Question about Refrigerators
Samsung RS20....noticed this AM the fridge side in not cold enough and the temp number on the door is flashing on and off.
  • vhomes Sep 01, 2008
    Got the same problem with my RS20NASH. Freezer and Refgrtr not cold. Temp LED indicator was blinking. Call Samsung SC, they came and said the sensor was not working. Requires 2 weeks to order. Still waiting for them to replace it.
  • 833 Answers
Sounds like you're frosting up.
Defrost unit manually. Clean the condenser coils. Don't leave liquids uncovered. Don't leave the door open unnecessarily. Make sure all air passages are open and clear. If this doesn't fix it long term...you likely have lost some refrigerant and need a recharge.
Posted on Jun 09, 2008
    Problem Solver:
  • 10 Answers
Temp blinking shows there is temp.not able to maintained on desired setting.check fan motor on fridge side is rotating or not,door not getting closed properly,or check fridge is defrosting automatically or not.
Posted on Jun 14, 2008
  • sandesh kajrolkar
    sandesh kajrolkar Jun 14, 2008
    please give proper model no. to give detail technical idea
    thanks
Kitchenaid side by side fridge is freezing food
you have a bad damper assy.when it gets cold enough in the fridge section the damper door closes so the cold air can't blow in from the freezer side,the door isn't closing allowing the cold air to keep coming into the fridge side 2220377 part number and this is electronic damper.if you order it from repair clinic you have 365 days to return it if it's damaged or it isn't your problem they will take it back,i'm 99 percent positive that this is your problem,when i would call the customer and get model number and ask a few questions i would take this with me when i go to the house from the discription you're giving.
Dec 05, 2013 | KitchenAid Superba Architect KSCS25INSS...
Freezer too cold--refrigerator too warm
If the cold control is not adjusting the temp when you move it, that can be part of the problem.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jan 26, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge seems to require max cold temp control
did you check to be sure the the compressor cooling fan is operational? if this is bad it will cause a problem similar to your condition. another thing if this checks ok is that your temp control could be getting weak, ( it has small springs connected to the contacts) and may need replacing. the fact that it will get to 0f tells me that compressor and freon system should be fine.
you mentioned the warm area on the side of your door is a anti moisture feature. if this area is abnormally hot it would indicate a bad condenser fan motor which is the compressor cooling fan.
If you have any further questions let me know thanks Peyton
Feb 23, 2009 | GE GSS20IETCC 20.0 Cu. Ft. Side-By-Side...
Samsung Fridge Freezer Model RS20
Renee,
There are a few things we need to look at. The likely cause is frosting up of the coils. This will also stop the fan. The best thing to do is to defrost the unit completely. The easiest way to do this is to shut it down and leave the doors open for 24-48 hours. You'll have to mop up a surprising amount of water. Now, why did it happen? Probably humidity due to 'window shopping', not closing the doors/bad/dirty gaskets, leaving liquids in the box which are uncovered. If this doesn't fix it...and you'll know after a week or so, it may be that the unit is low on gas or has a defective defrost timer...but that is getting ahead of ourselves.
Jan 22, 2008 | Refrigerators
Admiral side by side
All the cold air from your freezer gets pushed into the fridge with a fan in your freezer section. So your problem is from the fact that this cold air isn't get to your fridge.
- the door that allows this cold air into the fridge, normally in the top left corner of the fridge, is stuck shut and needs replacement.
-the freezer isn't defrosting and restricting the air flow
-the temp controller for the fridge is damaged and thinks that the fridge is cold enough.
Nov 15, 2007 | Admiral 26 cu. ft. Side-By-Side...
Side by side fridge freezer
Based on your weird display issues I'd lean toward the control board problem. At least that can be "one" of a couple problems...
Feb 01, 2007 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
265 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
