Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
No sound, red screen
Hi guys, im totaly desperate, mi TV is mad, i had this problem since 2 days, i've tryed to acces the service menu (menu+enter, + power) but nothing happens, just star to swiching colors (red, blue, green, so im know it's not a hardware problem ), reset neither work , i dont know what to do, vga mode its the same problem, Please HELP ! tnx
  • chilean guy Jun 10, 2008
    ok, i have fix the screen problem, in color temp i've put the "user" setting and put all 3 values in the middle (R,G,N), that way i have achived to see normal colors again, but , i still hace no sound in cable mode (a/v mode and vga mode are workig fine :D ) , i have called to viewsonic and they sugest me 2 thing , 1st to go to the menu and try reset the factory values (didn't work) , 2nd to unplug de ac and press the power button to uncharge all the residual energi and do some kind of "hard reset" (didn't work either). so finaly.... cable mode it's f**ked up but the others modes seems to work properly
    PD: to verify that the cable signal it's not the real problem, y have tryed in another cable cable (it's that writed rigth?) from mi home that work fine in another tv, but in this one it's same problem ever. need another information??
    C'ya and thanks pd2: sorry if mi english sucks :p
Sounds like the problem is being caused by bad cables or bad device signal. What is it hooked up to ie; computer, DVD player, etc. Check the cables themselves, start by checking the tips, try to make sure that none of them are bent or tweaked. Let me know what you find, and then we'll go onto step two.
Posted on Jun 09, 2008
Bought this TV used and was told it needed a ballast board. I spoke with the tech that worked on it and was told a supply board as well as possibly needing a new bulb. I've replaced all three with no...
Sir when replacing the bulb you should reset the lamp hour meter. 1. while on the standby mode press "mute" then the numbers 1,8 and 2 in succession, and press the power button.
2. wait until "loading factory" appears on your screen and the service menu is displayed with the lamp life hours. You will see a list of service options.
3. Scroll down to "option" and press "enter". next you will see "reset lamp" where you will press again the "enter" button. good day and best regards.
  • 2 Wait until "Loading Factory" appears on your screen and the service menu is displayed with the Lamp Life Hours. You will see a list of service options.
  • 3 Scroll down to "Option" and press "Enter." Next you will see "Reset Lamp" where you will press again with the "Enter" button.
  • Read more: How to Reset the Lamp Hours on the TV ' eHow.com http://www.ehow.com/how_5535314_reset-lamp-hours-tv.html#ixzz1VIGJC5k7
    Aug 17, 2011 | Samsung HL56A650 56 in. TV
    The word "Factory" has appeared on the screen in red
    Hi.
    Factory on screen means that the TV is stuck in service mode (Durabrand and more). The problem is fixed accessing Service mode and resetting to factory default settings.
    On Durabrand TVs problem is fixed using a programmable remote, entering service code on remote, and accessing service menu.
    Procedure is listed on TV service manual.Most durabrand use Menu and key combination 683 to access service mode.
    If that does not work, calll manufacturer number to get the key sequence to enter factory menu.
    Jul 06, 2010 | Televison & Video
    Red spot on screen
    Got the same problem with same TV (PT-61-LCX65) that was bought 4 years go in 2006 - first red spot appeared, then few weeks ago got green one nearby. Fixed it for free.
    I called Panasonic using the phone number in the manual (1-888-843-9788), selected Service, told that I got the problem which is most probably "a manufacturer's defect" that should be fixed for free - they redirected me to next step, then to next one and in about 20 minutes they arranged me a home-visit by support person (the guy had to drive 2 hours to get here!). Every thing went _very_ smoothly, I am very satisfied with Panasonic's support, it was just one call with few redirections.
    The service guy came in two days, unscrewed back panel, connected some kind of box to one of the boards (eeprom programmer?), turned TV onto some channel and let the box do its job for about 5 minutes - then all of a sudden spots disappeared and picture is OK now. The service guy told me that the overall picture quality should have also improved all across the screen, I guess TV sends some kind of feedback to that box for optimization.
    It was free service, the service guy mentioned something about law action and that Panasonic is required to fix that for free.
    Jun 11, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
    Samsung LN22C350D1D FACTORY SETTINGS??
    1. Do what you did, enter to service mode, and reset to factory default.
    2. Use the component cable (green, blue, red, white, red) connect your set top box to the TV’s component input.
    May 10, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
    Service menu
    How to Enter Service Mode
    1. Turn on the main power switch to place this set in standby
    mode. (LED will light in red.)
    2. Press the buttons on the commander as follows, and enter
    service mode.
    PRESS these buttons in sequence
    ON SCREEN DISPLAY---> (DIGIT 5) ---> (VOLUME +) --->STANDBY
    Method of Cancellation from Service Mode
    1. Set the standby mode (Press “ (TV STANDBY)” button
    on the commander), then press “ (TV STANDBY)” button
    again, hereupon it becomes TV mode.
    Thanks
    Oct 29, 2008 | Sony KP-53HS30 53" Rear Projection...
    TV won't turn on, red light flashes twice
    your tv has hardware problem and Sony service person can fix it.
    Jul 16, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
    Mi dvd-burner doesnt recognize blank DVDs and doesnt burn them
    try downloading www.slysoft.com thier Dvd player play and burns everything and you can do a trail run for 20 days or so lala linda
    Oct 03, 2007 | NEC ND-3540A DVD RW Dual Layer Burner
    Hi guys
    the lightning probably fried the system
    Aug 11, 2007 | Samsung HC-P4741W 47" Rear Projection...
    Philips dvd player not working
    Im sorry to tell ya that you did all the things I would have suggested, so it sounds like a system control problem or a power supply problem, and if its a good machine then maybe its worth you having a service person look at it?? Most dvd units are not worth it these days, unless there combos or recorders.. Sorry couldnt be of more help.
    Jun 05, 2006 | Philips DVP630 DVD Player
    ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
    273 people viewed this question
    Top ViewSonic Televison & Video Experts
    Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
