Question about HP Computers & Internet
Monitor no input signal - HP Computers & Internet
    Brigadier General:
  • HP Master
  • 3,614 Answers
Check the connection fro the video card... it is better to remove and put back again the video card , if your are using an expansion card...
Posted on Jun 08, 2008
  • micromaster
    micromaster Jun 08, 2008
    This seems cut and dried, but when it actually happens, it seems impossible to simply presume that the CPU is at fault. Sure, a faulty CPU will prevent a computer from starting up, but couldn't there be other causes? Yes. When a computer refuses to start but the power light illuminates, the main culprit is usually the PC's PSU (power supply unit). If you haven't made any recent upgrades to your computer, try replacing the PSU. Consult the PC or motherboard manual to make sure the new power supply is appropriate for your system. If the problem occurs after making an upgrade (such as replacing the CPU), consult the PC or motherboard manual and determine whether the PSU is properly connected and set at the correct voltage. If these solutions don't work, try replacing the PSU.
NO DVI INPUT SIGNAL AND MONITOR GOES TO SLEEP
you can't run 2 different inputs at the same time. VGA takes prescedence.
Apr 06, 2014 | HP L1950 Monitor
No input signal on monitor-not connected to tv-computer works fine except for the no input signal
no input or signal means that the monitor is not receiving any signal from the CPU and if the power light is amber then and the cpu works fine then there could be a problem with the cable connecting the CPU and the monitor ...check the cable.
Mar 03, 2014 | Dell Computers & Internet
Searching for signal
DVI and HDMI are the exact same signal, except that DVI doesn't include the provision for audio. Essentially the problem you're having is that you have the monitor set to auto input rather than HDMI input or DVI input. Setting the monitor to not look for any input you plug in and defining the input should cause the hunting wait to be eliminated.
Nov 23, 2013 | ASUS VK222H Monitor
No signal input ton montitor
Try a different monitor. If that works, your monitor has gone bad.
Mar 03, 2013 | HP Pavilion Computers & Internet
What should I do because it says no signal input
Sounds like your video card or monitor is bad. Most likely it's the video card because if it was the monitor the No Signal Input could not appear on the screen. To isolate the problem try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed Monitor displays ok without a problem then your original monitor is bad. If the Borrowed monitor has the same issue of No Input Signal as your original monitor, then your video card inside the computer is bad.
May 30, 2012 | Biostar MCP6PB M2+ Motherboard
What is Monitor Out on 42'' Hitachi plasma TV (42HDT50)
Monitor Out connects audio and video signals to an external monitor with corresponding inputs as noted in the document.
Mar 07, 2017 | Hitachi 42HDT50 42 in. HD-Ready Plasma...
Getting a no signal when hoioking up to video card.
hook a different montor up to the same card and see if you get a signal. if you do change the input on the monitor not getting a signal. if this does not make the monitor get a signal your video input on the monitor is bad and needs o be replaced or repaired
Dec 26, 2009 | AOC Monitor
Monitor status - no input signal. What does this
the problem might be coming from your video card or try changing your RAM
Jul 25, 2009 | HP Computers & Internet
Computers & Internet Logo
23 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
