Question about Addlogix Phone adapter (RJ126T)
RJ 12 female socket
I need to know the wiring diagram for this wall socket i am doing up my kitchen so much would help please thanks .If you could email it too me with colors of wires would be appreciated My email is spudtoby@netspace.net.au thanks
  • 37 Answers
Here is a site that lists all most popular wiring diagrams
http://images.google.com/images?hl=en&q=rj12+wiring+diagram&um=1&ie=UTF-8
Posted on Jun 09, 2008
Wiring diagram for my creda concept solar plus cooker
Request the wiring diagram directly from Creda.
Feb 23, 2018 | Crock Pots & Slow Cookers
I have a (like) phone chord and can't find where to put the other end. We have it plugged into the back of the router, need to know where to plug the other end.
Hi
It depends on which country you are in.
It depends what Broadband wiring setup you have.
It depends which type of cable you are talking about (see images 1 and 2 below)
In some countries, the RJ11 to RJ11 cable goes from this device into the phone Socket of an ADSL filter. One RJ45 to RJ45 cable goes from the Router into the Ethernet Socket of the ADSL Filter. Another RJ45 to RJ45 cable goes from the Router to the Computer. The ADSL Filter then goes into the Phone socket in the wall.
You need an ADSL Filter in every Phone Socket that has a telecommunications device attached to it (Fax Machines, Answering Machines, TV Set Top Boxes, games Consoles etc.). The ADSL filter separates Telehone, Voice & Fax Data traffic from Broadband traffic and allows all to share the same phone line with out conflict.
See Network Diagram below.
In some countiries or wiring setups, the RJ45 to RJ45 cable form the Router to the Wall does not need to go via the Phone Socket and can go directly into its own dedicated Ethernet Wall Socket.
If this answer helps you, please take the time to rate it. This helps answerers better understand the needs and the point of view of the asker and helps us explore the best ways to provide useful, high quality answers.
If you need further help, please feel free to post another question or add a comment to this question.
Thanks for using FixYa
IMAGE 1: RJ11 to RJ11 or ADSL MODEM or BROADBAND or TELECOMS or TELEPHONE Cable
virtual_a_4.jpgIMAGE 2: RJ45 to RJ45 or CAT5E or LAN or ETHERNET Cable
DIAGRAM 1: Typical UK Home Broadband Network Diagram
Aug 30, 2011 | Linksys Wireless-G Broadband Router
For headset use - phone has a female rj-11 connection - the headset I am using has 3.5mm male connections for speach (mic), and for earphone. Do you have an adapter than can accomodate - male RJ-11 to...
First, we want to clarify that the headset connection is an RJ9 (RJ11 is the phone cable to the wall and the clip is larger). Plantronics doesn't make any such adapter but it is available online, just type "converter rj to 3.5mm" and you should get some leads to check out.
Good luck from Headsets Direct - 800-914-7996.
Aug 15, 2011 | Plantronics Headset Telephone Headset
Need to know how to wire a RJ45 Cate 5E wall socket. Trying to understand the wiring diagrams which are numbered 1 to 8 where as socket is configured as A and B in two rows of 4. Fittings I have are Krone...
If you place the socket in front of you, the terminals from on the left side from bottom to top will use the white/blue, blue, white/brown, brown wires and the terminals on the right side would use the green, white/green, orange, white/orange wires from bottom to top.
A and B are used just to differentiate from the T568A and T568B schemes. So if you don't need cross-over configurations, you can just use the same on both ends. The method above is for the B scheme.
Apr 30, 2011 | Philips RJ45 Female to Female Ethernet...
Im am trying to repir a phone socket and need help with where to put the wires
The RJ-11?
find the dial tone on two of the wires you have in the wall.
Attach to the red and green wires on the RJ-11. Test the phone.
Your may have to fool with the wires. Be aware that if you are holding the correct wires when someone calls, you will get a little shot of 60 volts.
Thanks for your quesiton at FixYa.com
Jan 07, 2010 | Lands Phones
Not a 3 wire cable
It's asking for a ground wire. Run a small wire from the green wire on the fan and ground it to the electrical box.
Apr 06, 2009 | Home
Replace old tv antenna with a new one.
make diagram on paper of the old socket . Carefully unscrewing old socket from wall, DO NOT CUT WIRES, copy color of wires (if any) and where and how meny wires on the paper. EXAMPLE:: you have just pulled old socket away from wall, look and see how meny wires, colors if any, and where they are in contrast to the socket.(left wire=blue, middle wire=black, left=yellow, connector that is up or down=color. MARK these wires on paper, and if possible TAPE a piece of paper with a nember[#] on the wire and place that # on the paper corresponding to the wire in socket wall.
Take the socket to electronics store.NOTE;; IF STORE does not have a exact replacement ask store for SIMULOR replacement.Show the diagram you made to help you buy the right replacement.
Good luck
May 05, 2008 | Televison & Video
Addlogix Phone adapter (RJ126T) Logo
2,473 people viewed this question
Top Addlogix Computers & Internet Experts
David Payne
David Payne
Are you an Addlogix Computer and Internet Expert? Answer questions, earn points and help others
