Question about Whirlpool Refrigerators
My Whirlpool model DE22RQ or DQ water dispensor does not work. The ice maker is working. I hear a humming sound from the back when the dispensor is pressed but no water comes out.
If the icemaker is working you have water at the inlet. the water line in the freezer door may be frozen.
you will find a coupling near the lower freezer door hinge. disconect that coupling and activate the dispenser. If you have water there the line in the door is frozen.
you can remove that line from the door or just leave the door open for a while.
Posted on Jun 10, 2008
  • 770 Answers
Checked for a clog in the inlet side of the valve where the water comes in there is a small screen that maybe blocked also check on the back wall of the freezer where the fill tube goes into the units icemaker it could have frozen up due to low water pressure
Posted on Jun 09, 2008
Whirlpool model # ed5vhexvq1 side by side maker will not dispense ice..water works but it sounds as if there is no power going to icemaker from dispenser
Does the icemaker bucket has ice cubes. If yes then your problem is in the dispensor. If no ice cubes on the icemaker bucket then your problem is with the ice maker unit.
Let say Ice cubes on the ice maker bucket and dispensor makes noise when pressing for ice cubes. Then either your ice dispensor flapper is frozen or may be ice cubes in bucket may have defrost and frozen again sticking together.
Oct 01, 2014 | Whirlpool Refrigerators
Water dispenser maker works fine you can hear motor hum when pressing water dispenser button
You should not hear the noise of a motor unless you are trying to dispense ice. Is that the case your ice dispensor is not working?
Sep 16, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker door does not close all the way and the ice maker switch that releases the ice when press does not work all the time
Sounds like your saying that the ice dispensor flap is not closing completely which will cause frost on the inside shoot and on the ice bucket . Could be because of a broken guide ( clear plastic piece attached to the ice dispensor arm ) . Need brand and model number to help .
Aug 20, 2009 | Whirlpool Refrigerators
Ice maker works, fills door but doesn't come out
You have a bad dispensor flap solenoid . Frost due to flap not closing completely and ice will catch in the shoot .
Jul 25, 2009 | Whirlpool GS6SHAXLS Side by Side...
I have a GE refridgerator model number GSS25IFRE BB the ice maker and water dispensor just stopped working. The filter is new. and still has the problem with the plug in. Also if you hold a glass in the...
Do you have water getting to the filter? if not:first loosen filter and see if you might have air in line,secondly, the copper or aluminum water line from water supply to solenoid may be limed-up,third loosen line at solenoid and see if your getting water that far,those solenoids pulsate when operated on A.C.current you should hear a hum when activated to get water and that would explain pulsating light at water dispenser
Jul 24, 2009 | Refrigerators
Ice maker not getting water, but water to the door dispensor ok
The fill solenoid for the ice maker is not working. Replace it and you are good to go.
Sep 24, 2017 | Whirlpool GD5SHAX Side by Side...
Ice maker water supply line keeps freezing at nozzle
sounds like your defrost module may not be working, if that is the case it will Freeze up the tip then the line it also leads to a Cracking of the Flex pipe and the Water Filter lines hope this helps if you have a model number i can take a more in depth look at it
Jan 19, 2018 | Refrigerators
Ice maker was hot and could hear water dripping on will have to replace the ice maker.if further used without replaceing the compressor will get damaged and you will completely loose cooling in your unit.
Mar 07, 2009 | Whirlpool ED0GTQXMQ Side by Side...
Water Dispensor and Ice Maker Not working
Make sure you have water coming to the water inlet valve and then check to make sure that your water filter is pushed all the way in. Next check your solenoids in the back of your fridge. With the power off take an ohm meter and test across the two terminals and it should not Ohm out or beep. If it does you need to replace the solenoids
Jan 04, 2009 | Refrigerators
GE Refrigerator, model PSS26MGPBBB, stop making ice. Water dispensor works fine. Green light on ice maker is blinking. Have tried recycling power to ice maker no change. Have check to see if...
Aug 25, 2008 | Refrigerators
Refrigerators Logo
108 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
