Question about GPX PDL705
Ac adaptor I have a gpx dvdvplayer model # PD705 and i cannot find the adaptor and the battery needs charging. Is there any way to get one that will work with it.
I just called Gpx for a Car charger and they had in stock (as of 6-17-08) it was $14.99.... the wall carger was $9.99. Hope that helps. GPX phone # 314-621-2881.
Posted on Jun 17, 2008
    Champion:
  • 303 Answers
You can buy a new one by clicking on the hyperlink:
buy replacement ac power adapter charger GPX PDL705
Posted on Mar 04, 2009
Does it exist?
Please confirm model number
number of batteries in the battery bay 3,4 or 6
Jan 05, 2014 | GPX WMA/MP3 Portable CD Player Personal CD...
My Acer Aspire 9805 battery was replaced. For
It could be an AC adaptor issue.
It should boot when connected directly to the power outlet through the laptop adaptor. If it is not boot, then the adaptor might not be supplying the needed power to boot it up.
If it is possible, try to isolate the issue. Charge your new battery using another laptop. Then plug it in your laptop to see if it works. If it will work, then it is the AC adaptor of your laptop that is defective. If the charged battery still won't make the laptop boot, then there is something wrong with your laptop hardware. If could be a motherboard issue of your laptop.
Feb 23, 2010 | Acer Aspire 9805WKHi Notebook
When i go to charge my kodak M863 camera (in the wall or by USB) the green light flashes and then the red light blinks 3 times. please help this is the first time charging my camera.
You can used the USB cable to charged the camera, But some of the M863 camera will not take charged usign the USB cable., I strongy suggest used the AC adaptor just make sure the AC adaptor is 5V ac adaptor it will only charged using the 5V adaptor., About the flashing green it indicates camera is charging just wait for the solid green light it means it fully charged
You may purchased also a special charger for your battery(KLIC-7001)- cahrer model is K8600-C. i think the price of this charger is around $29.00
Nov 14, 2009 | Kodak EasyShare M863 Digital Camera
HAVE A KODAK 8.1 MODEL M893 CHARGE IT WHEB YOU TURN ON IT'S ON YOU GO TO TAKE PICTURE IT SHUTS OFF
Are you suing the recommended battery KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7001? If no please purchase KLIC7001
Now in case you are using this KLIC7001, How do you charged the camera or battery? USB cable or AC adaptor? If your using USB cable actually some of the M893 will not charged using USB cable you need to update the firmware or download the firmware before you can successfully charge it using the USB cable
Now if the AC adaptor make sure when you plug the adaptor theres a light indicator on the camera and charged the battery for 4hrs., and still the camera will shuts off everytime you take a picture please call kodak toll free 1 800 235 6325 have your camera repair. Gudluck!
Nov 05, 2009 | Cameras
How do you charge it
to charge the GPX ML6488 MP3 Player, you have to find the AC Charger design for GPX then locate the power outlet for GPX then plug the exact or match connector from your charger then plug the AC Charger to the power outlet then wait the MP3 's battery become full.
thanks
Sep 14, 2009 | GPX ML648B MP3 Player
I can't determine the polarity of my GPX PDL705 portable dvd
I have uploaded the GPX PDL705 manual to this site today. If you check tomorrow they may have posted it by then.
If you look at the small print on the adaptor it should indicate by diagram Voltage output, current capacity, type and tip polarity by small diagram. Most adaptors are 'positive' -- but if you are unsure do not plug the adaptor into the device because it will fry it!
Dec 05, 2008 | GPX PDL705
Laptop does not work with AC adaptor, does not charge. Mother board issue
You may be able to get a battery charger but its rare.
If you do wish to use the AC adapter, take care with positive and negative. Also the voltage of the battery is actually lower than the AC adapter in order to get charged. I don't know what is going to happen if you do choose to use AC adapter as battery. 75% chance that it will work.
Oct 08, 2008 | Dell Inspiron E1705 Notebook
Battery on lap top is not charging
switch off - disconnect ac adaptor - wait 3 seconds - connect ac adaptor - repeat about 20 times.
Is charge light blinking when you connect ac adaptor?
Try reseating battery.
If battery is old (over 2 years) or heavily used then it may need replacing. They only last for 250-500 complete discharges.
Aug 08, 2008 | Evesham Computers & Internet
Battery is not charging
Charger board seems to have gone bad.
Aug 05, 2008 | HP NC4010 Notebook
Lap top problem
Hi
If the AC power light is blinking, try the following steps:
1 Cut off power to the computer by disconnecting the AC adaptor and removing the battery. The error condition will be interrupted, and the AC power light will stop flashing.
2 Put the battery back into the computer. Do not connect the AC adaptor. Try turning the computer on again. If the computer starts normally, the AC adaptor may be
defective and will need to be replaced. If the AC power light starts flashing, remove the battery, and continue with the steps below.
3 Connect the AC adaptor to the computer. Leave the battery out of the computer. Try turning the computer on again. If the computer starts normally, the battery may need charging, may be depleted, or may be defective. Turn the computer on, insert the battery, and then leave the computer running for several hours, which will deliver a slow, steady “trickle-charge” to the battery. Once the battery has been trickle-charged, it may begin working correctly again. If the trickle-charging does not prove effective, consider replacing the battery with a new one.
4 Connect the AC adaptor to a different power outlet, preferably in a different room. If the computer starts normally, there may be a problem with the AC outlet itself, or the voltage level available from it.
5 Verify that the AC adaptor is the correct unit for your computer model. The computer may not be able to start from an AC adaptor that is rated for less current (amperage) than the computer requires, even if the rated voltage is correct, and the plug fits correctly in the DC-IN socket. The labels on the bottom of the computer and the AC adaptor show the specifications for voltage ("V") and current ("A") for each device. The voltage level must match exactly. The amperage rating of the AC adaptor must be equal to or greater than that required by the computer
Regards
Mike
Mar 21, 2008 | Toshiba Satellite 1805-S204 Notebook
GPX PDL705 Logo
210 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
