Question about Brother IntelliFax-2820 Laser Fax
Change toner sir, i changed the new toner then also display showing change toner reaason please.
Most likely its a defective toner unit, they have a chip on them that tells the machine when it was installed, and how much life it has remaining. if the machine doesn't recognise that its a new toner cartridge its probably a defecive unit. you should return the cartridge from where you got it and try another.
Posted on Jun 09, 2008
E-studio-232 adding toner problem
change the developer with the new one and change the sensor toner.
May 24, 2012 | Toshiba e-Studio 232 Black and White...
Had toner life end message. Replaced toner and drum with oem,machine reset but now just making blank copies. Tried to print internal report that's blank too
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Please note that this must be done with a new cartridge so the unit will see that there is toner in the cartridge.
Aug 01, 2009 | Brother IntelliFax-2820 Laser Fax
Toner life end warning light. replaced with new toner/drum still error
1. With unit powered on open the front cover.
4. Press "+" key 10 times until the display reads 10.
5. Press "SET" key.
6. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
7. Close cover and see if Toner Life End error message has gone.
Jul 28, 2009 | Brother DCP-7020 Black and White Copier
Sir i have brotherfaxprinter i refilled the cattriage but the printer was showing this option remove the door and replace the toner toner life over please the reply soon
If this doesn't work please let me know exaclty what model you have.
Open the front cover of the machine, press clear/back or options, the lcd should display change drum? press *00, close the front cover
Jun 11, 2009 | HP 645A Magenta Toner Cartridge (C9733A)...
Problem with changing the Toner Copier Cartridge
F2 has to do with a toner sensor not working. It could be the replacement cartridge is missing something. Make sure you use a genuine Sharp toner cartridge and that should take care of the problem.
Nov 03, 2008 | Sharp AR-5316 Advanced Digital Imager...
Replacing of new Cartridge problem
good day sir
I am Josco and my Email:oyas20102005@yahoo.com.
I have a lot of Sharp Copier but there is one that is giving me comcern coming out with a code (showing H & 4) and i can not work with the copier Sharp Digital AR-5316. please what do i do and it is the newest copiers among all, please i will be very glad to recieve a code so as t clear the interupting showing H & 4 on the copier.
Thanks
Josco from Nigeria.
How to change cartdridge for other color???
If you wait until the colour has completely run out, you will see a message to that effect, and the correct cartride will be presented. If you wish to change before this:
1. On the printers' control panel, press the "right" button (labeled no. 3) once and then the "down" button (labeled no. 4) until you see the RESET MENU.
2. Press the "right" button (labeled no. 3) once.
3. Press the "down" button (labeled no. 4) until you see "CHANGE TONER X" appear on the screen (where X is either C, M, Y or K, Cyan. Magenta, Yellow or Black).
4. Press the "right" button (labeled no. 3) once. The printer will rotate the toner carousel to the correct position for you to change.
5. Open the printer door and change the toner as normal.
Jan 20, 2008 | Epson Aculaser C1100 Printer
Fax machine 2820
Make sure that you are not using generic supplies. Using generic supplies or supplies that have been refilled will cause the unit to give false errors. There is white piece of plastic inside the semi circular opening, if you do not see a white semi circular opening it is either a generic toner or starter toner and you will need to replace the toner with a authentic toner. You may try this also: 1. Remove the drum and toner, separate the drum and toner and then rock the toner from side to side. 2 Put the drum and toner back together and clean the corona wire ten times. 3 Put the drum and toner back inside the machine and close the cover, if you still have toner life end try this: a Open the front cover b press the options key, the LCD will say "replace drum?" c press the start key. and then press 10 on your dial pad. the display should say accepted for about 2 seconds and then say cover open. d close the cover, if the display still has toner life end, you will need to replace the toner
Oct 03, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
148 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
