Question about GE Â 17.9 Cu. Ft. Top-Freezer Refrigerator
Whirlpool ed22rf cools poorly on non freezer side.
Help! I'm trying to help this lady who is trying to keep her food from spoiling.  She has a whirlpool ed22rf that makes ice but won't keep the right side cool.  I may have damaged the defrost timer while messing around with it.  It split open and I put it back together.  Could this be the cause of the poor cooling on the non freezer side?  Also, earlier the center strip between doors got really hot.
  • Anonymous Feb 26, 2009
    Its a GE and when i turned the defrost timer it took more then one click to shut it down
  • 828 Answers
Check condenser for dirt or dust, check back wall of freezer section for frost, if you find frost there is a defrost problem. Frost buildup on the surface of the back wall indicates that the coil inside the back wall is frozen over. Inside the back wall on the coil are heaters which the timer energizes to defrost at certain intervals. These heaters could have an open circuit, the defrost thermostat could be open, or the timer could be malfunctioning. To test the timer manually you can rotate the clutch head screw clockwise untill you hear one click. The heaters should come on and defrost for 18-22 minutes. The refrigerator should return to cooling after that time. If it does not automatically restart turn the screw once more to a second click and it should start.
Posted on Jun 09, 2008
Why is there a red hot element in my freezer
It's the only way your freezer will stay frost free. Water will condense from the air on the coil. Eventually the coil will not provide enough cooling to the freezer and your food will spoil. The defrost element solves this problem, however it can also lead to freezer burnt food.
Aug 24, 2014 | Frigidaire GLRS264ZA Side by Side...
I have an older side by side kenmore and the fridge wont go lower than 50.. I am afraid my food is going to spoil
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Oct 16, 2010 | Kenmore 44393 Side by Side Refrigerator
There are a few reasons why the refrigerator part will not are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
Jul 11, 2010 | GE Profile PSW26P Stainless Steel Side by...
Refrig. Won't keep food cold but the freezer works fine. Milk spoils after 3 days in the refrigerator. What's wrong? The thermastat was supposely changed?
If the thermostat has been replaced, then I would take a look at the dampers between the refrigerator and the freezer. Here is why....
All the cooling takes place in the freezer section of the unit, there are passageways with dampers that connect the freezer section to the refrigerator section. If these dampers get stuck in a certain position you will either have not enough cooling or to much cooling. This sounds like it is your issue. Hope this helps.
May 07, 2010 | Refrigerators
Refrigerator stopped cooling
the problem is in your freezer !
open the back wall of your freezer and check if the fan working then if you see a big build up of ice. then its your heater unit or your heater thermostat. to check that it is the problem unplug the unit defrost the freezer coil with hair drier gently and when it done plug it again and see if your fridg get cool (1h or 2) then you know its the heater unit or the thermostat :(
911servicetoday .com
Jan 01, 2010 | Whirlpool ES5FHAXS Side by Side...
The refrigerator is not cooling enough.
You will need remove the screws in the back of the freezer section, check to see if the little fan is turning, if not you will have to replace the fan motor, this is what circulates the air and keep the fresh food side cool.
Nov 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag Fridge (Model # MZD2766GEW) not cooling
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side.
Apr 06, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
GE Â 17.9 Cu. Ft. Top-Freezer Refrigerator Logo
409 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
