Question about Hitachi 70VS810 70" Rear Projection HDTV
Power light blinking continuosly
When i power up the set the 3 lights (lamp, temp, (those 2 are red) and the power light) come on then the 2 red lights go off after about a second, which is normal but the power light keeps on blinking. I had this problem 3 days ago and phoned Hitachi. I unplugged it from my panamax 5400 for a minute and then plugged back in but that didn't help. Then pissed off I went to bed. When i got up the next morning the set worked fine. I called the repair people and they told me that there wasn't anything they could do for me unless it was broke like the night before. It has worked fine for the past 3 days and now has gone out again with the same problem the power light keeps blinking. There is an eventual illumination coming from the set. It isn't bright but its there. Just now, after the TV has been off for 6 hours I went and turned it on. It worked fine for about 30 seconds and then the power light came on again picture went out, just the dull illumination and the power light keeps blinking. Any information that you could give me I would greatly appreciate. Thank you for your time.
  • Morigu Jun 08, 2008
    Thank you for your comment. I have already replaced the lamp. Infact like magic it worked this morning no problems. Unfortunately now that I have shut it off again it won't turn back on and the power light just keeps on blinking again. Seems like it needs 6-8 hours of rest before it restarts itself. I will have to look for a repair man. Thanks again for your help
  • Morigu Jun 15, 2008
    No fireplaces, and no smokers. But it is new home construction so there is a lot of dust. I will try cleaning out the fan. Had a tech come over and he told me to disconnect my HDMI cables from the TV hook up the standard jacks to it. Unplug it from the power source for at least 6 hours then turn it back on so that it can do a reboot. It just seems to me like its storing power and then shutting down for safety until it disapates and then is able to restart. It has run most of this weekend so far. It will be the last time I buy Hitachi though! Thanks for all your help.
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 92 Answers
First off check your lamp or replace it. You can never have too many lamps..........in the last minutes of overtime ! Are you kidding Me! If lamp doesn't work, you will need to find qualified servicer. Try craigslist or tv repair in yellowbook
Craig www.classtorations.com
Posted on Jun 08, 2008
  • Craig Siplin Jun 08, 2008
    There are several other problems that can cause your type of shutdown. This could be a temperature problem that could simply involve dirty or non-working fans. If there are smokers or fireplaces in the home. I would bet she's dirty on the inside. Just a thought
The tv went blank @ the red led is flashing continuosly sony kds-60a2020
If its lamp light on tv front that is blinking red then lamp is dead/ broken and need to be replaced. Lamp replacement procedure is easy and written in user mnaual of tv.
If it is standby/ power light that is blinking then please count how many times it is blinking after three seconds pause and let me know to diagnose tv problem because it is an error code that has info in its blinking.
Thanks.
Apr 03, 2011 | Sony KDS-60A2020 60" HDTV
Hello I have a Samsung TV Model# HL50A650C1FXZA I have 3 lights blinking 2 green and 1 red light what is the problem
Hello, I try to help. But your questions not spesific.
Below are conditions lamp indicators that appear blinking and solutions:
1. If Timer and Lamp blinking --> Auto timer on/off was been set, picture will appear ~ 25 second.
2. If Timer and Standby/Temp blinking --> A cooling fan inside the set is not operating properly.
3. If Lamp and Standby/Temp blinking --> The lamp cover on the rear of the set is not installed properly.
I hope that solve your problem.
Thanks.
Feb 22, 2011 | Samsung DLP HL-P5663W 56" TV
Series of 3 blinking lights. manual says lamp door isnt fastened properly. it is. i tried unplugging tv, have opened and closed lamp door 3xl. still blinking.
After I unplug and then plug tv to reset I get a solid standby light,then when I push the power button I get a green light that blinks 6 times then it blinks red 6 times and then red 6 times continuosly with a slight delay between the 6 blinks of red.
Oct 11, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
No picture and no sound
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 11, 2017 | Samsung Televison & Video
My Panasonic PT- 50LC13 doesn't turn on
Your service manual on page 82 steps you through decoding the blinking
1) there are two lights on the front near the reciever of the remote signals (Temp indicator and Lamp Indicator)
2) If the Temp indicator is on then they recommend you contact a service center
3) If the Lamp indicator is on and the power light stays on (no blinking) then you need to replace the lamp. Otherwise it says to contact the service center.
4) Counting blinks with the lamp indicator (1 every 5sec - lamp will not light or is abnormal, 2 every 5sec - lamp voltage is abnormal, 3 every 5sec - lamp temp is too high, 4 every 5sec - other error)
Apr 26, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic pt-52lxc66 power light blinks
There are actually two red leds present on your tv and depending on which one is flashing is going to tell you what to replace. 3X on the Temp led will point to a faulty thermistor and you would want to replace this part. If the 3 red blinks are the lamp light than this is a error on the iris position and you would need to have the optical block replaced.
Josh
Feb 09, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Hitachi 55VG825
Refer to owners manual on code of blinking lights. 2 red blinks means fan is about to fail etc.. thats just an example of course. See the manual it will tell you what the blinking means. It will also tell you if you can fix it or you need a tech.
Dec 28, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Open Questions:
See all Hitachi 70VS810 70" Rear Projection HDTV Questions
Hitachi 70VS810 70" Rear Projection HDTV Logo
458 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
