Heating & Cooling Logo
Posted on Oct 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Weather seal wasn't opening, replace motor. Still not working, replace electronics box. Nothing works, only red led on electronics box flashes.
Azrael SRL
Level 3:
  • Master 11,800 Answers
  • Posted on Oct 25, 2010
Azrael SRL
Master
Level 3:
Answers
11800
Questions
0
Helped
2566665
Points
35672
The flashing red led signals a fault. Since you have replaced the motor and the electronic box (and i'm assuming that the seal can be opened by hand - it's not stuck) the only thing left is the wiring - it's most likely shorted. Test it and repair the damaged section.
1helpful
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Our Yamaha RX-A730 won't turn on. It's less than 2 years old. It's plugged into the same surge protector box as other electronics and they all work fine. Is there a reset button or fuse box?
My yamaha rx730 did not powerup. The red power led had a faint flash, but pressing it caused it to flash rapidly but no display or relay clicking. trying to reset the speaker protection (button combination while pressing main did not work. Opened up the cover and remove the power supply board.
Measuring the 5.7v from the powerboard showed only 3v
Internal fuse is ok.
fixed it by replacing all elco's capacitors on the power supply board. Did it oneby one, and test it every time.
in the end it was the 47uf cap (C3708 page 137 service doc). Now5.7v is ok and its powersup again
Fix cost me 1 hour and $10 for new caps (incl shipment)
I have a delta touch faucet and the blue led light stopped working. The red is still lighting and the touch feature is working properly. How can I fix the blue led light?
  • Solid Blue - Normal operation, "Touch" mode is activated.
  • Flashing Blue - Normal operation, the hands-free mode is activated.
  • Solid Red - Warning mode - Replace batteries as soon as possible. While the water is running Solid Red LED is illuminated. When the water is off, the Red LED flashes once every 5 seconds. The faucet operates normally, solenoid valve is open.
  • Rapid Flash Red - Alert Mode - Battery Failure Imminent. The Red LED flashes once a second. The first time the faucet is used, the Red LED will turn ON, the solenoid valve will be opened and remain open. The manual valve must be used until the batteries are replaced.
  • Solid Red - Lockdown Mode - Replace Batteries. Extremely Low Batteries - The RED LED is ON, and water will not flow. The solenoid valve is closed and faucet will not operate until batteries are replaced.
  • Long Flash Red (2 seconds on / 2 seconds off) - Board error, replace electronics kit, RP53230 See manual bypass of electronics section of Installation instructions.
2answers
Led Trailer Lights Problem
I believe you need to switch polarity of these lights. Connect the red wire to ground and the ground wires to the functions you need. Yes, try it, some of these bulbs work on electron theory and so positive and negative are reversed.
Feb 04, 2015 • Boating
How do I check the led light strips on my led lcd tv, to see if they work? and/or how do I replace the led light strips?
Contact any service technician. It will be best in this case. If you're sound in electronics, and have some previous knowledge in servicing LCD TVs; please respond. Otherwise please !!!!!!!!. Time is precious for us.
3answers
My R2D2 interactive juste flash red
hola tengo el mismo problema que tu, cual es la solucion?
Te escribo desde Spain, mi correo [email protected]
gracias
5helpful
2answers
All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Blackberry pearl wont stay on and red LED light keeps flashing
my phone wont stay on and when it does come back on it shuts right back off. the LED light on the front keeps flashing red. ive taken the battery out and everything and nothing seems to work. help please!
5helpful
Water filter
electronic circuit needs repair
Top Heating & Cooling Experts
Paul Carew
john h
