Question about Blaupunkt Louisiana DJ32 Cassette Player
Blaupunkt flattening battery
Hi I have an Alfa 166 3 litre,2000 yr with a factory installed Blaupunkt cassette, cd changer radio in the Integrated Control System centre console. Should we not use the car for a week, with the radio and ignition off, the battery is flattened and the Alpha dealer states the radio leaking current and flattening the battery. Nobody seems to know in NZ how to fix this as they need software codes. Any help would be greatly appreciated, John
    Novelist:
  • 150 Answers
I would be concerned about the amount of current required to kill a car battery in a week:
Let's assume that 1 week = 24 * 7 = 168 Hrs
A typical, healthy car battery will deliver anywhere between,
45 to 70 Ampere-hours at small currents, depending on the
size of the car (check your car owners manual)
Assuming a weak battery has a 40 Ampere-hour reserve, it would require an average current of 250 milliamperes to drain
in a week, or about 3 watts of power.
While this does not seem like a lot, it certainly indicates
something is wrong, because the clock and station memory
in a radio should take a lot less than that.
The first step is to make sure that the radio is actually at fault,
not damaged wiring or another one of the dozens of electronic
systems in a modern automobile.
Don't trust your mechanic on this, I have never met a gear-head
that was any good in electronics, but they do come up with
some fairly captivating fish-stories when they do not
understand something. :)
1) The first step is to disconnect the radio and isolate the
problem.
2) Remove the radio and hook it up to a 12V DC supply,
or battery through a digital milliamp-meter. Check the
current with the radio shut off.
3) Anything over about 10 mA or so is BAD.
4) If the radio draws any significant current with the switch
shut off, look for a bad switch or a leaky capacitor on the
B+ wire (before the switch, so it should not be hard to find)
Another possibility is the clock/keep alive controller chip,
but this is less likely. The most likely culprit is probably
an old leaky capacitor (electrolytic or solid tantalum),
since these do tend to fail with age, vibration and extreme
temperatures in a car environment.
5) If the radio is at fault, you will need some knowledge and
electronic instruments to find the problem yourself.
A quick way to check an electrolytic or tantalum capacitor
is with an ohm-meter. Connect ohm-meter to the capacitor,
and watch the reading race to infinity as the capacitor charges
up. Then reverse the leads and watch it again. Once charged,
the capacitor should have infinite impedance.
6) If the radio is not at fault, it could be dozens of other
problems, ranging from the body control computer,
immobilizer, remote starter, parking lights, door-locks,
alarm system, bad wiring ... you name it.
7) You should be able to isolate it by measuring the battery
current, while pulling fuses one at a time.
8) Another possible cause is the battery itself, or a bad
(shorted) diode in the alternator. The best way to check
the alternator is with an oscilloscope, while the car is
running.
A bad diode will show up as a missing peak in the otherwise
regular pulse train.
9) Finally, don't over look the relays in the power distribution box.
These can over heat and stick in the ON position with the
ignition turned off.
Good luck, Martin
Posted on Jun 13, 2008
    Novelist:
    Champion:
  • 218 Answers
Can't help you with the wiring diagram, but a short term solution might be to put a toggle switch in line with the radio power lead, perhaps at the fuse, and just flip that switch to take the radio out of the circuit. Once you have solved the problem then remove the switch. One way to do this might be to take out the fuse for the radio completely and add a switch and inline fuse with an alligator clip on each end of the switch/fuse wire assembly you have made and clip one clip at each end of where the fuse plugs in. Once a permanant repair has been made, remove the assembly and plug the fuse back in. Be sure you are disabling the right power source to the radio. There are two. One for the memory function and one for the switched power function. If I were a betting man I would bet it is the one for memeory function since that one is not every turned off. Of course when you disconnect that one it will cause you to loose all your station presents and clock time, but at least your car will start and you will know which circuit is killing your car battery. My first guess would be the output module for the radio is about to fail. Just a guess, but maybe this helps. Later man. Good luck
Posted on Jun 09, 2008
Unlock code for Blaupunkt 420 radio
hi
i got a cd from ebay and its unlocked loads of stereos. very easy to use and it was very cheap to buy.
Roger
May 10, 2014 | Blaupunkt Car Audio & Video
HELP I NEED CODE FOR BLAUPUNKT CD RADIO SERIAL NO IS BP8551W0944298
The only way to get a code is thru a Dealer. If it's an aftermarket unit, look for a Car Audio shop that sells Blaupunkt. If it's Factory, the Car Dealership service dept can get it for you. Be aware though, they will charge a nominal fee to do this. So when you get the code, put it in a safe place! If it's Factory installed and you are the original owner, It would have been with your owners paperwork. If not, call your selling dealer and they may get it for you at N/C. Hope this helps.
Jun 01, 2011 | Blaupunkt IDC-A09 5-Disc CD Changer
Alfa Romeo 166 ICS Radio AUDIO mode is inoperative. As I switch the radio button to the "ON" position by pressing the switch, I get all the tuninig of CD/Casette/FM/AM radio frequencies, but non fo them...
The audio board is at fault. Take the unit in for repairs at any car dealership. They can send it out for repairs to any center that repairs radios for cars
Sep 07, 2010 | 2000 Alfa Romeo 166
I have a 2000 beetle with fixing in the boot for cd changer...will any changer do, not sure what i should be looking for! Thanks
Likely have a Monsoon radio system in your 2000 Beetle. The CD changer is controlled by your radio, and not any CD changer will connect to the outlet in your trunk. You can either find a CD changer on eBay (or elsewhere, or swap out your radio for a radio from a newer VW Beetle that has a CD player installed instead of the cassette. Can also find those on eBay.
Jun 10, 2009 | 2000 Volkswagen Beetle
Specs for Factory Installed AM/FM Cassette Radio & CD Changer.
generally each speaker in any car as a wattage range from 25 to at least 60 so if your car as four speakers lets say you would need a radio that with the four speajer channels with 200 watts but 300 would be better because it will move the factory speakers better and it wont put a load on the new radio
Aug 29, 2017 | 2000 Chrysler Cirrus
1998 - 2002 Honda Cassette 6 disk CD changer Radio
the cd changer is malfunctioning, the factory cd changers usually don't last that long because of the heavy use and many mechanical puts
Jul 29, 2008 | 1997 Honda Accord
Blaupunkt IDC-A09 5 Disc Changer
Hi try unpluging both the cd and the head unit from power for 30 mkins or more. this should reset the system. plug the head unit in 1st then the cd.
regards
Mark
www.blueice-electronics.co.uk
Jul 23, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt Louisiana DJ32 Cassette Player Logo
331 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
