlet for about 5 minutes, if that doesn't work, possibly and internal board or component must be repaired of replaced, in such case it's better to contact an authorized Samsung service center or technician to check your TV.
Nov 07, 2017 | Televison & Video
Samsung B2330HD Blue Still light, no picture?
Hay Junior!
You have a power supply problem and unfortunately this repair sould be done by one who knows electronics specially tv electronics..
Jun 19, 2012 | Samsung B2330HD 23 in. LCD TV
Can anyone point me in the right direction?I have had my samsung DLP (model SP50L6HD) for 4 years. This morning my children were watching TV and the tv started turning itself on and off. I switched it...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 24, 2011 | Samsung HLM507W 50" Rear Projection HDTV
Cable hooked up right...turned on this morning sound no pic
Ur tv been in use at least 1 1/2 or 2 years.On about 4 or 5 hours a day on this tv?The LED light indicator "LAMP" flashes?The projection bulb life is over.Require a new bulb.
May 27, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
I have a 52" samsung that is 14 months old. for some reason it is out of sync. the picture is too wide and does not fit cable shows or dvd's properly onto the screen. tried different picture size settings...
FCC says it only has to display a picture, with 16 formats it tough to get it to ever fit right, use 16x9 or full on TV remote , then 16x9, stretch 1080i on cable box
Jul 27, 2009 | Samsung LN52A650A LCD TV
No picture or sound/wont power up
Your mainboard is damaged, the mainboard is the one where you plug all the cables (component HDMI), it is really easy to replace, you only need to take special care with the screws.
1. remove all screws in the back.
2. unplugg all cables from mainboard.
3. remove all srews from mainboard and replace it.
4. put all screws back and then plug all cables again.
5. double check all mainboard cables are properly secured.
6. Test TV.
7. put the back cover and secure it with the screws.
8. Enjoy your TV again.
May 30, 2009 | Samsung LNT5265F 52 in. LCD HDTV
Vivitek tv
I have a 56" model that I have had a similar problem. My bulb burned out in <90 days. Warranty was 90 days on the bulb itself. When the TV picture goes out, the indicator LEDS blink on and off.
Here is what you have to determine:
1) First cover the left LED with a piece of paper so that you can't see it blinking. I don't know if your layout is the same as my TV. You may have to switch the paper blocking the LED.
2) Pay attention to the other LED and READ its' flashing code. In my case, the code was 2-3. It would flash 2 times, pause briefly, then flash 3 times. This meant code 23. That indicated the bulb was burned out.
3) If you look in the manual, It does have a code list of some sorts to tell you of the codes and their meanings. Hope this helps.
Nov 20, 2007 | Vivitek V37835 46 in. LCD Television
Open Questions:
Televison & Video Logo
106 people viewed this question
Henry  Thomas
Henry Thomas
