Question about KDS Radius RAD-7 17" Flat Panel LCD Monitor
Cant turn on
Where is the power cord located?
    Genius:
  • 2,985 Answers
Is the cord missing - perhaps a low/voltage co-ax socket which means that you will need an external power supply
Google to the rescue
Check out this lot
http://www.google.co.uk/search?q=KDS+%3E+Radius+RAD-7+17+in.+Flat+Panel+LCD+Monitor&sourceid=navclient-ff&ie=UTF-8&rlz=1B3GGGL_enGB260GB260
Posted on Jun 09, 2008
Find a replacement power cord for my autoclave
Yes same for me trying to get a replacment cord can't find any info on them
Jan 12, 2015 | Science & Laboratory
My tablet wont charge unless turned on but battery is so low it wont turn on so cant charge it up.heeeeeelllllpppp
You Power Cord must be bad. If you cannot get on the laptop by using just the power cord, then the power cord is bad and needs to be replaced. Also it sounds like you've been operating off your battery since the power cord is bad, but now the battery is dead because the bad power cord was not charging it.
Get a new AC Adapter and Power Cord. Or it could be that the pin where you plug the power cord into the table is damaged or broken.
May 15, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
I cant set up my Nintendo 64 Console
Do you have all the cords.
You will need to simply plug in the power cord to the wall and then plug in the AV (red, white, yellow) cords to your Television.
You may need to select the input for the TV to RCA.
Good luck.
The power switch is located on the top of the console.
Jan 29, 2011 | Nintendo 64 Console
SAMSUNG LN52B610 TV TURNED OFF BY ITSELF. CANT TURN TV ON. NO RED LIGHT ON TV FOR POWER. OUTLET WAS CHECKED AND HAS POWER. CORD IS IN GOOD CONDITION. PLUGS FIR SNUG IN...
Hello.
If you have multimeter available you can actually check if voltage present at the end of your power cord first.
If it's OK than you have to remove back cover from your TV and locate power supply board. It's very easy - it should be next to the power cord receptacle. First look for capacitors that have bulged tops instead of flat ones. If you locate any - replace them and check if it's going to take care of problem.
Right next to receptacle connection is fuse located and you have to check if it's open. Replace it if needed. If new fuse got blown right away - you have short in power supply board. If fuse is OK - connect power cord and using multimeter try to figure out if 5V is supplied from Power supply board to the main board (the one that have all inputs attached to it). If 5V is present but power LED in front of the TV is still dead - you could have problem with main board.
Best regards.
Russ.
Aug 17, 2010 | Samsung LN52B610 52 in LCD TV
My dad cant hook mine up for some reason
Ok
First, Turn your T.V. on and go to the input mode on the t.v.
Second, there should be two cords in the back of your playstation3.
The power cord and the input cord. These are the two basic cords to turn your playstation on.
Once you have them plugged in, on the back of your playstation 3 there should be a power switch right above the power cord. Click it on so that the I is down and the O is up. In the front of your Playstation, a red light will appear indicating that the Playstation is ready to be turned on. Tap the red light until it turns green ( this should only be tapped once) When it is green the system will go to the start-up menu and enjoy your Playstation 3
Jan 15, 2010 | Sony Playstation 3 (PS3) Console
I cant figure out where the power cord goes, and i also need to know where to buy the cord
Power cords are universal, called UPC type and can be found at any electronic parts or retail stores.
Locate a male 3 prong power connector on back or under the monitor
Oct 08, 2009 | AOMNI Corporation Magnavox 15MF605T/17 15...
I cant reboot my screen its all white.
Turn off the pc, disconnect the power cord. Remove the battery. Leave it alone for a few minutes. Plug in the power cord (do not replace battery yet) and turn it on. If it works, turn it off, remove power cord and replace battery. Plug power cord back in and turn on pc again.
Aug 21, 2009 | Dell Inspiron 1420 Notebook
Cant find a replacement fuse for the power cord
the fuse is located in the cigarette lighter plug, at the end you will see a silver cap and then the disk that goes over the top of it, that will turn and then you will have the front open to replace the glass fuse that is in it... to find the fuse size, after the fuse is out look at the silver ends it will have the size stamped on it... it might be a 40 amp fuse. or 20 amp. just look at the silver sides on the fuse you will find that there... hope this helps you out
Jun 03, 2009 | XRS-757 Radar Detector
Cant get my turntables turned on and there connected to my mixer do i need the power cords for the turntables????
if there is a slot for a power cord on the turntables them selves then yes you need the power cords
Apr 21, 2009 | Gemini XL-500 Turntable
KDS Radius RAD-7 17" Flat Panel LCD Monitor Logo
146 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
