Question about Video Game Consoles & Games
My IP Adress is failing.My laptop (connected to my 360.)has almost a full amount of internet signal on the toolbar at bottom of screen however there is another connnction (i guess with the 360 with a status of:limited or no connectivity. And whenever i try and repair it, it says: windows could not do the following action: renewing your IP adress. And i can't connect with my modem directly [(or i need 26.8 metres of ethernet cable.)you see my point?] IT IS MY FIRST TIME CONNECTING TO LIVE Can u help me?
It's not recommended to bridge a connection through a laptop to any other device... it's typically hard to setup and very faulty. Take lots of time to maintain and lots of patience... I would suggest taking the easy way out and getting something similar to this product.
http://compnetworking.about.com/od/homenetworkhardware/gr/xbox360wireless.htm
I can almost guarantee that you will not get a decent connection by bridging in the method you're describing.
Posted on Jun 09, 2008
Time out obtaining ip address
to create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
click on the tools at the bottom of the drop down list will be internet options or
click start control panel internet options you will see a home page box To Create Page Tabs type
each adress on its own line (type in google.com) or your preferred home page and browser
below that will be change search defaults click on settings you will see all search providers you
have if dont need any of them you can disable or remove them
click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details
or type in your default gateway adress into your internet search should read something like 10.0.0.138 to get an inertnet connection
hope this helps
Sep 28, 2012 | Computers & Internet
Same thing
Enable Internet Connection Sharing in Windows XP/Vista
Aug 06, 2009 | Microsoft Xbox 360 Console
Ip adress failed
u should try ringing ur internet server and u dont connect it to ur laptop u connect it to ur modem and router and btw for some reason xbox live doesnt work for everyone it weird but no one knows why
May 09, 2009 | Microsoft Xbox 360 Elite Console
Cannot connect belkin wireless adapter to my xbox 360 thru my pc
every computer has an ip adress you might have to go to your internet setting and find some thing that says some thing like... internet adress hook up hopefully you keep files on your computer becuase with out your ip adress you might not be able to hook up its sorta like a combination hope it helpes:)
Mar 02, 2009 | Belkin Video Game Consoles & Games
Ip address failed
In order to connect your XBOX 360 to your laptop (if the laptop is connected via dial-up), you'll need a cross-over ethernet cable. It's a special type of ethernet cable, which is typically the same price as a regular ethernet cable, but it allows two devices (in your case) to communicate with each other. Then, you'll need to configure your laptop to allow incoming connections via your Control Panel -> Internet Connections preferences.
Hope this help!
Robert W.
Jan 08, 2009 | Microsoft Xbox 360 Console
I need an IP adress
u have to change ur sharing settings on ur laptop in connections so ur port will open to let ur laptop and xbox find each other
Jan 06, 2009 | Microsoft Xbox 360 Console
My xbox 360 says i need an IP adress
The XBOX is configured for connecting to a router or server that will assign it an IP address. Connect it to your router instead of your laptop.
Xbox elite ip adress failure
From the question above I think you are saying that when you unplug your Ethernet cable from your Internet connection out of your E-BOX and try to use it in your laptop, it doesn't work. If this is correct, then it's probably that your ISP only allows for 1x active address to be used at any one time. To overcome the problem you'll need to also power recycle your Internet modem to clear out the MAC address of the X-BOX once you've unplugged it and before you make the laptop connection. You would have to do this each time you wanted to swap between the devices.
Alternatively, get yourself a Router to sit in between the Modem and end devices and then have an additional permanent cable / 2nd physical port to use.
Oct 25, 2008 | Microsoft Xbox 360 Elite Console
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
Ip adress
this is not a fault with the xbox 360 rather it is a problem you have with your internet connection or router. you'll have to check or possibly renew dhcp (the protocol that issues ip addresses on your router if you use one) or contact your isp about it.
Feb 10, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
